Wednesday, March 24, 2010 - 06:53 pm, by: Aaron Mead(Aaron)
Looks rather straight forward, but with all the tension from the lower control arm connection, will it go back in if I undo the big nut on the end of the strut bar? (I think its like 32mm)
Or should I undo everything up front, remove the airbag etc... and undo the two nuts that hold connect the strut bar to the LCA (seeing as you cant get to those nuts without removing the bottom strut to get into the strut bracket)
