  Soarer Central * Celsior Chat * Integration relay Previous Previous    Next Next
Matt Shields
Reg: 01-2010
Sunday, April 11, 2010 - 06:24 pm, by:  Matt Shields (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is anyone familiar with the integration relay? specifically location, symptoms of failure, testing and if so where i can get a replacement for how much?
think i cooked mine this weekend wiring up some lights.
looks like this
http://cgi.ebay.com/ebaymotors/Lexus-LS400-Integration-Relay-90-94-OEM-82641-50010_W0QQcmdZViewItemQQhashZitem230523a238QQitemZ150410076728QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
James Paton
Celsior V8
Reg: 12-2009
Monday, April 12, 2010 - 01:09 pm, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Location is up under the steering column on the fuse panel... trick is though its on the other side of the fuse panel.
If you are looking for one I suggest you pull your old one out first because there are a couple of different ones and you may purchase the wrong one (like I did) I paid $80 delivered from Japan for mine which was from Yahoo Auctions.
Matt Shields
Reg: 01-2010
Monday, April 12, 2010 - 04:30 pm, by:  Matt Shields (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok so to get this straight, it is on the underside of the dash, to the RIGHT of the steering column?
what shrouds to i need to remove?
i was under the impression i had to remove the lower part of the dash cover. and then that cream coloured fuse junction where all the blade fuses are, i need to drop that somehow, and it's on the top side of that. correct?
and can it be removed and the car function ok? or does the car need it to be in order to function.
its weird because the ONLY thing that has gone out has been my interior lights and nothing else. everything else works perfectly. your help would be appreciated as i've spent hours searching and not learnt a lot!
James Paton
Celsior V8
Reg: 12-2009
Monday, April 12, 2010 - 10:42 pm, by:  James Paton (Mys013) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you climb in and under the dash you will see the standard interior fuse box... you have fuses on one side of the panel but on the top side of the fuse panel you have relays, this is where the integration relay is. Its a fairly big relay.
From what I saw the car does function but I dont know what else you loose by not having it working properly, my issue was I had lost headlights completely. I would be very careful working around this area, disconnect the battery as the air bag wires are in the same place.
What you neeed to do is remove the lower dash panel, and loosen the fuse panel you should be able to have enough movement to remove the integration relay but it is fiddly.
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Tuesday, April 20, 2010 - 01:10 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey matt just wondering if you found or fixed the problem as one of my friends with a celsior is experiencing the same problem his interior lights wont work and neither does his fender pole, everything else is good
could this be similar to your problem or something else?
Matt Shields
Reg: 01-2010
Tuesday, April 20, 2010 - 03:15 pm, by:  Matt Shields (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
not as of yet. got some decent leads from some knowledgeable fellas on other forums.
if it works in my favour, it should be a 20c fix.
havent pulled out the unit though, so once i do that i'll know more and i will certainly let you know the results.
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Tuesday, April 20, 2010 - 03:56 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks mate, cheers
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Saturday, April 24, 2010 - 11:47 am, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the same problem has just happened to me.
interior lights wont work same with the parker lights and front passenger seat
Maclean Cherry
Celsior
Reg: 01-2010
Monday, April 26, 2010 - 12:52 am, by:  Maclean Cherry (Maclean_cherry) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did you check the fuse that I told you about?
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Tuesday, April 27, 2010 - 09:31 am, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah i couldn't find one labled dome everything is in japanese lol.
still have the problem but:-(
got a working integration relay for 10 bucks:-)
then taking it to the auto elec
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Friday, April 30, 2010 - 04:04 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well just got the integration relay today thought i'd have a go. i changed it and the problem remains
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Friday, April 30, 2010 - 10:36 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
could it be the light control ecu?
Matt Shields
Reg: 01-2010
Saturday, May 01, 2010 - 11:52 am, by:  Matt Shields (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dome light fuse is on the fuse box under the bonnet. its a 10 or 15 amp fuse. can get a photo of the exact one if it helps?
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Saturday, May 01, 2010 - 06:42 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah that would be good mate
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Sunday, May 02, 2010 - 11:43 am, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i done some more researching and found english translation to the fuse box and yes, it was the 10 amp dome fuse. i feel so stupid now knowing all of this was over a 10 amp fuse
Matt Shields
Reg: 01-2010
Tuesday, May 04, 2010 - 10:55 am, by:  Matt Shields (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thats great news josh. sorry i didnt get round to taking a pic for you.
fancy selling me your spare integration relay???? i was going to try and repair mine, but this would be a hellofa lot easier!
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Tuesday, May 04, 2010 - 03:18 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
pm me with an offer:-)
Matt Shields
Reg: 01-2010
Tuesday, May 04, 2010 - 09:57 pm, by:  Matt Shields (Smokeyvip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
erm, you said you paid 10 bucks for it so....10 bucks+postage?
Aaron deVisser
Reg: 09-2010
Thursday, December 09, 2010 - 02:02 pm, by:  Aaron deVisser (Bigdiv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just wondering if mine has the same problem, the interior light functions fine when on the "on" switch, but when i open the doors when its on "door" it does not. I read somewhere the relay box requires a resistor replacement ? Any one had experience with this ?
