Saturday, June 05, 2010 - 07:11 am, by: Steve Eardley(Steve2006)
Mounted on the passenger side on the corner of the front bumper I have the mini aerial that you can put up to help you judge the edge of the car. It even has a light on the top which illuminates with the sidelights. Were these a standard item or an optional extra as I have never seen another Celsior with one fitted. Having said that I have never seen another Celsior in the UK.
Saturday, June 05, 2010 - 08:40 am, by: Joshua Baldwin(Celsior101)
i know of a lady named emma williams who has a celsior in the uk. not many at all around your area. im pretty sure the fender pole is a extra option. my c-f doesn't have one
Sunday, June 06, 2010 - 05:03 am, by: Steve Eardley(Steve2006)
Mine didn't work when I got the car so I removed it in an attempt to repair it but the nylon drive was brittle and crumbled (just like the aerial but with a wire inside it for the tip lamp). This left a hole in the bumper but eventually I managed to get a working replacement from Japan. I do occasionally use it when pulling out from behind another parked vehicle but it's more of a talking point than a fender pole.
Tuesday, June 08, 2010 - 03:47 pm, by: Ashley Sommer(Flubba86)
Righto, so thats interesting. I have a fender pole in my front bumper, but I dont have that up/down switch on my dash.
Also, I dont have that "auto airpuri" knob either, whats that for? I have the purification system in the boot, should I also have that knob to control it?
Tuesday, June 08, 2010 - 05:57 pm, by: Joshua Baldwin(Celsior101)
so there is no buttons? what is there? just the blank plastic trim? see whats behind it and see if any wires are behind it that lead to a plug? if not it sounds like the bumper bar has been replaced with one that has the fender pole. my celsior has neither of these switches/buttons
Tuesday, June 08, 2010 - 07:54 pm, by: Ashley Sommer(Flubba86)
Josh.. yeh, its just a blank plate. I took the plate off, theres nothing behind it, no wires like I was hoping. So yeh, would be a repalcement bumber I think. Also my air purification system seems to work by itself, I dont know if I need that "auto airpuri" nob.
Tuesday, June 08, 2010 - 09:46 pm, by: Joshua Baldwin(Celsior101)
you dont need the auto airpuri nob if it didn't come with it, the air purification will work fine. the airpuri nob and fender pole was just a dealer installed option like what don said.
