Thursday, June 24, 2010 - 05:55 pm, by: Ryan Castle(Pzest8)
hi there guys !! i know this has probably been covered already but i have searched for hours with no luck !! few weeks ago i acidently jacked the left side of my car up and then it stayed like that. i spoke to a soarer workshop in queensland and he sagested deflating all the bags and resetting computer. this worked for around two weeks until i raised the height on my height controller i tried deflating and resetting but no luck and now i also have air escaping from what looks like the left valve of the two on drivers side .......... ANY HELP WOULD B GREATLY APPRECIATED ......
Thursday, June 24, 2010 - 08:12 pm, by: Joshua Baldwin(Celsior101)
is your air sus computer giving any error codes? also try un plugging your height controller and see what happens when the height controller is disconnected, it could be the height controller playing up, my old one did.
Saturday, June 26, 2010 - 05:27 pm, by: Ryan Castle(Pzest8)
THANX HEAPS FOR YOUR SUGGESTION !!!!!! good to c someone on this site is willing to help out a newby in desperate need of some help...... i have tried disconnecting the height controller and no luck. and there is no error codes coming up...
Thursday, July 08, 2010 - 03:25 pm, by: Maclean Cherry(Maclean_cherry)
Put the car in diagnostic mode and check for codes. If nothing comes up then try disconnecting your battery negative for 5 minutes and then reconnecting it.
Mine does this every couple of months and disconnecting the battery solves it.
Thursday, July 08, 2010 - 06:49 pm, by: Rich O'neil(Kiwiinaus)
You need to check that you haven't broken the unit that measure's the height , turn off the air sus take the wheel off and have a look for that unit , it has an arm that goes to it from the lower strut and with the wheel off you will easily see it . This could be why it's not re-adjusting correctly after a reset .
