  Soarer Central * Celsior Chat * Suspension woes Previous Previous    Next Next
Lloyd Montague
tas
1uzfe
Reg: 04-2009
Monday, January 24, 2011 - 03:07 pm, by:  Lloyd Montague (Vip400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok so i have left my old man incharge of getting my car registered because its two states away. he has jacked the front up to put new brake pads in it. when he has put it back on the ground the front suspension has dropped to the ground. it wont pump up with standard high low or either of my height controlers. he took one of the struts out to see if it had burst, it hadnt. it still holds air. any ideas
cheers, lloyd
p.s sorry i dont have a shift button1111
Joshua Baldwin
1990 ucf11 c+f celsior. 1991 uzz31 toyota soarer
Reg: 10-2009
Monday, January 24, 2011 - 05:19 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
make sure the switch is on in the boot. then turn car on with switch on hi and tems on normal and wait.
the switch in the boot is for when the car is jacked up or hoisted etc. so the air bags don't de pressurise.
Robert Timson
Celsior
Reg: 05-2008
Monday, January 24, 2011 - 08:45 pm, by:  Robert Timson (Rjet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You could also disconnect the battery for 15 minutes then re connect which will place the computers back to standard settings.
Lloyd Montague
tas
1uzfe
Reg: 04-2009
Monday, January 31, 2011 - 02:52 pm, by:  Lloyd Montague (Vip400) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well no luck. i guess i'm after a set of front struts
Vincent Chan
v8
Reg: 12-2010
Tuesday, February 01, 2011 - 09:15 am, by:  Vincent Chan (Vincent191) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jack the front wheels up slightly with the suspension switch in the boot switched ON. After a few minutes you should see the wheels coming down and touching the ground again. You should hear the air pump working. The noise should be coming from the driver side front fender.
If you hear nothing and the wheels don't come down then the chances are your air pimp is not working. It may not be your struts, they are bloody expensive to replace.
Don't jack the wheels up too high, just off the ground will do.
