  Soarer Central * Celsior Chat * Rear View Demister Not Working Previous Previous    Next Next
Denham Melder
Reg: 01-2006
Thursday, June 29, 2006 - 08:45 am, by:  Denham Melder (Inasnt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My drivers side rear view demister doesent seem to be working.
Thinking it couldnt be a fuse otherwise either wouldnt work. Can I swap over the demister part from another celsior or soarer or will I need to source a replacement drivers side mirror?
Steve Petkos
Celsior V8
Thursday, June 29, 2006 - 09:15 am, by:  Steve Petkos (Vipimp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my one doesn't either, im guessing it is because they have to be changed when they are complied.
Denham Melder
Reg: 01-2006
Thursday, June 29, 2006 - 02:30 pm, by:  Denham Melder (Inasnt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Damn just found that out also. I was looking to replace it with another celsior one but apparently most of them get damaged when removed
Charles Landwehr
Celsior UCF11 and AE111 Levin
Friday, June 30, 2006 - 07:55 pm, by:  Charles Landwehr (Chucklandwehr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That really sucks guys. My Celsior compliance work was done by me. I had a glazier friend cut me some flat mirrors. When I stuck them onto the existing mirror with double sided tape, I made sure there was contact, glass to glass at the centre. The vibration still works to clear the mirror. A little slower than the convex mirror, but it still works effectively.
cheers Chuck.
Sam Ferguson
Celsior
Saturday, July 01, 2006 - 02:40 pm, by:  Sam Ferguson (Lexrsk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
did not even have to replace to mirror when i got mine complied
