  Soarer Central * Celsior Chat * TRC problem!! Previous Previous    Next Next
Tim Zhao
Celsior!!!
Tuesday, September 12, 2006 - 05:22 pm, by:  Tim Zhao (Key) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi, My TRC indicator light is on all the time since last week! any one got this problem before? why? Thanks..
Steve Petkos
Celsior V8
Tuesday, September 12, 2006 - 09:55 pm, by:  Steve Petkos (Vipimp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
......errr, stop lighting em' up....that was my issue.
Yours maybe different
Tom Richards
Tuesday, September 26, 2006 - 05:12 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
try filling the brake master cylinder to slightly over max.
Sam Ferguson
Celsior
Tuesday, September 26, 2006 - 06:58 pm, by:  Sam Ferguson (Lexrsk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
using the diagnostic plug under the dash jump pin's Tc & E1 with the ignition on read the code (number of times that the TRC light flashes) then send me a PM and i will look up the code and advise where you should start looking.
Tim Zhao
Celsior!!!
Friday, September 29, 2006 - 07:26 pm, by:  Tim Zhao (Key) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the advice, i will try during the weekend.
