Wednesday, September 13, 2006 - 07:46 am, by: Rich O'neil(Kiwiinaus)
Completely awesome !! Got them yesterday and the whole top section [ 75 mm deep ] is billet alloy , no top rubber section to eventually deteriorate and leak , even the TEMS motor drive bracket is alloy billet . Extremely well made , certainly not a backyard 5 second job , very impressed . Fitted them last night , everything lined up like it should . The road test was even better than I imagined , even when I first got the car i used to run the TEMS on hard , it's now the same with the TEMS on the standard setting . the airbags seem even more responsive !! Worth every cent as they are a better unit than even new Lexus struts and they are rebuildable which the genuine units are not .
Wednesday, September 13, 2006 - 07:59 pm, by: Rich O'neil(Kiwiinaus)
Price Neil was Aus $1300.00 total for two delivered to my door ,BUT don't import anything secondhand or not , with a value of over Aus $1000 otherwise you will get slugged with $299.55 import duty !! Eevn through it will add $48.00 to the freight cost get them in seperatly to avoid the CUSTOM'S MAN !!....A...Holes !!
Wednesday, September 13, 2006 - 09:04 pm, by: Rich O'neil(Kiwiinaus)
Neil I had blown both airbags on my Celsior , I fitted a borrowed unit from a mate who had bought a Celsior about 5 years ago , way before most knew what a Celsior was !! Anyhow it came with the struts still in and the dash , try that now !! When my right unit also went I bought one for $150.00 in a hurry and it had " R " stamped on the top , this was because the air inlet was a few degrees off center so therefore it must have a left and a right , I was still able to fit it , just had to grind the hole in the strut tower a bit bigger , Celsior struts have the air inlet dead centre , so there is no left and right and as such nothing is stamped on the top , my point is that that strut came out of either a Soarer or a Crown [ I can't know that ]which means that if it came out of a Soarer then you will be able to fit a Celsior unit in your Soarer , the only difference being in the location of the air hole and that can easily be fixed by fitting a 90 degree fitting straight in the strut and using a common old brass air line hose joiner to extend the length of the hose , I already have one in my right hand line....no probs !! If you need some more info send me an E-mail and I'll send you my number .
Wednesday, September 13, 2006 - 10:08 pm, by: Neil Griffiths(Aussiesc)
Rich, I'm asking these questions mate so other people can look on and take note.This will be a cheaper option for them if they relise it..hahahah Thanks for all your input mate,
