  Soarer Central * Celsior Chat * Uneven Celsior Previous Previous    Next Next
Andrew Ferres
Cressida V8
Thursday, September 14, 2006 - 09:14 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a Celsior here, and the left side is 1-2" lower than the right side.
Put the car on HIGH and the whole car goes up, uneven but by the same amount each side.
Put the car on NORM and the suspension controller on lowest setting, and the whole car goes really low, but still with the left side lower.
I'm thinking that the guys that installed the controller mixed it up and lowered the left and didn't reset it.
Is there any way I can reset the suspension to full height/level?
Or am I looking at 2 faulty/blown bags on the left?
David Cassells
TT Soarer \ V8 Celsior
Sunday, September 17, 2006 - 08:45 am, by:  David Cassells (Davetoyostar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The high Sensor rods are probably uneven. Or the Sus Controller is incorrectly set.
Andrew Ferres
Cressida V8
Sunday, September 17, 2006 - 09:57 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any idea on how to reset it?
Is it an identical setup to the UZZ31 ?
David Cassells
Sunday, September 17, 2006 - 07:52 pm, by:  David Cassells (Davetoyostar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what controller are you using?
Andrew Ferres
Cressida V8
Monday, September 18, 2006 - 09:41 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
AERO AS165X according to the unit.
http://bag01pr000.ac.yahoo.co.jp/users/6/3/0/0/ooiiau4520-imgbatch_1150253339/600x450-2006061400077. jpg
http://bag01pr000.ac.yahoo.co.jp/users/6/3/0/0/ooiiau4520-imgbatch_1150253339/600x450-2006061400078. jpg
http://bag01pr000.ac.yahoo.co.jp/users/6/3/0/0/ooiiau4520-imgbatch_1150253339/600x450-2006061400079. jpg
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Tuesday, November 03, 2009 - 09:16 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im having the same problem as well but the left side is the higher side i have a controller hooked up and have fiddled with everything to do with the controller and suspension ecu and just cant work it out
David Barnes
Celsior V8
Reg: 06-2008
Sunday, November 08, 2009 - 01:32 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well technically you cant adjust the rear left and right separate, on the fronts. Unplug your controller and see if everything goes back to normal.
David Barnes
Celsior V8
Reg: 06-2008
Sunday, November 08, 2009 - 01:34 pm, by:  David Barnes (Toyota_celsior) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What the, I just noticed how old this post is.
Josh - Try not to bring up old threads from the past, normal newbie mistake haha.
Sunday, November 08, 2009 - 08:26 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't see any problems with reviving old threads when it's relevant.
Dave Rose
wa
uzz31 v8
Sunday, November 08, 2009 - 10:38 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Joshua use the "search " button , there is a lot of write ups on how to adjust the 4 rods and set up with a controller .
Joshua Baldwin
ucf-11 1uz-fe v8
Reg: 10-2009
Monday, November 09, 2009 - 05:04 pm, by:  Joshua Baldwin (Celsior101) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok will do thanks mate
