  SoarerCentral * Say G'day * All Heart but no brains * Archive through April 12, 2007 Previous Previous    Next Next
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 06:00 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
Well I'm new and hail from Brunei and Sydney. I bought my Active soarer end of 2005. its badged a lexus sc400. I test-drove it once and then decided i had to have it. stock standard jap import, Red with full black leather interior. What was I getting myself into buying an active? I got a great deal on it and really low Kms like less than 15,000 for a '94 car!
thought it was sweet but the suspension caved in as soon as i got the keys in my pocket then the roller coaster began. So it took like 7 months to get the new struts from japan. so no driving the car at all during the wait...then the workshop tried to start the car.
That is where i am now from six months ago. SOMEHOW the ecu was overloaded and it looks like a small fire went off inside the ecu! so up till now no driving the car...
I have been everywhere looking for a replacement but was told my model has a different ecu pinout that is impossible to find a replacement. mid94 to mid 95 and only 43 cars made with it. cant get one new as they stopped production 10yrs ago and fat chance at getting a second hand one with so few around.
I think i have 2 options.
1.get another model v8 ECU and with pinout diagrams do a transplant. getting pinouts has been the sticking point
2.send the ECU with a hole in it to get repaired- but this needs internal wiring diagrams and a real expert to do and probably really expensive too! plus no one can give me internal wiring diagrams either!
Anyone out there that can help?
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 06:25 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
needless to say the biggest drawback is the car being in Brunei with people with no clue.
aaaah!
Dave Rose
wa
uzz31
Saturday, April 07, 2007 - 06:35 pm, by:  Dave Rose (Sand_groper) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Zul
Mate sorry to here this news ....they may have jumped the car to start it!...very unlucky...Zul could you put a pic on showing the pins then we know what to look for....32s are worth the effort
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 06:52 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave,
this is what it looks like..
Rob,
My chassis no is UZZ32-0001839
I'll try my luck on yahoo japan. its the 94-95 models that i was told only with the same pinouts. wish me luck!
cheers.
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 07:02 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
one of the label and denso part no.
rob, how do you navigate on yahoo japan? its all in japanese!
Dave Rose
wa
uzz31
Saturday, April 07, 2007 - 07:24 pm, by:  Dave Rose (Sand_groper) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Zul
I use a disk to translate it ..but cant do any think till i return to work on wed sorry?
have printed it off regards Dave
Gary Nimmo
V8 Supercharged & intercooled
Saturday, April 07, 2007 - 07:45 pm, by:  Gary Nimmo (Gazzasore) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Also lots of info & how to do for your Active on
www.planetsoarer.com
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 07:46 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mate, any help is appreciated. I've been waiting for over 6 months for this, i can wait till wed. haha
cheers,
Zul
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 08:12 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gary,
thanks. I have been on planet soarer its a great knowledge base. saw your profile your ride sounds awesome. when its all running again i plan do mine up too. cheers Zul
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 11:14 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh my god what have i found?
http://page6.auctions.yahoo.co.jp/jp/auction/f53713127
it looks like a connector which might work with my pinout but i have no idea what it will connect to.
anyone have an idea what this is for- can i substitute another ecu with this thing?
Zul Idris
SC400 V8
Saturday, April 07, 2007 - 11:42 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think it just extends the connectors from car to ecu. with female and male ends of same pinout. so no use to me.
Andrew Meiers
Sunday, April 08, 2007 - 08:21 am, by:  Andrew Meiers (Acmtt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes its often called a fields harness, its so you can tap ( cut) into the wires on the connector to run a piggyback computer without touching the original harness. So when you remove the piggyback its as simple as unplugging it, and plugging the original harness directly into the ecu.
Monday, April 09, 2007 - 08:17 am, by:  Benny Gammelmark (Oldfield) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have found this translation page useful when looking at Japanese sites.
Just open in another window and cut and paste the link(s).
http://translate.google.com/translate_t
Zul Idris
SC400 V8
Monday, April 09, 2007 - 01:24 pm, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Neil, hmmm.. interesting option where can you get the harness? and what is the TT (luxo)?
A particular soarer TT luxury model?
Also found a possible 96-97 sc400 ecu from the US. they say it matches pinout. any issues if i get this instead? mine is a jap spec.
:-) I have a Cadillac, and I am allowed on here :-)
Monday, April 09, 2007 - 05:51 pm, by:  Neil Griffiths (Aussiesc) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The US version will be looking for an EGR setup..but this could be removed.It will also have no speed cut and different max rev limit..
I suspect you WILL get a Kligon warning..but it will run all the same.Possably fuel gauge will be wrong.
As for the TT ECU & Harness... I have both :-)
I recommend
www.adaptronic.com.au
Dave Rose
wa
uzz31
Monday, April 09, 2007 - 10:12 pm, by:  Dave Rose (Sand_groper) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Zul
there is a uzz31 ecu on Ebay AUS ..item at AUTOLINK UK $282....???
Dave Rose
wa
uzz31
Monday, April 09, 2007 - 10:29 pm, by:  Dave Rose (Sand_groper) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry Zul on blowing up the picture of ecu it has the wrong pins...
Zul Idris
SC400 V8
Tuesday, April 10, 2007 - 01:34 am, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers Dave, i got excited for a minute there.
Dave Rose
wa
uzz31
Tuesday, April 10, 2007 - 03:17 pm, by:  Dave Rose (Sand_groper) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
zul
this guy may be of some help
..hlemmens@optushome.com.au,...I belive he may be able to repair your ecu .....all the ones i have found have found only have 3 inlets ...it seems as if the 16p is missing??
Zul Idris
SC400 V8
Wednesday, April 11, 2007 - 01:42 am, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Dave,
I emailed Harry a while back- mid march but he never replied. i assumed he was not interested or the email address is a dud= same as above.
so I'm sending it to Damien Ware who said he will look at it. Thanks Damien!
yeah i haven't had much luck with locating another ecu but must keep looking as there is no guarantee that it can be repaired at all.
Dave Rose
wa
uzz31
Wednesday, April 11, 2007 - 10:12 am, by:  Dave Rose (Sand_groper) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
O.K. will keep on looking on J.P. YAHOO ..
Roger Costello
UZZ31 V8 Limited, UZZ32 no 867
Wednesday, April 11, 2007 - 02:01 pm, by:  Roger Costello (Roger) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Zul
If you can get hold of a standard UZZ30/31 ECU from the 94 - 95 period with the same pin-out Damian should be able to swap the processor chip over from your UZZ32 ECU providing the chip survived whatever originally caused the damage. The only difference I'm aware of between UZZ32 and UZZ31 ECU's is the ROM map code stored in the processor chip itself. Supposedly the 32 ECU has some extra low down grunt added at the expense of fuel economy to help compensate for the additional weight of the car and the power used by the suspension pump. A UZZ31 ECU will work fine in a UZZ32. It would possibly be a bit slower off the line but many people have tried the swap both ways successfully.
Looking at the production diary there were thousands of V8 Soarers made that have compatible ECU's to yours so finding one should not be impossible. You could also try MInes and see if they would produce one for you as a a special order. They will re-map an ECU to your specification if you supply it and you could do worse than losing the speed limiter and having the wick turned up a bit. The cost is not outrageous and it would almost certainly perform better than the original ECU fitted to your car.
The different connector and pin-out on the 94 to mid 95 V8's is annoying but not an insurmountable problem. I think it's also worth checking if Toyota can supply a new UZZ31 ECU from the equivalent month to your UZZ32. It could be worse, there were only 12 ECU's made for the mid 95 to 96 UZZ32's and they are a different pin-out again but using the the earlier connectors with sequential injection and 4 oxygen sensors.
Roger
Zul Idris
SC400 V8
Thursday, April 12, 2007 - 01:25 am, by:  Zul Idris (Zman) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Roger,
wow that is a lot of information. thanks.
I have considered the aftermarket ecu but concerned about the rest of the functions like the digital display etc. Would a Mines ecu have that functionality- who knows what else it might not cover? You know i did ask castle hill toyota for the uzz31 ecu but same deal- stopped production.
It's frustrating as i have not found one ecu with the same pinout in the 6 months of looking. actually more has happened in the short while of SC than the other 5 months!
I don't mind having to use another model uzz31 or other year as long as it'll fit there are heaps of those! but how could i get around the fact the pinouts are different?
I do take some comfort in knowing that 43 is better than the 12 haha.
I think if this repair don't work then i'll have to go with Neil's option of TT ecu- harness and piggyback. But i'm still looking
Roger Costello
Thursday, April 12, 2007 - 02:55 am, by:  Roger Costello (Roger) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Zul
The Mines is an OEM Toyota ECU remapped and includes all the standard functionality. Normal changes are different timing and fuel maps along with the speed cut removed and sometimes the RPM limit raised. They are a straight swap with the stock unit but my guess is Mines would need you to supply a UZZ31 ECU with the correct pin-out for them to modify. All the digital displays and diagnostics work as normal on a Mines and yes the digital speedo will not magically develop the ability to read over 200 km/h, It only has a 1 in the display and the digits don't rollover.
Your chances are good of getting a JDM UZZ30/31 ECU of the correct type with Dave and Neil looking as well. If it was me I would be chasing two, one to get the car mobile and the second to do the processor swap or Mines upgrade. A stock ECU should be fairly cheap and you don't want to be experimenting without a spare.
Did you source four new complete suspension struts for your car and have you rebuilt the suspension valve-body?
Regards
Roger
V8 Ltd manual
Thursday, April 12, 2007 - 09:54 am, by:  David Vaughan (Davidv) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a 1994 car with the same pinouts on my ECU. Sending the ECU over here could be done via Neil.
