  Soarer Central * Say G'day * New soarer to the group Previous Previous    Next Next
Luke Cairns
Reg: 12-2007
Monday, December 24, 2007 - 11:05 pm, by:  Luke Cairns (Soarer350) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi my names luke i own a 91 soarer 1jzgte. it started life stock and still looks that way on the outside but under the bonnet i have spent more money than i thought possible. i have a garret gt35/40 turbo on a custom s/s manifold, turbosmart 48mm wastegate with screamer pipe, arias forged pistons, arp rod bolts, mild port and polish on the exhaust side, hybrid 600x300x100 cooler, microtech ecu, oil cooler, trans cooler, built up auto with 3500 stall and stage 2 shift kit, avc-r boost controler, some gauges, full twin 3 inch exhaust with no cat and 2 4 inch mufflers at the rear. thats all i can think of i probably have forgoten somthing but hope to start coming on cruises and meeting some other soarer owners
Brian Kelly
Colorado USA
SC300 5-speed
Reg: 04-2007
Tuesday, December 25, 2007 - 03:35 am, by:  Brian Kelly (Whereswaldo583) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Luke! Sounds like you've got quite the beast there.
I'm dying to see some pics.
Dave Billings
Louisiana
SC 300, 2JZE, 5 Speed
Reg: 06-2007
Thursday, December 27, 2007 - 12:29 pm, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Luke!!
Luke Cairns
Reg: 12-2007
Thursday, December 27, 2007 - 04:25 pm, by:  Luke Cairns (Soarer350) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
tried to upload some photos but it said they were either to big in size or too big in kbs either way i cant really be botherd trying to change them around so they fix so i guess you guys will just have to wait till the next melbourne cruise to see it
Friday, December 28, 2007 - 07:22 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just resize to 800x600 jpeg, it takes about 30 seconds to do in Microsoft Picture Manager or any one of hundreds of other utilities.
Josif Nguyen
Saturday, December 29, 2007 - 08:53 pm, by:  Josif Nguyen (Silversoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds hot! how much power does that thing have with that setup?
Edward Salem
Commodore VP 1993
Reg: 01-2007
Sunday, December 30, 2007 - 11:55 pm, by:  Edward Salem (Sydeward) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
welcome luke
if the images are too big try opening them with MS paint and selecting file > save. saving in paint automatically increases image compression with no noticable loss in quality
Luke Cairns
Soarer Turbo
Reg: 12-2007
Thursday, January 10, 2008 - 07:15 pm, by:  Luke Cairns (Soarer350) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Full dyno tune is on wednesday 16/01/2008 so il have the power figures then and il try and put some pics up when i can be botherd
Luke Cairns
Single Turbo Soarer
Reg: 12-2007
Saturday, January 26, 2008 - 03:44 am, by:  Luke Cairns (Soarer350) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just wanted to update my soarer has just been on the dyno but not without problems proviously with my old gearbox and stally setup i was making 275rwkw on 17psi but was slipping up top now on 25psi i am making 247rwkw with a screwed up stally
I tell you, you can never win
Will update when stally has been fixed
Adrain Parsons
JZZ30 tt
Saturday, January 26, 2008 - 08:29 am, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice power figures there luke, show us some pics!!
Luke Cairns
Single Turbo Soarer
Reg: 12-2007
Monday, January 28, 2008 - 11:39 pm, by:  Luke Cairns (Soarer350) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Finnaly got around to putting some pics up will get better ones later
