Thursday, July 03, 2008 - 10:57 am, by: Don Bagnall(Baggs)
Welcome Jason
If it's got TEMS, it'll be a GTT-L pr luxo-pack.
The mileage (real or imagined) is irrelevant, as it is the condition at time of purchase which REALLY matters. You can fiddle the mileage on anything if ya wanna.
Having said that, it sounds like you've found a good one.
Thursday, July 03, 2008 - 05:15 pm, by: Adrain Parsons(Ace1975)
welcome mate, if i was you i would get the air con looked at before you buy it, when my compressor went i was up for almost $2000 to fix the whole air con system.
Saturday, July 05, 2008 - 10:31 pm, by: Jason Munro(Jason_munro)
picked up the soarer today. it has a few of the usual things that need fixing.
the passenger side door trim is cracked near the speaker, and the central lock motor on the passenger side does not work. (it tries to lock, but fails)
the climate control unit does not light up at night. it works, it just doesn't light up at all.
the lower display on the dash has what looks like two globes that are not working. (each end of the display is a little dim) and the cluster as a whole is a little dim during the day.
also, i think that the TEMS is stuck in hard mode. i drove over 200km home today, and it was rock hard all the way. will have to investigate that.
the headlights are also a little on the yellow side.
