Glenn Connell
Tinkerer Queensland Soarer limited
Posts: 16 Reg: 09-2008
| Hi, How do i stop the dam doors from auto locking, when i'm driving. It is really starting to give me the shts. Glenn |
Goo Roo New Zealand Soarer Limited UZZ31 V8
Posts: 2597 Reg: 11-2005
| They are meant to do it, a wise safety feature. I'm not sure how your would stop it but Im guessing you would pull the fuse for central locking, or disconnect the cable for it in the door panel It would mean you would not have central locking, so have to manually lock both doors went leaving the car. Also in the rare event of a car jacking, some one would be able to open your door with it no longer auto locking!... Just a thought for safety!
Scott Gates
Goo Roo SA TT
Posts: 1121 Reg: 03-2007
| What is so bad about it? It's just a safety feature. I don't think anyone has bothered to try and stop it. |
Glenn Connell
Posts: 17 Reg: 09-2008
| i suppose its a good thing, but i keep forgeting to unlock it and the missus gets left in there.... |
Luke Bell
TryHard NSW JZZ30 GT-TL Manual
Posts: 211 Reg: 04-2006
| The only problem I have with this feature is when I stop and the passenger starts yanking at the door handle, I am worried that someone will break it one day! |
Chris Lock
TryHard sa V8 Limited
Posts: 198 Reg: 03-2008
Glenn Connell wrote on Monday, October 06, 2008 - 07:52 pm:i suppose its a good thing, but i keep forgeting to unlock it and the missus gets left in there....
So what's the issue?? Peace and quiet in the home if she's stuck in the car ;) |
Posts: 10086 Reg: 11-2004
| Mine learnt to undo the lock before pulling the handle. Though occasionally I get it wrong when I am a passenger. |
Joshua Rao
Goo Roo WA JZZ30 vvti GT-L
Posts: 1117 Reg: 09-2006
| those things snap quite easily apparently. Seen it happen |
Goo Roo North Island JZZ31
Posts: 3805 Reg: 10-2005
| Later model Soarers don't seem to do it. Maybe there is a component you could upgrade? |
Will Schultz
TryHard new south wales tt
Posts: 187 Reg: 05-2007
| My 91TT doesn't do it.Never has since i got it.No idea what the previous owner did to stop it though |
Joshua Rao
Posts: 1121 Reg: 09-2006
Matthew Sharpe wrote on Tuesday, October 07, 2008 - 04:55 am:Later model Soarers don't seem to do it.
My 96 has it. My 94 JZZ31 didnt. |
Andrew Ferres
DieHard WA '90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Posts: 939 Reg: 07-2005
Peter Nitschke wrote on Monday, October 06, 2008 - 09:18 pm:Mine learnt to undo the lock before pulling the handle.
Its a mechanism on a lot of Toyota drivers doors that the inside handle simultaneously unlocks and opens the door at the same time. Unfortunately the passengers doesn't do it, but they can always unlock it themselves. I'm not sure about the Soarer, but the Celsior has a lock/unlock button right next to the handle, and also the lock itself is right there. |
Gary Poloskei
TryHard A.C.T JZZ30
Posts: 141 Reg: 01-2008
| this really should be in the GENERAL section or the INTERIOR section as there are already topics on this issue. |
David Grima
Tinkerer WA Twin Turbo
Posts: 36 Reg: 07-2007
| To my knowledge non LIMITED soarers don't lock the doors when you put the car in drive. Only GT-L models do. |
Posts: 3815 Reg: 10-2005
| No, I had a '91 UZZ30 bog standard and it definitely had autolocking. |
Posts: 2607 Reg: 11-2005
| Yep, same here. I think its a poverty pack feature! For them NOT to work |
Goo Roo NSW 94 UZZ31 (V8) / 96 JZZ30 (TT) / 97 JZA80 (TT)
Posts: 2625 Reg: 07-2005
| Nope I don't have it on my GT-TL '96 TT. Then again, mine came with TRC, woodgrain, electric seats, etc. but no LCD rear view mirror and el crapola sun visors? Then again, the Soarer came with about a million combinations of options. Maybe this auto lock was an option? |
Andrew Ferres
Posts: 945 Reg: 07-2005
| Or it could be that a previous owner has disabled it. Its only one wire that needs cutting. |
David Tra
TryHard qld TT
Posts: 215 Reg: 11-2007
| what if you sourced out an american driver side door handle mechanism? would that solve the dilemma of unlocking the passenger side door? |
Andrew Ferres
Posts: 946 Reg: 07-2005
| Good question, do they have the drivers door unlock thing? It might be easier to look at your drivers door and see if its a simple bracket/tab that needs to be installed to get the lock to actuate at the same time as the handle. |
Chris Prak
TryHard WA Soarer GTT-L
Posts: 423 Reg: 12-2006
| My passenger door handle is broken from this scenario. Serves them right, now they can't get out. |
Jason Munro
TryHard NSW Soarer GTT-L
Posts: 190 Reg: 07-2008
| David, i believe that Peter has tried the US spec handle, with no success. the unlock mechanism, might be in the actual lock in the door. not the handle. if you got a us spec drivers side door lock (not just the handle) it might work. just a guess though... Jason. |
Sam Atash
Tinkerer WA UZZ31
Posts: 89 Reg: 06-2008
| I used to get annoyed at it, but then i got my Cyclops Alarm/ immobiliser installed. Now it auto locks, and when i turn the car ignition off, the doors automatically unlock couldnt be happier! |
