very nice mate i luv it got a question which mite sound abit stupid tho but i nevver new soarers came with left hand drives or did you change it??? either way looks HOT man
Monday, November 17, 2008 - 05:02 pm, by: Matt Small(Slow_sc3)
Peter Angelopoulos wrote on Monday, November 17, 2008 - 01:15 pm:
very nice mate i luv it got a question which mite sound a bit stupid tho but i never knew soarers came with left hand drives or did you change it??? either way looks HOT man
thanks its a sc300 came LHD
Peter Nitschke wrote on Monday, November 17, 2008 - 02:00 pm:
USA models - SC300 and SC400, are all left hand drive. These are the only true Lexus badged versions.
Looks good indeed Matt!
thanks yeah america got the 2jz-ge and the 1uz
BTW: if anyone needs anything from america i have access to any part you need just let me know.
Wednesday, November 19, 2008 - 04:11 am, by: Matt Small(Slow_sc3)
Thanks and the rear tire has been fixed.
I am located in Germantown Maryland.
The lag really isnt all that bad 3,80-4,000 im at full boost and im taking the motor all the way to 8,500.
Here's a rundown of the cars current state: Engine: 1.5jz ( new oem usdm 2jz-gte short block ) - new oem toyota oil pump - new timing belt and tensioner - shimmed oil pick up - every gasket replaced - arp head studs - oem toyota head gasket - port and polish head - crowler valve springs - HKS 272/264 cams - adjustable cam gears - T4 exhaust manifold - tial 40mm wastegate - greddy t78-33d - 3 inch down pipe - dual 3 inch exhaust magnaflow tips - all vac hoses are ss - TTE Fuel Rail - 720CC Delphi injectors - veilside replica intake manifold - 80mm throttle body - dual ssqv bov's - 24x12x4 inch front mount - 2.5 inch hot side intercooler piping - 3 inch cold side intercooler piping - Areomotive Feul Pressure Regulator - fuel dampener bypass ( driftmotion ) - reloomed wiring harness looks new - ss power steering reservoir - valve cover bolt replaced with 10mm bolts - tt supra fuel pump - tt supra throttle cable
Drivetrain: - R154 - soarer bell housing - marlin crawler Bearing retainer - marlin crawler thrust washer - new slave cylinder - new clutch master cylinder - new pilot bearing - urethane shifter bushing - spec twin disk clutch - ss clutch line full length
Suspension/Wheels/Rotors: - NEX Full Coilovers - SS Brake lines - 99LS 400 front brake upgrade - drilled/ slotted rear rotors - new pads front and back - 95TT wheels 245/275mm - new front ls rotors - megan adj rear toe - megan adj rear traction bar
Misc stuff done: - bucket racing seats - 4 point harness - 97 front bumper - 97 front grill - 97 new fog lights - working gauge cluster needles - battery relocated to trunk - Mcculloch 6000k HID - 20% window tint. - paint job is about two years old (dark metalic forest green) [6M2] - new trunk struts - VIS carbon fiber hood - Corbuea rear seats
