  Soarer Central * Say G'day * Another soarer newby Previous Previous    Next Next
Daniel Colburt
JZZ30 turbo
Reg: 06-2009
Monday, June 08, 2009 - 11:49 pm, by:  Daniel Colburt (Dcautosport) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
gday all,
im a mechanic on the gold coast, trying to get my head around soarers as i have never touched them before.
i managed to pick up a 93' JZZ30 Soarer in VE purple, R154 converted 5sp., body kit, 20's, with a trust TD07 single turbo kit which doesn't see full boost till 5g (badly needs cams).
i does have a few problems which i have been working through full time since i have had it (2 days) hopefully in the next couple of weeks she should see the higher side of 350rwhp
Dan
Brenton Trafford
V8 Limited - UZZ31
Tuesday, June 09, 2009 - 10:17 am, by:  Brenton Trafford (Traff) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Welcome! Always good to have another mechanic on board.
Sean Routledge
Reg: 07-2008
Tuesday, June 09, 2009 - 04:24 pm, by:  Sean Routledge (Stircrazy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any pics?
GT Starlet
Tuesday, June 09, 2009 - 08:16 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
perhaps just a smaller rear housing brother.. I had a XTR T66 on my Soarer with a T4 .86 rear housing and that was pretty laggy... i changed it to a .69 and it brought boost on a solid 1000RPM earlier, then i adjusted cam gears which helped another 500-750rpm made a hell of a difference.
Welcome to the club mate, get some pics up !
Also dont forget to check out the QLD Events section as cruises get organised there.
Colin Woolford
JZZ30 GT T L
Reg: 06-2009
Wednesday, June 10, 2009 - 07:05 pm, by:  Colin Woolford (Xcwx) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Welcome mate im very new here as well.. I have found out its a good way of learning things from other peoples experience.. Have fun mate .. talk soon .. looking forward to seeing some pics of ya ride..
