Saturday, June 30, 2012 - 11:49 pm, by: Walter Gillmore(Cl33pa)
$100 for Psu delivered $250 lilliput lcd touchscreen delivered. $50 for lcd frame. $60 for case $70 for trim kit (custom brackets made, as supplied brackets are for sc300 US left hand drive market)
Sunday, July 01, 2012 - 01:17 am, by: Walter Gillmore(Cl33pa)
yeah, you can order all the bits yourself. but you'll still have to send them to me to fit as the screen mounts need some work and the lcd has to be mounted to the case plus the custom radio/ climate control brackets. depending on the lcd you order, the case will have to be modified to suit the driver board of the lcd. lots of little tweaks to get it to sit factory flush.
Monday, July 29, 2013 - 06:09 pm, by: Walter Gillmore(Cl33pa)
its been a very long while since ive visited this page. heres more of an update of what ive been doing. suprastick got sent away for an upgrade. also new patch harness as i now do not run an EMB and extended loom on suprastick
Custom 2.5mm aluminium airbox with dress bolts and rubber seals
4 inch intake pipe for single turbo conversion with idle air and rocker breather pipe bits.
single gt3540 copy on ebay manifold modded to fit 46mm wastegate and custom 3 inch dump with wastegate merge
Tuesday, July 30, 2013 - 07:56 pm, by: Walter Gillmore(Cl33pa)
was very slack with it and no progress for over 6 months while gathering bits. did most of the work in the last few weeks as i got a kick up the bum with the suby wagon running out of rego. lol
Wednesday, April 30, 2014 - 11:43 pm, by: Walter Gillmore(Cl33pa)
Bit of an update. Purchased powerfc. 650 injectors and staggered hks cams car runs sweet as atm. Also fitted new ally radiator. Ebay turbo and wastegate and manifold showing no signs of typical crapness.
Thursday, May 08, 2014 - 11:11 pm, by: Casey Perkins(Caseyp)
Car sounds great, may I ask where you got the mufflers? I think I have decided on a twin 3" system including xforce mufflers, they look quite similar is all
