  Soarer Central * Say G'day * NATASHA'S SOARER PICTURES! Previous Previous    Next Next
Open in new windowArchive through February 26, 2010Matthew Weaver30
Open in new windowArchive through March 03, 2010Peter Nitschke30
Open in new windowArchive through April 02, 2010Ben Lipman30
Haydn Crandell
TT 2.5
Friday, April 02, 2010 - 03:05 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben Lipman wrote on Friday, April 02, 2010 - 02:05 pm:
Friday, April 02, 2010 - 01:21 pm, by: Mike Beck (Gold_40gt)
Matthew Sharpe wrote on Friday, April 02, 2010 - 09:49 am:
My current Soarer definitely doesn't have a clear coat (wine red mica) and is quite shiney.
Are you sure?
of course he is sure ,he just said he has know idea about professional painting lol
Matthew Weaver
Reg: 01-2010
Friday, April 02, 2010 - 04:15 pm, by:  Matthew Weaver (Spinna) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah i know what you mean my rear side is peeling and on the boot is peeling so i got to respray it. Makes the car look sh*t :-(
Natasha D'Abreo
Reg: 10-2009
Sunday, April 04, 2010 - 03:26 pm, by:  Natasha D'Abreo (Natashad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matt, I finally cleaned my headlights with my sister. First I tried the soapie steel wool pads, and it stayed clear for about 5mins then went back to the normal colour. Then today we tried the stuff you gave me and It actually worked abit, its probably 3shades clearer than before, its still got a slight yellow tinge but, it worked. I followed the intructions step by step. Thankyou so much for the stuff!
Matthew Weaver
Reg: 01-2010
Sunday, April 04, 2010 - 04:19 pm, by:  Matthew Weaver (Spinna) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oh yeah i've just got plast X and that's work great so if you want to get the yellow tinge and make it clean give me a yell ok natasha cheers
Monday, April 05, 2010 - 01:39 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, I was pretty sure, I watched them paint it and never saw a untinted shoot (must have just not been there when it was done I guess), the scratches on it do appear to be directly into the colour unlike scratched on my UZZ30, and the oxidization on the rear spoiler doesn't look anything like what the oxidization on my UZZ30 was like, which lifted the clearcoat on the front bar (different symptoms of a different problem perhaps?)
However clearly I'm wrong and just don't know what I'm looking at.
I'm not going to argue with an expert!
Chris Prak
JZZ30 Soarer - Twin Snails
Reg: 12-2006
Monday, April 05, 2010 - 05:00 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys, its a cutting compound I use at work all the time to remove the dirt or grainy texture in clear coats. It does not burn the paint or leave swirls, but designed to remove deeper scratches or inconsistency in the clear.
And yes, all cars have clear whether it's satin, semi or gloss, otherwise you'd get oxidation over the years and paint will fade/peel.
You wouldn't cut anything besides 2pack because the others have no hardener in paint mixtures.
Haydn Crandell
TT 2.5
Monday, April 05, 2010 - 07:46 pm, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Sharpe wrote on Monday, April 05, 2010 - 01:39 pm:
clear coat is usually applied 20-30 minutes after the colour
the oxidization was probably older then the other car mabe, some are differant, some are just faded bad, and others start to show signs of peeling . bit like sunburn blisters.
see this pic? you can buff this up to a high gloss but it will always come back.
Natasha D'Abreo
Reg: 10-2009
Monday, April 05, 2010 - 07:58 pm, by:  Natasha D'Abreo (Natashad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My dads 200sx paint has all white patches on the bonnet and boot and roof and he tried to use some special wax the dude at autobarn gave and It didnt work at all. I should put pics up its quite bad.
Haydn Crandell
TT 2.5
Tuesday, April 06, 2010 - 11:48 am, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wax no good, you need cutting compound on a machine buff
Haydn Crandell
TT 2.5
Tuesday, April 06, 2010 - 11:49 am, by:  Haydn Crandell (Haydn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris Prak wrote on Monday, April 05, 2010 - 05:00 pm:
you can still buff Acrylic no problems
