  Soarer Central * Say G'day * New reader, First poster - Hi from Tasmania! Previous Previous    Next Next
Open in new windowArchive through July 26, 2010Daniel Lee30
Open in new windowArchive through October 18, 2010Ron Bassett29
James Buchan
Reg: 10-2008
Monday, October 18, 2010 - 06:14 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Re the airbag light, did you put the keys in the ignition whilst the dash was out. That can be what triggers the airbag light to come on.
Often best if you're going to take the dash out is to take the battery out, put keys where you won't be tempted to put them in the ignition. I don't know how to remove the airbag light, but apparently it's a real pain.
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Monday, October 18, 2010 - 06:17 pm, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ron, I know Scott and have his contact details, he's just a very very busy man.
James: No I didn't, I presumed the previous owner did. I trued to clearance of it, but it didn't work. (Did it all right bar the bastard actually going away! :-)).
I don't know why I took it to the place with the light on anyway.
Edit: The light is surprisingly easy. Find it here: http://www.planetsoarer.com/dashrepair/dashrepair.htm (Scroll to bottom)
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Monday, October 18, 2010 - 07:12 pm, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Which other site?
Boostcruising? Toyotas?
Scott Wilkes
Tasmania
92 TT Factory Manual, 70 HG GTS Monaro
Reg: 10-2008
Monday, October 18, 2010 - 09:44 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
pm bro
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Monday, October 18, 2010 - 09:53 pm, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Done :-)
For those interested:
http://soarercentral.com/sc-forum/messages/30604/328838.html?1287400788
Time to do more work! :-)
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Thursday, November 04, 2010 - 01:41 pm, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This project is still ongoing unfortunately :-(
Went home at lunch and as I wasn't hungry decided to try and get the struts out so they could be re gassed.
Got the left hand side bonnet fine at the bottom (Unscrewed with a 12mm spanner) but couldnt for the life of me get the top. All I ended up doing was starting to strip it.. Same story for the top and bottom on the right.
The boot ones came out fine though.
Any tips? Just hit with 20kg of WD40 or?
I also started up the car and gave it a little rev to keep it from getting 'stale' and I noticed it doesnt back off from high RPM very well and I THINK I can hear a slight hiss 0.5 Seconds after I let off the acelerator. Anything to worry about? I may have to take a vid to show.
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Thursday, November 04, 2010 - 09:45 pm, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Got all of the struts off now bar the passenger bonnet side, so frustrating!!
Friday, November 05, 2010 - 06:22 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try some heat.
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Friday, November 05, 2010 - 08:37 am, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Someone did mention an oxy torch.
Would this damage the strut though?
Saturday, November 06, 2010 - 08:14 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not if you don't let it get too hot - you don't want to make it glow.
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Monday, November 15, 2010 - 12:04 pm, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Doesn't seem like an easy option still, I don't want to burn off my paint!
I have made a thread about it anyway.
Apparently I can just pop the strut off anyway?
Without undoing it from the car.
Tuesday, November 16, 2010 - 05:51 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dunno about the bonnet struts, mine are both like new so I've never had any reason to take them off. You have to undo the nut on the boot struts though.
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Tuesday, November 16, 2010 - 08:27 am, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, took some pictures of them too. You have to undo it for sure.
The boot ones came off so easy :-(
Chris Smith
Tasmania
Soarer UZZ31 V8
Reg: 07-2010
Tuesday, November 23, 2010 - 08:59 pm, by:  Chris Smith (Smithter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well the soarer is finally rego'd!!!
Filled it up for the first time tonight... $90 later :-(
