owner of pearl white 1992 soarer for close to seven years in that time clocked up only 50,000 klms,I replaced battery ,cam and crank sensors ,plugs and leads,air filters ,fuel filters,rear brake pads,rear springs,radiator hoses,cam belt water pump and pulley bearings plus a few other things like MAS ,idle sensor ,thermostat, this coupe was a up date from a 1964 EH holden I had for 33 1/2 years and with parts off ebay and a little CD work shop manuel except for wheel alinements have done all the work by myself that included the hundred thousand service, the reason I back have a look now is my analyzer says the fuel pressure regulator is giving some problem at the moment and I am looking to see if anyone had a fix for this p0001 situation, cheers Patrick.
