  Soarer Central * Mechanical - TT * General Mechanical * Clutch Fan information. Previous Previous    Next Next
Tate Clinton
Monday, January 08, 2007 - 03:36 pm, by:  Tate Clinton (Tek) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm in need of a new clutch fan for my TT. What options do I have?
I read that the clutch on the 1JZ-GTE is interchangable with the 2JZ-GTE. But I have a feeling that those parts will be pretty expensive to buy straight from Toyota. Is there any aftermarket clutch fans that will bolt in? Or does anyone know the sizes/specs of it - so I could look for one?
Also, if anyone has a clutch fan that they are selling can they please contact me? I don't need the fan blades, just the clutch. I don't really wanna put second hand parts in, but if the price is right then it may be the best option.
Thanks
Monday, January 08, 2007 - 03:48 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tate, The 2JZ-GTE has a different part number to the 1JZ-GTE, so dunno whether it'll fit
The 1JZ-GTE one is part number: 16210 - 88400 (5/1991 - 8/1996)
Tate Clinton
Monday, January 08, 2007 - 05:05 pm, by:  Tate Clinton (Tek) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Don.
I've recieved a quote for a brand new fan clutch for the 1JZ-GTE (using the part number listed above). It's pricey. So if anyone can tell me wether the 2JZ-GTE fan clutch can be used it would be really appreciated, seeing as finding second hand ones from that engine is a bit easier.
Usman Naeem
JZA80
Reg: 10-2006
Monday, January 08, 2007 - 05:22 pm, by:  Usman Naeem (Osman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i am sure they are interchangeable
Usman Naeem
JZA80
Reg: 10-2006
Monday, January 08, 2007 - 05:27 pm, by:  Usman Naeem (Osman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
brand new ones are like $550 from castle hill toyota, i was in the same spot when i wanted one, went to the wreckers they wanted like 250 for it ...
and then i bought thermo fan and a switch it ended up costing me 150
Grant Rowan
jzz30 TT
Monday, January 08, 2007 - 05:52 pm, by:  Grant Rowan (Booster13psi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have used a 2jz-gte fan clutch on my 1jz-gte. All I had to do was swap over the fan blades. As the 2j ones hit the radiator shroud.
Tate Clinton
Wednesday, January 10, 2007 - 11:21 am, by:  Tate Clinton (Tek) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've had a few people tell me that it may just be the viscous oil inside the clutch that needs replacing. My mechanic said that he wouldn't do that for me and I'm a bit weary of doing it myself - anyone know how hard it is for a n00b?
Anyway, if it's too much of a challenge I'll just go with the second hand 2JZ-GTE hub onto my existing fan. Thanks a lot for the info - hopefully it will help others if they encounter the same problem down the track.
Tate Clinton
Monday, January 22, 2007 - 09:45 pm, by:  Tate Clinton (Tek) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hmm... alright, I have a new one.
I've put new oils into my clutch fan, and it didn't seem to have much of an effect. Because I thought I may have done it wrong, I went and bought a second hand part, and chucked that in - still got the same problem. I'm pretty sure the bearings on the clutch are good because it spins nicely. So i'm thinking maybe this isn't the problem?
My car still overheats in stop-start traffic. After about 15mins of city driving the coolant will be boiling and steaming out of the overflow tank. Can anyone else think of what the problem could be? It's not a coolant leak, but maybe a blockage somewhere... but where do i look? Or any comments are more than welcome!
Thanks again for the help.
Monday, January 22, 2007 - 09:53 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Radiator?
Tuesday, January 23, 2007 - 08:00 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Blocked radiator, stuck thermostat, leaking head gasket. Pick one (hopefully not all three!)
Harry Doling
Soarer GTT
Reg: 06-2012
Tuesday, November 20, 2012 - 05:06 pm, by:  Harry Doling (Harryjzz30) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry for the thread mine, but this is the closest info I could find by searching...
I just did my 100,000km service - timing belt, tensioner, pulley, cam & crank seals, water pump, hoses, balancer, drive belt and idler bearing. But I discovered I also need a new viscous hub for the fan which has a noisey bearing. I can't find one aftermarket for the JZZ30 and Toyota want $734!!! (Part No 16210-88400). Can anyone confirm Grant's info above that the 2JZ-GTE hub fits? Must be from JZA80 Supra because Aristo had a hydraulic setup... I can source them aftermarket for about $150. Just a bit of a gamble based on one reference on the interwebs... Might have to go thermos rather than risk wasting money on the wrong part.
Tuesday, November 20, 2012 - 06:54 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Noisy bearing ? Bearing noise would be water pump or pulley noise elsewhere IMO .
When the clutch fan starts failing , it locks up and doesn't disengage when revved , very noisy fan wash sound .
Harry Doling
Soarer GTT
Reg: 06-2012
Thursday, November 22, 2012 - 09:01 am, by:  Harry Doling (Harryjzz30) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
we've tested it and its definitely the bearing in the fan hub, not the brand new GMB water pump or the brand new tensioner pulley bearing.
has anyone here ever replaced their fan hub?
