  Soarer Central * Mechanical - TT * General Mechanical * Stock BOV sound Previous Previous    Next Next
Luke Nieuwhof
Thursday, September 22, 2005 - 10:58 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Myself and another Soarer owner were at the drags last night and I noticed I could hear his BOV from the stands. I had a look under the bonnet and he has a stock BOV. Mine is also stock but it makes no where near the noise his does. Mine is a flutter at best that can barely be heard over the engine.
Any ideas what would affect the amount of noise made on a stock BOV?
Brad Elphinstone
JZZ30 GT-T
Friday, September 23, 2005 - 08:39 am, by:  Brad Elphinstone (Belphins) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does your mate have a pod filter? If so, more than likely that's what you were hearing.
Gary Morriss
2.5 TT
Friday, September 23, 2005 - 09:50 am, by:  Gary Morriss (Gaza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If its a standard air box,has he cut the baffels out ?
That works.
Paul Mazza
N.S.W
Friday, September 23, 2005 - 02:11 pm, by:  Paul Mazza (Paul2211) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had the stock BOV and a pod filter and it used to make a loud flutter sound, so that may be what you heared.
Simon Triantafillou
Soarer Turbo
Friday, September 23, 2005 - 02:45 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
He might have a second BOV somewhere else along the piping. Seen that done before.
Black/Black JZZ30 VVTi
Friday, September 23, 2005 - 03:36 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's what I used to have as well (the stock BOV still in place but everything venting through a Blitz BOV).
Robert Davies
qld
both
Friday, September 23, 2005 - 03:51 pm, by:  Robert Davies (Blueone) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cool, i want it to sound like a pigeon taking flight!!
Taranaki
Friday, September 23, 2005 - 05:00 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
EXCELLENT!........buy a pigeon, and install
Shane McInnes
Friday, September 23, 2005 - 05:15 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hard to get that sound Robert...that fluttering sound you here is the actuall turbos back spinning which defientley isnt good. unless there is a BOV out there that specifically makes that noise.
Cause ive always been told its the turbos back spinning?? people usually think its the wastegate but its not.
Brad Elphinstone
JZZ30 GT-T
Friday, September 23, 2005 - 06:18 pm, by:  Brad Elphinstone (Belphins) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Or a disturbed pigeon.
JZZ30 Twin Turbo
Friday, September 23, 2005 - 06:32 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I tried disconnecting the stock blow off valve recirculation piping and blocking the hole that leads to the intake of the compressors/towards the airbox, and it doesnt blow off at all?
I think my stock BOV is fubared?
Luke Nieuwhof
Friday, September 23, 2005 - 07:32 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
He did have a pod so maybe that was it, was a hell of a lot louder though.
Friday, September 23, 2005 - 07:52 pm, by:  Morgan Cross (Morgan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Or a boost leak.
Freeman Tang
JZZ30 GT-TL
Friday, September 23, 2005 - 10:48 pm, by:  Freeman Tang (Cobra_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah a pod makes it really loud!! stock air box is designed to reduce induction noises eg. bov noise and sucking noise, get a pod if u want a louder bov noise, cheaper than getting a aftermarket BOV.
Wayne Koh
G-TT
Saturday, September 24, 2005 - 01:05 am, by:  Wayne Koh (Teknoboi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hehe that was my car :-)
yeh i think its the pod
when it sucks up air it vibrates the pod and the filter thingies?
Shane McInnes
Saturday, September 24, 2005 - 11:30 am, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When my stock BOV was connected with pod filter it wasnt that loud at all. it made enough noise so you could here it but yeah the aftermarket bov i have on there now is much louder than the pod.
Liam Swan
Saturday, September 24, 2005 - 04:37 pm, by:  Liam Swan (Liampire) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
aftermarket BOV is just pure wank factor
Shane McInnes
Saturday, September 24, 2005 - 05:09 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Unless your boost is set high, cause then the stock BOV leaks so ive been told?
Freeman Tang
JZZ30 GT-TL
Saturday, September 24, 2005 - 09:50 pm, by:  Freeman Tang (Cobra_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i think so ! but more of a canary factor to me! hate cops pull ya ova for that, whereas all those motorbikes eg. Harlies, hammering around everywhere and their catastrophic noise level is legal??
Melbourne
Sunday, September 25, 2005 - 12:38 am, by:  Morgan Cross (Morgan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
IF you get a sequential bov the sound will throw coppers off a bit :-)
Just tell them you don't have a bov, that is the noise they are hearing, tell them it's compressor surge and the noise they can hear is your turbo blades falling apart.
Peter Keen
Sunday, September 25, 2005 - 07:56 pm, by:  Peter Keen (Slaughter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
lol! you want flutter/compressor surge? why would u want that?
i was the same when i first brought mine though!
just go get a fmic,stainless piping and a decent pod filter! then youll hear your compressor surge more!!!! im told all these can contribute to making it a lot louder!
James Linton
W.A
TT 1JZ-GTE
Reg: 03-2008
Saturday, January 03, 2009 - 06:15 pm, by:  James Linton (Jameslinton50) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
compressor surge comes naturely with a turbo car it dosent mess up turbos that much unless running silly amounts of boost like 15.....20psi then u will buck turbos
