Thread |
Last Poster |
Posts |
Pages |
| Factory manual overboosting | Chris Koszo | 3 | 1 |
| Ct12 rebuild help | Christopher Hosking | 1 | 1 |
| Ct20s kit for 1j soarer. | Kurt Atzmuller | 38 | 2 |
| Starting my compound turbo setup! | Kurt Atzmuller | 91 | 4 |
| Twin ct20's custom project | Kurt Atzmuller | 13 | 1 |
| Air leak | Darren Bak | 1 | 1 |
| Forward Facing Rear CT12A | Casey Perkins | 17 | 1 |
| Turbo wheel dimensions comparison. | Tai Johnsen | 1 | 1 |
| Turbo max psi | Scott Vim | 16 | 1 |
| Vvti turbo oil leak | Scott Vim | 6 | 1 |
| Hey guys who do you think like of this?? Air intake?? | Boris Siljanoski | 4 | 1 |
| VVti turbo on its way out?? | Peter Nitschke | 6 | 1 |
| 1JZ Cast Iron Single Turbo Manifold | Camron Garcia | 4 | 1 |
| Air whoosh when turbo kicks in - limited boost. Help please. | Nathan Sopeer | 4 | 1 |
| Lol could this be real? | Scott Vim | 3 | 1 |
| Internal or external waste gate | Casey Perkins | 2 | 1 |
| Possible dump pipe Manufacturer | Jeff Bedsor | 118 | 5 |
| Need help installing blitz turbo timer | Crystal Moss | 2 | 1 |
| Single turbo question, ECU | Boris Siljanoski | 13 | 1 |
| My TT's engine is running very flat but no smoke. Could it still be... | Trevor Marsh | 11 | 1 |
| Turbo setups for 1.5j... | Kurt Atzmuller | 39 | 2 |
| CT12B's on a 1JZ | Blake Gloyn | 10 | 1 |
| More power | Tai Johnsen | 7 | 1 |
| HyperGears billet SS2 Roller bearing VNT turbocharger | Tao Shangguan | 26 | 1 |
| External Wastegate Fluctuating Open Early | Kurt Atzmuller | 17 | 1 |
| Don't ask | Matt Newman | 8 | 1 |
| Not sure on what size wastegate to use | Jay Asghari | 4 | 1 |
| Spool Issue | Glenn Munro | 2 | 1 |
| Turbo on its way out | Daniel Clarke | 2 | 1 |
| Whats really wrong with the GTX3076R? | Ali Saeed | 25 | 1 |
| Fuel cut defender | Zac Clare | 8 | 1 |
| Cracked CT12a Turbo Housing??? | Glenn Munro | 2 | 1 |
| Aftermark Oil Feed / Return kits | Walter Gillmore | 9 | 1 |
| Manual boost controller question | Zac Clare | 11 | 1 |
| Some Single Turbo Help! | Ezekiel Vozzo | 18 | 1 |
| Only 5 psi stock tt | Adam Day | 10 | 1 |
| DD turbochargers | Ross Pesina | 3 | 1 |
| First upgrade? G-Force II | Ethan Rodda | 8 | 1 |
| HELP coolant lines on turbo side | Peter Nitschke | 2 | 1 |
| 1.5j t3gs with gt2860rs cores results | Tony Nguyen | 18 | 1 |
| Best single turbo for 300 - 350 rwkw | James Tims | 55 | 3 |
| Stock Ct12a's, 16psi, stock injectors/pump, FCD, SAFC 2, recipe for... | Boris Siljanoski | 6 | 1 |
| Single turbo kit | Tai Johnsen | 4 | 1 |
| Water lines feed and return | Johnny Brasche | 8 | 1 |
| Going to up my boost soon | Robert Day | 17 | 1 |
| Precison 6262 Dyno results | Robbie Rashleigh | 17 | 1 |
| CT12a 1JZGTE High flow. Bit fancier then just steel wheel. | Tao Shangguan | 5 | 1 |
| Stock BOV | Weisong Zhang | 23 | 1 |
| Notice turbo question | Julian Mazur | 12 | 1 |
| Rebuilt turbos? | Jamie Deakin | 6 | 1 |
| Once Again! Turbo replacement | Daniel Clarke | 16 | 1 |
| Still over boosting | Matthew Weaver | 8 | 1 |
| BOV question/help | Daniel Clarke | 8 | 1 |
| Baided turbo coolant lines? | Layton Molenaar | 2 | 1 |
| ASK CIHAN : build tips | Blake Gloyn | 31 | 2 |
| GT3582r worth it on the 1jz? | Daniel Clarke | 28 | 1 |
| Ct12a rebuild time need info | Daniel Clarke | 3 | 1 |
| Boosting issues | Matthew Weaver | 4 | 1 |
| Turbo help needed | Sanjeewa Jayasekara | 16 | 1 |
| Budget single turbo conversion | Michael Sinay | 26 | 1 |
| T3G rebuild options / questions | Sebastian Grant | 28 | 1 |
| E85 / LPG 1jz TO4Z build | Allan Langford | 28 | 1 |
| Greddy Profec B Spec 2 - Not Holding Boost at any level | James Tims | 18 | 1 |
| Turbo smart fuel cut defender 2 | Blake Gloyn | 5 | 1 |
| Help turbo highflow options | Daniel Clarke | 9 | 1 |
| In need of a hi-flow service in Geelong/Melbourne | Alistair David | 5 | 1 |
| Front mount intercooler | James Buchan | 10 | 1 |
| Turbo Rebuild Mechanic Melbourne Recommendations | Jay Asghari | 18 | 1 |
| Noisy turbo | Josh Barnes | 1 | 1 |
| Smoke at idle after boosting | Daniel Clarke | 9 | 1 |
| Boost, How much can 1jz handle? | Enzo Seidl | 24 | 1 |
| CT15b replacement | Jacob Thomas | 3 | 1 |
| T3/T4 T04E TURBOCHARGER 480HP T3 TURBO only $204 Brand New??? | James Tims | 7 | 1 |
| Tuning Greddy Spec 2 Profec B for stock turbos | James Tims | 18 | 1 |
| Blown turbo or something else | Robbie Rashleigh | 19 | 1 |
| Whole bunch of questions..... | Kurt Atzmuller | 11 | 1 |
| Possible to disable turbo | Boris Siljanoski | 19 | 1 |
| What should I do to get turbo sound louder/longer? | Kurt Atzmuller | 17 | 1 |
| Stock Setup | Boris Siljanoski | 5 | 1 |
| Best Turbo upgrade for the 1jz-gte | Johnny Brasche | 46 | 2 |
| Single hidden turbo...is it possible? | James Tims | 21 | 1 |
| Weird turbo sound...turbo flutter... | Fabian Bordon | 10 | 1 |
| Oil return line | Daniel Clarke | 3 | 1 |
| JZZ30 Intercooler kit? | Enzo Seidl | 5 | 1 |
| Very weird turbo problems. | Jack Lloyd | 3 | 1 |
| Turbos very noisy - car safe to drive on highway? | Dan McColl | 8 | 1 |
| GTX3576R | Tai Johnsen | 3 | 1 |
| Twin turbo manifolds | David Watt | 34 | 2 |
| Single water feed lines | Daniel Locke | 3 | 1 |
| Turbo sound, Need Help! | James Buchan | 27 | 1 |
| Dump pipe overboosting | Jeff Bedsor | 4 | 1 |
| Single turbo recommendations? | Aaron Mead | 3 | 1 |
| T-58 Questions | Ezekiel Vozzo | 8 | 1 |
| Good time to set turbo timer | James Tims | 24 | 1 |
| Need some parts identified under the bonnet, also how to connect st... | Alistair Moorby | 3 | 1 |
| Turbos need replacing - what are my options? | Matt Sartori | 5 | 1 |
| Can I run two devices off the same vacuum line? | Aiden Cheese | 8 | 1 |
| HELP - Which turbo GTX 3076 or GTX 3540 - both with 0.63 rear housings | Tai Johnsen | 24 | 1 |
| Boost Controller Problem - Solenoid or Main Unit | Hakan Pasha | 1 | 1 |
| TURBOSMART SOARER TT 1JZ BOV BLANKING KIT AVAILABLE NOW! | Matthew Smith | 40 | 2 |
| Stock Return Lines | Gary Poloskei | 9 | 1 |
| High flowed steelies from 1JZ onto 2jz | Daniel Clarke | 7 | 1 |
| Shell V-Power Fuel | Tai Johnsen | 33 | 2 |
| Turbo/wastegate/boost controller setup correctly? Seems to be stuck... | Luke Tongs | 8 | 1 |
| Ceramic or Steel Wheel Turbo's? | James Tims | 5 | 1 |
| Not making boost | Daniel Renahan | 24 | 1 |
| Garrett GT3788R opinions?? | Daniel Clarke | 4 | 1 |
| Popping noise? | Daniel Clarke | 7 | 1 |
| CT12A Compressor side lock nut | Gary Poloskei | 2 | 1 |
| Replacing tt for single does this look safe? | Veronica Mead | 14 | 1 |
| Hi flow, steel wheel CT12a question | James Tims | 25 | 1 |
| Boost Gauge Install - Please help | Darren Bauer | 31 | 2 |
| Weird Boost Issue | Hakan Pasha | 14 | 1 |
| Steel wheel or single? opinions..? | Luang Thokbuom | 44 | 2 |
| Ebay intercooler | David Grima | 5 | 1 |
| How to read a Compressor Map + Conversion Table | Tai Johnsen | 8 | 1 |
| Stock turbos, harsh rattle under boost ?? | Robbie Rashleigh | 29 | 1 |
| Gizzmo help | Hakan Pasha | 10 | 1 |
| Front or back oil feed for single turbo, does it matter? | Matthew Weaver | 7 | 1 |
| CT12A Gaskets | Matthew Weaver | 2 | 1 |
| Alright guys. Its $$$ Time | Mark Pattel | 10 | 1 |
| Another blown turbo post. | Matthew Hamono | 2 | 1 |
| Stock Soarer defected for white smoke, thinking turbo seals. | Chris Lock | 17 | 1 |
| Turbo Smart FCD | Christian Perez | 5 | 1 |
| T04Z with 0.68AR response | Chris Papadopoulos | 3 | 1 |
| 1JZ GT35R single turbo kit for $2300 landed from USA | Aaron Mead | 6 | 1 |
| Cracked Back Housing (Single) - Take a look | Camron Garcia | 7 | 1 |
| OVER BOOST! | Walter Gillmore | 41 | 2 |
| Stock 2jz turbo's | Walter Gillmore | 6 | 1 |
| 1JZ aftermarket BOV and adapter kit ?? suggestions ?? | Tai Johnsen | 19 | 1 |
| BOV Adaptor | Walter Gillmore | 4 | 1 |
| This is new type of CT12A setup | Walter Gillmore | 19 | 1 |
| Black Smoke? | Justin Hughes | 7 | 1 |
| Gt3271? | Chris Milner | 5 | 1 |
| 1JZ sounds like a tractor... exhaust leak ?? | Justin Prewett | 1 | 1 |
| Which is the better option?? | James Wilson | 28 | 1 |
| What RPM should my standard 1991 TT soarer hit full boost | Yang Luo | 11 | 1 |
| What do I need for a single turbo | Ross Pesina | 41 | 2 |
| Help to id a turbo | Walter Gillmore | 28 | 1 |
| Help!! turbo | Ross Pesina | 11 | 1 |
| GT35R & Internal wastegate | Ross Pesina | 6 | 1 |
| Which GT3076R? | Brett Harrison | 12 | 1 |
| Sard R2D2 problem | Richard West | 3 | 1 |
| Wastegate | Brett Harrison | 2 | 1 |
| Leaking coolant line | John O'Brien | 5 | 1 |
| Any one's interested to get their CT15B turbo high flowed at half p... | Chris Nguyen | 12 | 1 |
| Intercooler pipes | Walter Gillmore | 8 | 1 |
| Turbo side part numbers | Layton Molenaar | 5 | 1 |
| Are these the good dumps? | Daniel Salt | 4 | 1 |
| Would 17psi hurt | Matthew Weaver | 12 | 1 |
| What is this pipe and where does it connect to? | Nick Okeeffe | 12 | 1 |
| GT 3076R ? | Austen Menze | 55 | 3 |
| Lews dump piupe gaskets | Daniel Clarke | 2 | 1 |
| Turbo spooling problem | Matthew Hamono | 4 | 1 |
| Urgent Turbo Question!!!! | Matt Sartori | 7 | 1 |
| New CT12A's | Costa Tsimiklis | 107 | 5 |
| My Single Turbo Soarer - Vids | Evan Nguyen | 4 | 1 |
| Picture Request - Black Turbo Piping. | David Barnes | 3 | 1 |
| Turbo Vibration / Upgrade / Question | Costa Tsimiklis | 14 | 1 |
| Twin tdo6 | Matthew Sharpe | 58 | 3 |
| Thought I'd share this interesting page | Aaron deVisser | 1 | 1 |
| сt12b On 1jz-gte TT | Alex Krasnikov | 6 | 1 |
| Found some brand new genuine CT12A's | Alex Krasnikov | 29 | 1 |
| New soarer owner, Modified with some problems help needed | Costa Tsimiklis | 9 | 1 |
| Are my turbos buggered? | Walter Gillmore | 25 | 1 |
| Turbo upgrade | Harley Jones | 11 | 1 |
| Know of an adaptor to fit an aftermarket Bov to stock position ?? | David Duffell | 6 | 1 |
| Forced upgrade time. help! | Aiden Cheese | 16 | 1 |
| Needing advice on upgrading... | Rob Rojo | 42 | 2 |
| External wastegate selection help! | Costa Tsimiklis | 8 | 1 |
| Cheapest bang for buck mod! | Gary Poloskei | 8 | 1 |
| Ct12 with Garret Centre needing oil line info etc | Lew Radbourn | 24 | 1 |
| How to go single | Matthew Weaver | 1 | 1 |
| Turbo housing to exhaust manifold gasket | Scott Wilkes | 18 | 1 |
| Smoke from exhaust. Was told turbo seals gone. | Matthew Weaver | 2 | 1 |
| Vids of my supra (NAUUGGHHTTT) | Chris Prak | 4 | 1 |
| Turbo specs - rough idea | David Tra | 6 | 1 |
| Is running boost controller safe on stock turbo? | Shadi Sabbagh | 25 | 1 |
| Flutter | Layton Molenaar | 19 | 1 |
| GREDDY T78 | Aaron Casey | 47 | 2 |
| New Turbo | Jeff Bedsor | 18 | 1 |
| Single turbo advice | Mark Bryant | 3 | 1 |
| Boost Boost Boost | Evan Kaio | 7 | 1 |
| CT15b Upgrade | Brett Callaughan | 5 | 1 |
| 1JZ modification guide | James Wilson | 34 | 2 |
| Will i hit boost cut | Ian Clifford | 46 | 2 |
| CT15b highflow/rebuild | David Tra | 25 | 1 |
| Haltech Platinum 1000 PnP 1JZ-VVTI | Cihan Aday | 1 | 1 |
| Toyota Soarer 1jzgte TT to singe using Std Turbo Manifolds - Ebay | Jeff Bedsor | 15 | 1 |
| Problems with overboosting! | Scott Wilkes | 15 | 1 |
| Help with oil line length for single conversion | Spencer Cameron | 7 | 1 |
| Gatting turbos checked out | James Wilson | 2 | 1 |
| Need help removing lews dump pipes | David Wojcik | 6 | 1 |
| Boost issues | Jeff Smith | 9 | 1 |
| Shuddering when backing off accel. | Rob Rojo | 2 | 1 |
| Started the removal.. | James Wilson | 20 | 1 |
| Turning off when boosting | Cihan Aday | 29 | 1 |
| High flows & head work | Nathan Hlad | 2 | 1 |
| Adj Cam gear settings | Layton Molenaar | 12 | 1 |
| Getting a gt35 | Costa Tsimiklis | 8 | 1 |
| Which turbo is this? | David Tra | 9 | 1 |
| Ms-Ibc barely increase boost | Marc Hoffmann | 6 | 1 |
| Alternative turbo upgrades | Chris Milner | 13 | 1 |
| Boost Gauge | Aaron Mead | 10 | 1 |
| My turbos sound bad =[ | Natasha D'Abreo | 10 | 1 |
| Do I need an E-Boost?? | Sari Rabadfi | 5 | 1 |
| GOING SINGLE | Aaron Mead | 8 | 1 |
| Killed my Turbo | Rhys Salmon | 4 | 1 |
| Over boosting | Marc Hoffmann | 4 | 1 |
| Help - With my BOOST leak | Shane Van Ross | 14 | 1 |
| 9psi feels same as 15.5 | Austen Menze | 18 | 1 |
| Single conversion | Jeff Smith | 3 | 1 |
| Hks t3g heat shield | Sebastian Grant | 23 | 1 |
| Bang bang antilag question | Austen Menze | 28 | 1 |
| Issue raising boost | Scott Wilkes | 13 | 1 |
| Removed BOV gave me a huge increase in power! | Ryan McDonough | 9 | 1 |
| OIl in turbo's | Elizabeth Hogan | 6 | 1 |
| Spare Turbos, Compressor Wheel | Ty Mackay | 18 | 1 |
| What are these markings on my turbo? | Austen Menze | 4 | 1 |
| Is going single, street legal... | Lew Radbourn | 17 | 1 |
| Hybrid HKS T3G's | Antonio Hunt | 15 | 1 |
| Going well and then it all went horribly wrong | Sebastian Grant | 57 | 3 |
| Changing Stock TT Turbos - VF8 Turbos | Boris Siljanoski | 16 | 1 |
| Incabin boost controller | Christian Perez | 4 | 1 |
| Ct12a Replacement question | Rob Rojo | 9 | 1 |
| Lets Talk external wastegates | Chris Driver | 8 | 1 |
| Surely this isnt normal? | Jeff Bedsor | 3 | 1 |
| Manual Boost Controller | James Harris | 7 | 1 |
| Looking to go single turbo | Asmat Saleem | 16 | 1 |
| Cleaning out actuators | Scott Wilkes | 3 | 1 |
| VVTI 1JZ TURBO BOOST CONTROLLER | Andrew Stewart | 3 | 1 |
| Screamer block plate | Scott Wilkes | 4 | 1 |
| EBay Boost Controller | Supadej Akrawichien | 22 | 1 |
| Are my turbos leaking or just f<<ked | James Wilson | 9 | 1 |
| Standard Turbos | Nicolas Andrushenko | 6 | 1 |
| Vacuum Lines | Michael Keen | 10 | 1 |
| Oil drain/feed lines? | James Wilson | 3 | 1 |
| Help with Blitz ID3 not holding constant boost | Austen Menze | 5 | 1 |
| Turbo mount bolts hard to get to places | Marc Hoffmann | 11 | 1 |
| Can the stock ECU run a BOOST Controller? | Sari Rabadfi | 14 | 1 |
| Fuel Cut Debate - Simple Fix Wanted | Rob Rojo | 22 | 1 |
| Turbo removal | Scott Wilkes | 6 | 1 |
| Will it fit? | David Grab | 7 | 1 |
| How much boost with my T3/T4? | Tim Hutchings | 3 | 1 |
| Raise that boost! | Walter Gillmore | 4 | 1 |
| Regarding Trefs smoking turbos....... | Scott Wilkes | 2 | 1 |
| Anyone got the AEM Wideband? | Austen Menze | 9 | 1 |
| Strange Boosting Problem. | Dale Holan | 25 | 1 |
| Disconnect turbos? | David Barnes | 25 | 1 |
| Single Turbo Manifold Adapters.... | Daniel Clarke | 15 | 1 |
| Loosing boost bad... | Sebastian Michalski | 36 | 2 |
| GT3582R .63 exhust housing | Grant Rowan | 75 | 3 |
| My New Single | Rob Rojo | 35 | 2 |
| Max boost...stock turbos | Harley Jones | 74 | 3 |
| Help/Advice | Chris Prak | 13 | 1 |
| EBC Solenoid mounting | Scott Wilkes | 4 | 1 |
| Fitting ct20's | Scott Wilkes | 5 | 1 |
| Gt3582 + 6boost manifold 1jz | Gary Poloskei | 34 | 2 |
| Removing the turbos from a 1J - any how-to's or special tools neede... | Daniel Clarke | 41 | 2 |
| 1JZ EXTERNAL GATE INSTALLATION | Aaron Casey | 9 | 1 |
| Lower boost. And best place to get GT35R turbo? | Aaron Casey | 3 | 1 |
| 2jz with gt3076r?? | Aaron Casey | 10 | 1 |
| What's this on my turbos??? | Sebastian Grant | 9 | 1 |
| Steel wheel | Cihan Aday | 30 | 2 |
| What's a great twin setup | Bobby Green | 2 | 1 |
| Upgraded Turbo Problem. | Cameron Laufer | 22 | 1 |
| Gizzmo MS-IBC help. Duty settings. | Dale Holan | 4 | 1 |
| Single Turbo Help | Daniel Clarke | 35 | 2 |
| Le sigh... coolant in the pipes | Walter Gillmore | 25 | 1 |
| HKS T3G SETUP COMPLETE.. + couple questions ... | Mark Tierney | 59 | 3 |
| GIZZMO EBC | Dale Holan | 21 | 1 |
| SAFC II reduces boost cut? Is it true? | Dennis Weglehner | 50 | 2 |
| Found a way to get usdm supra turbos on a soarer.... | Robert Day | 15 | 1 |
| Opinions on which turbo? | Michael Keen | 53 | 2 |
| Turbonetics turbo kit | David Key | 3 | 1 |
| Soooo im going to put these on | Charlie Ters | 5 | 1 |
| Another 'Whats This' Pic. | Michael Liang | 8 | 1 |
| Replacement for CT12A | James Harris | 2 | 1 |
| How much to... | Michael Lucas | 6 | 1 |
| How to inspect CT12a turbos? | Scott Wilkes | 4 | 1 |
| WTB Single turbo 1jz Manifold | Dave Cazes | 2 | 1 |
| Gizzmo IBC | Cihan Aday | 6 | 1 |
| GT35R rebuild? | Daniel Clarke | 12 | 1 |
| Flooded Turbo | Michael Keen | 4 | 1 |
| Ct15 turbo? | Andrew Stewart | 27 | 1 |
| TR43 HYPERGEAR TURBO | Tao Shangguan | 34 | 2 |
| My fun morning | Ty Mackay | 12 | 1 |
| Turbo issues? Black smoke. | Ty Mackay | 12 | 1 |
| American Steel Wheel 1jz Turbos | Costa Tsimiklis | 8 | 1 |
| Gizzmo ms ibc help! | Ryan Rankovic | 4 | 1 |
| Heat management- manifold very close to compressor outlet | George Funa | 6 | 1 |
| Up the boost | Manual Kalianis | 53 | 2 |
| Pinging Engine. | Blake Gloyn | 8 | 1 |
| Floating V's Bearing? | Andrew Stewart | 10 | 1 |
| Turbo Help: looks like Led balancing weights have been exposed | Grant Rowan | 36 | 2 |
| Turbos not spooling! | Tim Hutchings | 32 | 2 |
| Chinese turbos?? | Lionel Trotea | 9 | 1 |
| Boost Pressure? | Ben Lipman | 9 | 1 |
| JAYCAR fuel cut defender... WA PEOPLE | Matthew Standage | 2 | 1 |
| Plumbing up external gate. | David Tra | 11 | 1 |
| Whistling Noise, Not blown turbos?? | Joel King | 31 | 2 |
| Wastegate Actuators | Jeff Bedsor | 1 | 1 |
| CT12A from Japan | Kyle Wathen | 22 | 1 |
| Turbo oil feed studs / nuts | Daniel Treadwell | 1 | 1 |
| Stock turbo manifold upgrade question | Maurice Diggler | 8 | 1 |
| Budget turbo kit | Gary Poloskei | 11 | 1 |
| I'm going SINGLE!!! Some advice needed please ... | Mal Nicholson | 43 | 2 |
| CT20's | Mal Nicholson | 6 | 1 |
| I'm new to turbos, somewhere I can learn more? | Kane Chan | 11 | 1 |
| How do you identify Chinese Copy CT12a's | Cameron Laufer | 12 | 1 |
| CT12A Oil Leak. Need advice | Joel King | 13 | 1 |
| 1uzfe turbo setup, what do i need?/to know (lots of questions ;)... | Robert Day | 4 | 1 |
| Turbo problems?... | Christian Molenda | 6 | 1 |
| Single turbo conversion Need info please!!! | Nathan Sheehan | 11 | 1 |
| Gizzmo MS-IBC | James Harris | 2 | 1 |
| Replacing/ changing boost Gauge | James Harris | 4 | 1 |
| Is my turbo gone!!! | Cameron Laufer | 12 | 1 |
| Turbo - I think im losing boost???... | Tim Hutchings | 12 | 1 |
| Help me in choosing the right boost controller. Please. | Luke Streat | 19 | 1 |
| Is my turbo cactus? | Luke Streat | 21 | 1 |
| Heads up on FCD/EBC/ECU options/benefits | Daniel Burns | 17 | 1 |
| Boost Controller Advice | Mike Dobkin | 4 | 1 |
| Single Turbo coming, last minute advice? | Rob Rojo | 10 | 1 |
| Turbo Trouble | Tim Hutchings | 14 | 1 |
| Individual intakes for each turbo? | Daniel Clarke | 29 | 1 |
| DO I NEED TO REPLACE OIL FEED FOR TURBO? | Ben Socratous | 12 | 1 |
| Boost level | Brian Kelly | 3 | 1 |
| T4 turbo | Garth Williams | 5 | 1 |
| Hypergear TR44HF tuning impressions | Tao Shangguan | 131 | 6 |
| EBC Trouble | Mike Dobkin | 5 | 1 |
| Turbo sizing advice on a 2JZ | Danny Dinh | 7 | 1 |
| Loud spooling noise | Barry Main | 16 | 1 |
| Name this dump pipe? | Steven Nanevski | 27 | 1 |
| WANTING TO UPGRADE TWINS WITH TWINS | Steven Nanevski | 9 | 1 |
| Installing a boost controller - Instructions for noobs | Danny Dinh | 11 | 1 |
| Gt30/40r with a hks t25 rear | Lew Radbourn | 23 | 1 |
| What is Boost Cut? | Chris Prak | 3 | 1 |
| Oil water lines | Ben Socratous | 3 | 1 |
| Stock ecu, no FCD able to run 20psi | Cihan Aday | 4 | 1 |
| CA12 turbo help???? | Scott Wilkes | 18 | 1 |
| Dump valve open at 2400 then the noise from the turbo...... | Brett Harris | 9 | 1 |
| Gready T67 Single turbo kit | Jason Jon | 6 | 1 |
| Strange thing has got me puzzled | Cameron Laufer | 6 | 1 |
| Gt30\40 1.06? v's .82 | Cameron Laufer | 18 | 1 |
| Ebay purchase advice please | Daniel Clarke | 5 | 1 |
| Steel Wheel Turbos? | Brett Harris | 8 | 1 |
| Turbos loud on cold start | Andrew Magee | 6 | 1 |
| Gizzmo MS - IBC | Cihan Aday | 10 | 1 |
| Refitting rebuilt turbos, need advice. | Don Bagnall | 21 | 1 |
| GFB Mach 1 Adaptor | Scott Gates | 3 | 1 |
| Experience or advice on which electronic boost controller to get? | Shaz Pervez | 14 | 1 |
| Turbo problems | Edward Salem | 14 | 1 |
| Reccommended boost for my car | Tony Nguyen | 4 | 1 |
| Are turbos meant to rattle? or is it something else? ... | Dixon Won | 14 | 1 |
| Please help a fellow out (turbo talk) | Simba Jon | 34 | 2 |
| Stock BOV question | Steven Roduner | 4 | 1 |
| Single Turbo = $$$, maybe not? | Cameron Stanley | 23 | 1 |
| Single Turbo Kits? Or purchase items separate? | Michael Keen | 30 | 2 |
| Fuel cut defender | Danny Dinh | 12 | 1 |
| Are HKS EVC boost controllers any good? | Mario Jayawardena | 7 | 1 |
| Another 'cheap' Hypergear conversion.....or is it?.... | Maurice Diggler | 164 | 7 |
| Turbo / Manifold weight / dimensions for postage... | Charlie Ters | 4 | 1 |
| Stock turbo replacements | James Cahir | 6 | 1 |
| CT12a GT28 Roller bearing Turbos | James Johnson | 46 | 2 |
| Installing ssqv | Mario Jayawardena | 1 | 1 |
| External wastegate query | David Tra | 10 | 1 |
| TURBO HELP PLS ON SPECS | Karim Tabbouch | 3 | 1 |
| HDI Super Electronic Boost Controller | Sebastian Grant | 3 | 1 |
| Small oil leak | Ryan McDonough | 5 | 1 |
| Boost ajustment | Daniel Clarke | 6 | 1 |
| Boost spikes | James Johnson | 14 | 1 |
| Newbie needs advice | Kaloy Szyd | 6 | 1 |
| T-Piece boost controller problems... | Luke Burt | 9 | 1 |
| Stuffed Turbo?!!! | Matthew Werner | 8 | 1 |
| Hitting boost. | Ken Tran | 5 | 1 |
| Turbo storage | Cihan Aday | 4 | 1 |
| Good deal or cheap and nasty? | Michael Keen | 14 | 1 |
| Faulty PCV Valve = Turbo Failure? | James Harris | 8 | 1 |
| Wonky power curve - running overly rich | Sean Fair | 7 | 1 |
| Turbo Boost help!! | Scott Gates | 5 | 1 |
| Oil pressure | Josh Brown | 5 | 1 |
| Front vs Rear Turbo | Braden Murdoch | 2 | 1 |
| My PFC finally tuned | Sami Ansari | 14 | 1 |
| Has anyone seen or used this turbo kit??? | Christian Molenda | 8 | 1 |
| Electronic Boost Controller = No fuel cut defender? | Daniel Clarke | 12 | 1 |
| Jaycar Independent Electronic Boost Controller Kit | Charlie Ters | 2 | 1 |
| No wheelspin | Chris Davey | 30 | 2 |
| Boost increase...or not? | Brad Knudsen | 7 | 1 |
| Boost issues!? | Tim Hutchings | 5 | 1 |
| Stuck wastegates | Steve Zourkas | 9 | 1 |
| Max psi | Charlie Ters | 8 | 1 |
| Raising boost levels | Luke Burt | 7 | 1 |
| Birthday Upgrade | Robert Whitbread | 159 | 7 |
| Variable vane turbos | Matthew Werner | 7 | 1 |
| Turbo replacemant | Daniel Clarke | 38 | 2 |
| Turbo blades | Peter Nitschke | 15 | 1 |
| Whats the difference (CT12A) | Shane McInnes | 6 | 1 |
| Turbos howling sucking | Jason Thornton | 21 | 1 |
| HKS To4z opinion | Shyam Purushothman | 9 | 1 |
| T04z Hot Side Question | Maurice Diggler | 9 | 1 |
| Single turbo oil drain | Anton Jones | 15 | 1 |
| HKS T3G Actuators | Steven Nanevski | 14 | 1 |
| Sleeping beast | Luke Cairns | 17 | 1 |
| Does the 2JZ turbo set up bolt up to the 3-to-1 1JZ set up | Luke Bell | 6 | 1 |
| 91 TT - Turbos not boosting | Kyle Wathen | 8 | 1 |
| HKS T3G | Roshan Jay | 22 | 1 |
| What are these vacuum lines? | Joshua White | 4 | 1 |
| Turbos suddenly stopped boosting | Luke Nieuwhof | 7 | 1 |
| Porting a stock BOV? Possible? | Russell Rohde | 9 | 1 |
| Dirty Pipes | Russell Rohde | 8 | 1 |
| Howlin' Wolf! | Jeff Smith | 15 | 1 |
| Ceramic or steel | Braden Murdoch | 16 | 1 |
| Hose off bov? | Shannon Mobbs | 2 | 1 |
| New Turbos - big problem! | Mustafa Akgul | 41 | 2 |
| I can't raise my boost level | Blake Gloyn | 4 | 1 |
| Opinions on turbo kit | Aaron Holland | 1 | 1 |
| What is the CT20 single turbo equivalent to? | Andrew Stewart | 1 | 1 |
| GT3076R OR GT3082R | Lew Radbourn | 10 | 1 |
| What turbo should I Go | Blake Gloyn | 30 | 2 |
| Gt35r too big? | Aaron Mead | 9 | 1 |
| Help with stock BOV Piping? | Maurice Diggler | 7 | 1 |
| Questions about hooking up a boost controller | Jake Laing | 5 | 1 |
| Just a quick question~~ | Aska Liu | 15 | 1 |
| 1jz single turbo kit | Micheal Males | 11 | 1 |
| Boost problems, HELP!!! | Tim Hutchings | 12 | 1 |
| Blitz boost controler | Phil Stuart | 14 | 1 |
| Boost tap | Tim Hutchings | 1 | 1 |
| One way valve on BOV | Brian Timms | 4 | 1 |
| Fcd | Raymond Bardrick | 2 | 1 |
| Stock boost level | Tim Hutchings | 7 | 1 |
| How hard is it to change an exhuast housing? | James Harris | 5 | 1 |
| Booost problems with (DSBC) | Rob Rojo | 5 | 1 |
| Jaycar FCD (fuel cut defender) to use or not to use??? | Benn Glover | 10 | 1 |
| Single turbo size | Daniel Clarke | 3 | 1 |
| Steel wheel upgrade | Daniel Clarke | 5 | 1 |
| Rear turbo is gone after changing rocker cover gasket | Braden Murdoch | 5 | 1 |
| Single turbo overboost | Shyam Purushothman | 6 | 1 |
| SINGLE TURBO CONVERSION. SOARER 2.5TT | Vinh Bui | 6 | 1 |
| WHAT DO I DO, WHAT DO I DO, OH MY GOD, WHAT DO I DO? | Patrick Robinson | 16 | 1 |
| What do you think of this kit? | Will Schultz | 2 | 1 |
| 1JZ GTE Compression test | Edward Salem | 16 | 1 |
| Can I run 13s with more boost? | Daniel Clarke | 47 | 2 |
| Hypergear TR44 HF installed (no leaks!) | Grant Rowan | 52 | 2 |
| Whats peoples opinion on kkr turbos,like 480 | Adam Holloway | 15 | 1 |
| problem with greddy profec b spec 2 | Adam Holloway | 18 | 1 |
| Nothing is easy for me | Daniel Clarke | 37 | 2 |
| $3000 for a single turbo conversion | Jeff Smith | 89 | 4 |
| HELP HELP PLEASE | Jake Laing | 16 | 1 |
| I need some serious help with my TT | Will Sanguins | 13 | 1 |
| Help needed, T3G's not boosting over 7psi | Mustafa Akgul | 20 | 1 |
| Garret TO4b | Rory Pipprell | 3 | 1 |
| Running Rich at Start up / Under Boost bit of smoke | Daniel Clarke | 7 | 1 |
| Bov adapter.....What type of weld to use??? | Jeff Smith | 4 | 1 |
| Is this a manual boost controller? | Charlie Ters | 4 | 1 |
| Pics of my single turbo | Adam Holloway | 12 | 1 |
| I have gone to single turbo now | Adam Holloway | 26 | 1 |
| HELP, WITH HKS BOV INSTALLATION | Shane Haverkamp | 6 | 1 |
| What the frick?! | Ken Tran | 5 | 1 |
| Turbo Torque...hahaha | Rob Andreacchio | 13 | 1 |
| EBC'S | Chris Prak | 21 | 1 |
| Anyone using a Greddy Profec B spec II? | Scott Ferguson | 18 | 1 |
| HKS T3G's | Daniel Clarke | 2 | 1 |
| Fuel cut cancel? | Shaun Stephenson | 6 | 1 |
| Plumbing into Vacume hoses, that have already been plumbed into | Chris Prak | 4 | 1 |
| Bov Help | Dale Holan | 7 | 1 |
| Picture needed from installed solenoid for a ebc (APEXI AVC-R) | Rob Andreacchio | 5 | 1 |
| What flange is | Michael Keen | 3 | 1 |
| Blow Off Valve Plate | Shane McInnes | 3 | 1 |
| Garrett gt17's | Michael Keen | 3 | 1 |
| Gizzmo Ms-Ibc | Cara Joseph | 2 | 1 |
| A single turbo for drift any ideas? | Brendan Angee | 5 | 1 |
| Recommended turbo workshops in SA? | Edward Salem | 14 | 1 |
| HKS JZX100 turbo kit on a Soarer? | Jon Edwards | 6 | 1 |
| What are peoples opinion on a IHI apexi C7 turbo 650hp setup | Daniel Clarke | 20 | 1 |
| New Steel Wheeled Turbos, boost issues | Daniel Clarke | 15 | 1 |
| HKS T3G's | Luke Burt | 5 | 1 |
| STOCK BOV PICTURES ANYONE? | Jeff Smith | 7 | 1 |
| Info on TD06S 20G-12cm2 | Jeff Bedsor | 17 | 1 |
| Turbosmart Dual Stage Boost Controller Install | Braden Murdoch | 7 | 1 |
| Another blow off valve question... | Jake Laing | 1 | 1 |
| Advise on upgrade | Alen Sadikovic | 1 | 1 |
| Dont buy just jap manifold for 1j | Adam Holloway | 9 | 1 |
| Braided oil and water lines for TT turbos | Adrain Parsons | 10 | 1 |
| Need help for boost controller asap | Patrick Tran | 5 | 1 |
| Melbourne Turbo shops | Cara Joseph | 3 | 1 |
| Turbos swap, stock to after market | Braden Murdoch | 23 | 1 |
| Price on going single | Chris Davey | 12 | 1 |
| Steelwheeled supra ct20a | Matthew Crawford | 5 | 1 |
| Greddy profec b spec 2 are they hard to install and are they any good. | Adam Holloway | 11 | 1 |
| Help Needed! Please Read!, Turbo Whine.. | Jeff Smith | 12 | 1 |
| Installing boost gauge on manual | Patrick Tran | 7 | 1 |
| Do i need new turbos? if not wats wrong? | Kim Anthony | 21 | 1 |
| Where to mount manual boost controller? | Kurt Porter | 6 | 1 |
| Factory turbos about to kick it - Highflow or not? | Daniel Clarke | 18 | 1 |
| Maximum boost pressure on ceramics? | Braden Murdoch | 18 | 1 |
| Boost Gauge | Kurt Porter | 20 | 1 |
| Turbo Timer-where to get one? | Yang Luo | 10 | 1 |
| Ct12a options??? | Jeff Smith | 10 | 1 |
| Turbo's getting stripped and rebuilt - opinions on kkk wheels | Matthew Crawford | 17 | 1 |
| Boost cut... | David Henderson | 13 | 1 |
| HKS T3g do you have them? | Christian Molenda | 5 | 1 |
| Leaking Oil Drain | Grant Rowan | 4 | 1 |
| Are they gone???? | Edward Salem | 20 | 1 |
| Boost Gauge | Maurice Diggler | 21 | 1 |
| Installing CT12As | Ben Daniel | 10 | 1 |
| I'm Going To Buy A New Turbo...But Which One? | Luke Yates | 36 | 2 |
| Installing boost controler | Ben Socratous | 3 | 1 |
| Difference between GCG turbos and stockies | Todd Williams | 2 | 1 |
| Difference between front and back turbo? | Peter Abdelmessih | 2 | 1 |
| About the steel wheelies on ebay????? | Nilay Bhikha | 23 | 1 |
| Boost Controller, Which vacuum line? | Alex Ross | 13 | 1 |
| Turbo manifold compatibility | Ben Daniel | 4 | 1 |
| Twin Scroll Setup's | Marc Vipond | 2 | 1 |
| 400rwkw+ what else? | David Eberhart | 50 | 3 |
| Single turbo & LPG, ECU question | Chris Davey | 8 | 1 |
| How much quicker will my turbo spool... | Benjamin Burgess | 12 | 1 |
| Dumps with stock exhaust, FMIC, boost - any point? | Paul McConnell | 6 | 1 |
| Upgraded twins with Subaru VF10 turbos | Daniel Clarke | 49 | 2 |
| Single turbo conversion or just replace turbos | Mustafa Akgul | 21 | 1 |
| Turbo noise issues | Matthew Sharpe | 12 | 1 |
| Helpm please my soarer wont boost over 10psi | Brian Timms | 3 | 1 |
| How can i can set up the turbo boost on my soarer | Yang Luo | 4 | 1 |
| Where to get turbos?? | Ross Pesina | 43 | 2 |
| Not on boost | Aslan Kuyucu | 12 | 1 |
| Turbonetics GT-K | Lew Radbourn | 7 | 1 |
| Boost Controller, Intercooler, Detonation... | Cihan Aday | 6 | 1 |
| What do i need to go single....on a budget ?? | Benjamin Burgess | 12 | 1 |
| FCD and Boost Cut | Cihan Aday | 3 | 1 |
| What kind of hosing for a boost gauge | Christian Molenda | 2 | 1 |
| Methods of prolonging your turbo life | Braden Murdoch | 6 | 1 |
| How to tell if you have steel wheels | Justin Cook | 22 | 1 |
| Turbo not bossting everything is fine but no boost | Brian Timms | 8 | 1 |
| There's a lot of talk about this, and it now has my interest. | Todd Williams | 12 | 1 |
| Turbo rebuild | Justin Camilleri | 3 | 1 |
| Turbo whistle w/ upgraded exhaust | Edward Salem | 32 | 2 |
| New toys for me!!! | Ben Socratous | 18 | 1 |
| Finding a t section for boost gauge/steering column q? | Christian Molenda | 2 | 1 |
| Overdrive Turbo? | Stephen Hurst | 10 | 1 |
| Leaking oil from rear turbo oil line after refitting steel wheels | Damien Barnes | 4 | 1 |
| When to replace Turbos... | Daniel Czechowski | 27 | 1 |
| When turbos break it's a great excuse to UPGRADE! | Joe Radisic | 2 | 1 |
| HELP: Smoke from turbo! | Christian Molenda | 6 | 1 |
| GT3076R more responsive after tune and gearbox rebuild | Benjamin Burgess | 4 | 1 |
| GREDDY TD07S-25G | Charlie Ters | 8 | 1 |
| JJR Turbo | Chris Davey | 3 | 1 |
| Turbo response | Cihan Aday | 56 | 3 |
| Turbos | Daniel Clarke | 54 | 2 |
| Turbo Removal. | Jeff Smith | 19 | 1 |
| Acceptable Boost to be run on stock turbos. | Daniel Clarke | 17 | 1 |
| HKS T3G dump pipe | Stasi Christo | 7 | 1 |
| Dual Stage Boost Controler | Tim Eacott | 4 | 1 |
| Boost loss, from 12.5 psi to 10 psi | Cihan Aday | 10 | 1 |
| Surging when boost comes on and no real power | Dennis Weglehner | 16 | 1 |
| Whistling turbos | Braden Murdoch | 57 | 3 |
| Power fc boost control kit | Benjamin Burgess | 18 | 1 |
| Car misses and builds boost | Chris Prak | 6 | 1 |
| Cheap turbos on Ebay | Chris Davey | 3 | 1 |
| Whats this Single Turbo kit like? | Dan Humphreys | 14 | 1 |
| Single turbo manifolds, what about this one? | Benjamin Burgess | 8 | 1 |
| GT3040; T04S Compressor vs GT40 Compressor | Benjamin Burgess | 2 | 1 |
| Install Help!: HKS EVC IV Electronic Boost Controller | Callum Finch | 8 | 1 |
| Fitting supra turbos to a soarer? | Cihan Aday | 12 | 1 |
| I'll never mess with wussy twins again! ... | Brian Timms | 7 | 1 |
| Turbos in your passenger seat anyone! | Jeff Wilkins | 11 | 1 |
| Turbotech manual turbo boost controller - Opinions? | Toan Nguyen | 8 | 1 |
| XR6 Turbo spec GT35R | Maurice Diggler | 30 | 2 |
| A few questions - boost + BoV.. need information | Aka Abedin | 17 | 1 |
| T3 or TD05 | Peter Suridge | 1 | 1 |
| Dump pipes = boost rise + boost cut ? | Maurice Diggler | 34 | 2 |
| HKS T04R response on a 1JZGTE | Chris Davey | 21 | 1 |
| Turbocharger Question | Aaron Mead | 26 | 1 |
| Boost problem | Yang Luo | 7 | 1 |
| Greddy Bolt On Turbo Upgrade Kit | Sean Yost | 48 | 2 |
| Jaycar Boost controller | Brendan Hax | 13 | 1 |
| Turbo oil | Tom Cousin | 1 | 1 |
| Turbo's needing to be explained.... | Vinh Bui | 9 | 1 |
| Quickest 60' on stock turbos and convertor | Daniel Clarke | 36 | 2 |
| Few questions - turbo's / things to look for / upgrades | Dean Carsen | 27 | 1 |
| High Pitched Scream coming from turbos | Vinh Bui | 34 | 2 |
| Single Turbo | Chris Davey | 7 | 1 |
| Turbo chatter | Daniel Czechowski | 16 | 1 |
| Picking up the turbos tuday | Braden Murdoch | 15 | 1 |
| Using mechanical Boost controller as a Pneumatic FCD | Cihan Aday | 12 | 1 |
| Boost issue | Braden Murdoch | 14 | 1 |
| Turbo upgrade option that is not what I was expecting | Richard Johnson | 14 | 1 |
| Other Direct Fit Twin Turbo applications perhaps?? | Adam Olsen | 2 | 1 |
| Turbo gaskets? | Daniel Czechowski | 2 | 1 |
| Hybrid Turbos vs Reconditioned Steel Wheeled Turbos | Vinh Bui | 89 | 4 |
| CT12B's on a 1jz??? | Braden Murdoch | 4 | 1 |
| Stock 1jz pulls 144rwkw | Joel Moore | 11 | 1 |
| Trust T67 25G- 8cm or 10cm? | Aaron Mead | 9 | 1 |
| Loss of boost and less power all of a sudden :| | Luke Nieuwhof | 14 | 1 |
| Think my turbo seals are gone, now what? | Matthew Sharpe | 11 | 1 |
| CT12a turbo gasket part numbers | Ben Daniel | 19 | 1 |
| Turbo life | Michael Keen | 15 | 1 |
| Twin TD05 Turbo MX73 Cressida project | Adam Olsen | 8 | 1 |
| Compressor maps | Cihan Aday | 10 | 1 |
| Boosting a mostly stock TT | Graham Dollisson | 27 | 1 |
| Question regarding Turbos | Damian Ware | 19 | 1 |
| Turbos on its way | Frank Sarkozi | 11 | 1 |
| Boost Controller | Braden Murdoch | 47 | 2 |
| Steel wheel turbo Vs hks t3g twin bolt on turbo | Dan McColl | 119 | 5 |
| Manifold help. experiance people need only to read. | Dan McColl | 3 | 1 |
| Ebay boost controllers | Ben Socratous | 23 | 1 |
| Question about the HKS or TD04 turbos?? | John Tibbs | 5 | 1 |
| Its time for a single..... | Richard Johnson | 52 | 2 |
| Boost Controller Settings (eboost) | Simon Triantafillou | 11 | 1 |
| I need turbo'd back pressure help! | Trent Toovey | 23 | 1 |
| Using boost controller without SAFC | Luke Nieuwhof | 4 | 1 |
| My AVC-R got problem | Jordon Codd | 31 | 2 |
| Hks t3g turbo's | Dave Stevanovic | 2 | 1 |
| Turbo Troubles? | Callum Finch | 14 | 1 |
| Gone single near finnished what next? | Cihan Aday | 8 | 1 |
| CT12 weight? | Daniel Czechowski | 2 | 1 |
| Turbo swap. | Danny Dinh | 3 | 1 |
| Coolant temperature rises after single turbo put in | Ben Socratous | 2 | 1 |
| Cheapest turbo upgrade help??? | Paul Brockbank | 5 | 1 |
| What kind of lag is everyone getting | Callum Finch | 57 | 3 |
| How long turbo seals last??? | Matthew Sharpe | 14 | 1 |
| What turbos fit directly onto the stock cast manifolds? | Simon Triantafillou | 4 | 1 |
| Turbo died and gone to heaven? | Jero Evans | 12 | 1 |
| Kinda nervous about turbo whine after reading the forums!!!! | George Check | 11 | 1 |
| FINALLY got the HKS t3g's in!!! | Christian Molenda | 26 | 1 |
| Turbo Death Whine. | Ben Daniel | 13 | 1 |
| Rebuilding turbos | Yang Luo | 8 | 1 |
| Turbo recondition $3000 start | Andrew Meiers | 10 | 1 |
| Garret gt28 ballbering | Daniel Drury | 17 | 1 |
| Single turbo | Danny Dinh | 6 | 1 |
| How much life at 14psi ? | Luke Nieuwhof | 21 | 1 |
| Standard Boost | Daniel Salt | 10 | 1 |
| Labour cost of replacing one stock turbo | Braden Murdoch | 13 | 1 |
| Cost of Turboing a NA 2JZ | Vinh Bui | 9 | 1 |
| Stock turbo conversion | Anthony Mare | 24 | 1 |
| Screamer Pipe | Paul Brockbank | 7 | 1 |
| Anyone know how to use the Blitz Dual SBC Spec S boost controller? | Peter Nitschke | 9 | 1 |
| What to do what to do ( turbos) | Matt Toll | 85 | 4 |
| Boost dies, chocks at high rpm and bunny hopping, wtf? | Sebastian Boyd | 13 | 1 |
| Sequentials on a 1JZ? | Cihan Aday | 9 | 1 |
| Single Turbo Conversion | Brett Lauria | 28 | 1 |
| GT45R | Marc Vipond | 26 | 1 |
| Weird Whining noise in turbos when cold? | Callum Finch | 7 | 1 |
| Another single turbo question... | Peter Ha | 44 | 2 |
| Standard turbo equivilants? | Callum Finch | 11 | 1 |
| Super charger for TT soarer | Marc Vipond | 44 | 2 |
| What size of the turbo wastegate to fit in ct12a | Lew Radbourn | 14 | 1 |
| How to tell if they have steel wheels? | Don Bagnall | 18 | 1 |
| Over boosting/boost controller trouble | James Johnson | 3 | 1 |
| 25psi overboost on JZX83 | Phil Melvin | 5 | 1 |
| Heard a snick..have I lunched a turbo? | Ben Socratous | 12 | 1 |
| Turbo removal | Matthew Sharpe | 20 | 1 |
| Steel Wheeled Turbos? | Jeff O'Rourke | 19 | 1 |
| Could only get 8psi from my turbos while tuning safc2 | Daniel Drury | 6 | 1 |
| Turbo?? | Sam Lofts | 5 | 1 |
| Single turbo setup done finally... | Benjamin Burgess | 64 | 3 |
| Single turbo related question | Paul Brockbank | 20 | 1 |
| Turbo Kit on Ebay. VERY NICE | James Harris | 10 | 1 |
| Ct12a vs t3g | Cihan Aday | 30 | 2 |
| Triple turbo ??? | Don Bagnall | 29 | 1 |
| Replacement trurbo's(what to look for?) | Michael Sztyk | 6 | 1 |
| Ct12a and ct12 | Peter Nitschke | 9 | 1 |
| Opinions on these turbos | Lew Radbourn | 8 | 1 |
| Single Turbo Soarer! Need ideas on what to do next! | Ben Evans | 32 | 2 |
| Chemical cleaning turbos, exhaust manifold etc | Steven Nanevski | 3 | 1 |
| Need advise on possible turbo setup | Cihan Aday | 11 | 1 |
| Standard Turbo Boost Setting | Chris Davey | 9 | 1 |
| Big Single Turbo Whats your thoughts? | Dave Storrie | 19 | 1 |
| What size wastegate should i use? | Chris Davey | 6 | 1 |
| CT12B's | Cihan Aday | 19 | 1 |
| Yet Another Turbo Upgrade Thread... | Rob Andreacchio | 18 | 1 |
| Steel/stock turbo pics | Todd Williams | 5 | 1 |
| T61 turbo | Chris Davey | 111 | 6 |
| Turbos | Morgan Cross | 5 | 1 |
| Leaking turbo manifold - Duh.. | Andrew Meiers | 11 | 1 |
| Turbo Question | Todd Williams | 8 | 1 |
| Steel wheeled ct12A's | Lindsey Swan | 9 | 1 |
| Turbo Pipes and Throttle Body... | Shane McInnes | 14 | 1 |
| Big Single Vs High Flow The Stock Turbo's | Shane Hayter | 31 | 2 |
| CT12a Steelies what PSI?? MAX? | Cihan Aday | 7 | 1 |
| Is a T28 turbo too small? | Lew Radbourn | 10 | 1 |
| Turbo questions | Troy Tappenden | 2 | 1 |
| What size Turbo | Benjamin Burgess | 6 | 1 |
| Trust TD06-20G Single Turbo conversion | Steven Nanevski | 4 | 1 |
| Y-Pipe Single turbo conversion. | Chris Davey | 7 | 1 |
| Turbo's again | Hayley Rafati | 19 | 1 |
| Bigger Turbo Conversion | Jared Martin | 21 | 1 |
| Turbo oil lines | Simon Roberts | 3 | 1 |
| Larger (GT40-67) turbo installed now | Tim Eacott | 21 | 1 |
| TRD Turbo | Sam Sulley | 3 | 1 |
| Twin 2530's on a 1JZ-GTE? | Troy Tappenden | 9 | 1 |
| Steel Wheel rebuild | Shane McInnes | 9 | 1 |
| Late model single turbo soarer | Mike Verrinder | 56 | 4 |
| Single Turbo 90 Degree Bend! | Cihan Aday | 10 | 1 |
| Big single | Louie Drossos | 3 | 1 |
| No Turbo Spool | Graham Dollisson | 16 | 1 |
| Turbo..boost.. how much does it run? | Cihan Aday | 33 | 2 |
Start New Thread |
