1
3
7
Days
Search
Topics
Tree View
Help
Soarer Central
Mechanical - TT
Ignition System & Upgrades
Previous
Next
Thread
Last Poster
Posts
Pages
Spark plug changing
Blake Gloyn
24
1
JZZ30 TT start-run issues...ignitor?
Nathan Sopeer
2
1
1NZ into 1JZ Cheap Coilpack Upgrade Guide
Tai Johnsen
92
4
Coil pack resistance values
Layton Molenaar
1
1
Missfire under boost !! Coils changed along with plugs etc
Matthew Werner
33
2
Help. Coil pack and now sounds like wrx
Corryn Anderson
9
1
1J ignitor
Brett Harrison
9
1
Missing o-rings?
1
Emanage ultimate ignition timing????
Harley Jones
14
1
Which size spark plug removal socket
Nathan Sopeer
8
1
OUT WITH THE OLD AND IN WITH THE BOSCH
Robert Bruinsma
11
1
Ignition problem - BORROW x6 ignitor or leads [VIC]
Tony Nguyen
1
1
Ignition cut at 6000 rpm with EMU...
Michael Sinay
14
1
Base ignition timing...
Scott Casey
2
1
Spark plugs
Ross Pesina
25
1
Jaycar Programmable Ignition System
Ross Pesina
1
1
Any difference between the HKS DLI 2 and the HKS DLI?
Jeff Bedsor
24
1
Coils: Part numbers. price, and best place to purchase
Scott Casey
8
1
Best plugs for Q.L.D weather
1
Any benefit of running a larger spark gap?
Costa Tsimiklis
6
1
The never ending problem! Now with a new message.
Jeff Bedsor
8
1
Ignition Coils
Matthew Weaver
3
1
How do you know what spark plug gap you should run?
George Funa
10
1
Installing spark plugs
Scott Wilkes
8
1
Toyota OEM Coilpacks at the Limit
Aaron Mead
22
1
Installed Bee*r not fully working
Todd Williams
12
1
Which plugs ?
1
Best place to buy Iridium Spark Plugs
Boris Siljanoski
10
1
Oil in spark plug wells
Daniel Panickar
5
1
COILPACKS PROBLEM GOING TO BE FINISH SOON
Geoff Coulter
18
1
Superspark Coil packs are out!
Shyam Purushothman
4
1
Brisk spark plugs
Walter Gillmore
2
1
What can cause this?
Christoffer Bergling
33
2
Tried Changing Spark Plugs But Can't Get Her Working Right
1
Superspark coils
1
Coils
Matthew Werner
33
2
Miss under part throttle fine under wot. wtf?
Louis Angelopoulos
25
1
[JAPAN] D1 SPEC VSD IV Ignition Booster System
Rajiv Wickramaratne
1
1
Car sound like a hairdryer?
1
Who knows how to read a spark plugs?
Ben Lipman
8
1
Missfire maybe?
Scott Wilkes
1
1
Coilpacks
Charlie Ters
7
1
Missfire Solved
1
Bosch Coils-how does the wiring work?
Chris Davey
29
1
Looking for a Wiring Diagram for HKS Twin Power DLI-2
Andy Bathie
6
1
Need ignitor where do i get one ?
Benjamin Burgess
4
1
Christian Here is a DLI for you
Cameron Laufer
1
1
Misfire which I can't figure out
Michael Keen
40
2
Bad miss fire.
Alen Sadikovic
11
1
Need Advice on Spark Plugs
Braden Murdoch
8
1
Spark plugs fouling
Matthew Sanderson
8
1
Help please Spark Plugs....
Brian Timms
17
1
Time for new coilpack methinks.
2
Need help with sourcing coilpacks
Brian Laws
15
1
Spark plug tutorials
Shaun Stephenson
21
1
Spark plugs
Daniel Salt
6
1
Coil Pack Cracking
Michael O'Driscoll
18
1
Spark plugs and oil
1
Serious missing or Ignition problem!!
Nathan Evans
33
2
Can't remove spark plug cover!
Drew Hiron
12
1
Spark Plug Leads ? 1JZ
Ben Evans
16
1
Wierd idle after sparky change.....???
1
Spark Plug Yes I Know But
Mustafa Akgul
14
1
Sparkplugs
2
Start New Thread
Administration
Log Out
Previous
Next
