Thread |
Last Poster |
Posts |
Pages |
 | Misfire driving me mad. | Evan Kaio | 9 | 1 |
 | Head gasket | Matthew Sharpe | 14 | 1 |
 | Whining Noise - Power Steering? | Anika Le | 7 | 1 |
 | Head gaskets and seals | Nathan Hlad | 9 | 1 |
 | Help? | Barry Precious | 14 | 1 |
 | JZZ30 Engine Removal (Auto) | Evan Kaio | 11 | 1 |
 | Engine noise on cold start up | Scott Wilkes | 12 | 1 |
 | Boost Controllers – Where to get hose etc | Boris Siljanoski | 20 | 1 |
 | Harness removal | Ben Williams | 3 | 1 |
 | Whining noise timming belt/cams | Daniel Tilbrooke | 15 | 1 |
 | Bad hesitation when not at operating temperature | Frank Csapo | 17 | 1 |
 | Engine Oil Level | Scott Wilkes | 17 | 1 |
 | SOARER TT WIERD PROBLEM PLZ HELP | Lew Radbourn | 46 | 2 |
 | Hydrolocked motor yesterday in Melbourne storm. | Omar Amin | 17 | 1 |
 | Ridiculous price for power steering hose, any options other than oem? | Sebastian Grant | 9 | 1 |
 | Bit Confused.. what do you think? | Rhys Salmon | 18 | 1 |
 | Aluminium radiator | Sebastian Grant | 32 | 2 |
 | Awful Compression Test | Ben Williams | 13 | 1 |
 | Importing JDM motors | Shane Haverkamp | 2 | 1 |
 | To wreck it or fix it? | Aiden Cheese | 7 | 1 |
 | Some sort of sensor help | Shane Haverkamp | 9 | 1 |
 | Brake booster outlet for 2j manifold??? | Aaron Casey | 1 | 1 |
 | Floded Engine | Garth Williams | 37 | 2 |
 | Radiator contaminated with trans oil. | Andrew Jennings | 7 | 1 |
 | Trouble with TT diagnostics | Scott Wilkes | 3 | 1 |
 | Intake lines | Marc Hoffmann | 2 | 1 |
 | Oil leak help | Michael O'Driscoll | 20 | 1 |
 | Inlet manifold still giving me greif ... | Aaron Casey | 20 | 1 |
 | Fuel pump ECU | Sebastian Grant | 4 | 1 |
 | How to remove the intake manifold. | Aaron Casey | 8 | 1 |
 | Acceleration issue | Tyson Adams | 5 | 1 |
 | Cold start problem, help please | Scott Wilkes | 38 | 2 |
 | HELP Car Splattering | Rob Rojo | 26 | 1 |
 | How easy to R&R 1JZ engine and tranny? | David Grab | 2 | 1 |
 | What is this? | Daniel Clarke | 8 | 1 |
 | Part numbers for 2jz | Aaron Casey | 5 | 1 |
 | 1JZ servicing | Ross Pesina | 6 | 1 |
 | Diagnostics mode question | Boris Siljanoski | 2 | 1 |
 | Standard 2j fuel | Aaron Casey | 3 | 1 |
 | 2jz measurements | James Meikle | 1 | 1 |
 | Ejecting crank pully cost? | Matchy Loi | 9 | 1 |
 | Swapping a 1JZ-GTE to 2JZ-GTE | Martin Costa | 6 | 1 |
 | Water hose kits? | James Cahir | 13 | 1 |
 | ACL Race bearings in 1JZ? | Fabian Bordon | 6 | 1 |
 | Weird noise after dropping the coolant | James Wilson | 6 | 1 |
 | Jzz30 in limp mode deiving me crazy | Ilia Raykhtin | 11 | 1 |
 | Converting to Electric fans: Can I use the stock water pump? | Matthew Sharpe | 12 | 1 |
 | Best option to replace TT head gasket? | Daniel Clarke | 17 | 1 |
 | 1JZ MISFIRING (HAVE TRIED EVERYTHING STILL CANT FIGURE IT OUT) | Andrew Beutel | 25 | 1 |
 | Cooling flush question | Austen Menze | 5 | 1 |
 | Converting 1jz rear sump to front sump Help | Sam Watson | 9 | 1 |
 | Inlet manifold pics please...bit lost. | James Wilson | 12 | 1 |
 | Cooling system check - Melbourne's South East | Karl Vanzuyden | 7 | 1 |
 | Help need ideas 1jzgte in limp mode | Justin Simpson | 39 | 2 |
 | New soarer T04 Conversion, some questions re this | Blake Gloyn | 15 | 1 |
 | Need INFO ASAP ... | Daniel Clarke | 16 | 1 |
 | Been busy this past week ... | Scott Wilkes | 2 | 1 |
 | SC300 SC400 Factory Manual Download - 4000+ Pages FREE | Costa Tsimiklis | 22 | 1 |
 | Possible to fit cruise to a TT that didn't come with it standard? | Scott Wilkes | 4 | 1 |
 | Car problem is giving me problems. Help me diagnose. | Cihan Aday | 24 | 1 |
 | Cooling issues! What should I look at? | Aiden Cheese | 66 | 3 |
 | Electrical diagram for the TT engine? | Aiden Cheese | 11 | 1 |
 | Stock radiator vs. aftermarket radiator | Ken Brahniuk | 18 | 1 |
 | Strange sounding problem, | Cameron Laufer | 25 | 1 |
 | Weak midrange | Daniel Clarke | 18 | 1 |
 | Thread pitch - Timing belt tensioner pulley?? | Matthew Sharpe | 7 | 1 |
 | Strange Noise? | Austen Menze | 21 | 1 |
 | Small Problem | Scott Wilkes | 8 | 1 |
 | So I need to fit a fuel tap/drain valve... | Daniel Clarke | 4 | 1 |
 | Flywheel question | Tim Hutchings | 1 | 1 |
 | Dead 1jz need advice | James Johnson | 6 | 1 |
 | Changing cam cover gaskets | Matthew Sharpe | 17 | 1 |
 | Another 100K service question | Daniel Panickar | 3 | 1 |
 | My base timming 30deg btdc,should b 10? | Austen Menze | 4 | 1 |
 | Difficult to start the engine sometimes | Sam Tow | 3 | 1 |
 | Limp mode | Paul Ince | 9 | 1 |
 | Car won't start when warm | Shane Haverkamp | 11 | 1 |
 | Pulley kit problems | Nathan Hlad | 8 | 1 |
 | Oil cooler fitment | Nathan Hlad | 10 | 1 |
 | Tips on launch technique | Rob Rojo | 57 | 3 |
 | My soarer wont idle when its cold | Austen Menze | 25 | 1 |
 | Diff ratio on a manual TT | Daniel Clarke | 6 | 1 |
 | Problems, 3 possble causes? | Ty Mackay | 29 | 1 |
 | Leak in radiator | Ty Mackay | 6 | 1 |
 | Base timing is out? | Austen Menze | 8 | 1 |
 | How much power can the auto box handle?? | David Grab | 13 | 1 |
 | TT timing belt | Dave Rose | 21 | 1 |
 | Warning Error after heavy foot | Danny Dinh | 5 | 1 |
 | Oil filter question | Walter Gillmore | 27 | 1 |
 | Dash warning light says CHARGE | Aiden Cheese | 28 | 1 |
 | What oil to run in 1jzgte soarer | David Grab | 57 | 3 |
 | 1jzgte torque main cap specs | Ben Lucas | 3 | 1 |
 | 150K service | Kevin Trac | 2 | 1 |
 | Rawring fan like a truck | Matthew Sharpe | 6 | 1 |
 | Just got new manual soarer | Kevin Trac | 1 | 1 |
 | Manual conversion speedo sender a cheaper way | Darren Driscoll | 2 | 1 |
 | Throttle cable | Daniel Clarke | 8 | 1 |
 | Yes, Another won't idle thread but different.. | Austen Menze | 14 | 1 |
 | Knock sensor probs | Carlo Cervo | 6 | 1 |
 | Holy Smokes! Think I just blew my headgasket! | Michael Larcombe | 22 | 1 |
 | Trans cooler question. | Tim Hutchings | 20 | 1 |
 | A-Pillar pod for the soarer. | Daniel Panickar | 24 | 1 |
 | Another post for Tref regarding stuck windows | Peter Nitschke | 2 | 1 |
 | Whats going on? BHG? | Narvey Vilaythong | 9 | 1 |
 | Soarer Problems misfire during mid RPM really need help | Daniel Clarke | 9 | 1 |
 | Worn plastic cogs | Shane Haverkamp | 6 | 1 |
 | Timing Belt | Nickel Quimada | 9 | 1 |
 | 1jz gte rebuild | David Duffell | 9 | 1 |
 | PCV operation under boost? possible boost leak? | David Barnes | 3 | 1 |
 | Replacing PCV valve with 2jz valve | Dale Holan | 13 | 1 |
 | Radiator repair in Maroubra | Danny Dinh | 3 | 1 |
 | Modifications..what to do, what to do.... | Michael Bradshaw | 18 | 1 |
 | External wastegate installation help? | Chris Davey | 9 | 1 |
 | Oil Test | Scott Casey | 6 | 1 |
 | Stutter on cold start | David Barnes | 2 | 1 |
 | Tricks to removing PCV grommet? | Frank Csapo | 7 | 1 |
 | RANDOM STALL | Nathan Hlad | 6 | 1 |
 | Smoke from mates soarer | Scott Wilkes | 12 | 1 |
 | Took some photos tonight ... | Scott Wilkes | 12 | 1 |
 | With Oil Change Comes Loss of Power :S and Exhaust question. | Aiden Cheese | 9 | 1 |
 | How long before | Michael Lucas | 5 | 1 |
 | Car backfiring under load in upper revs | Scott Wilkes | 18 | 1 |
 | REAR LIGHT error message | Ken Yo | 5 | 1 |
 | Overheating Problem.. | Matthew Werner | 29 | 1 |
 | COOLANT LEAK | Scott Wilkes | 4 | 1 |
 | Detonation ... | Shane Austin | 13 | 1 |
 | Ventilation hose between the cam covers | Ben Lipman | 6 | 1 |
 | Stock BOV connection help | Eddie Prasad | 4 | 1 |
 | Holy smoke. Is it valve stems, turbos or what? | Matthew Werner | 4 | 1 |
 | Loss of power when warmed up | Austen Menze | 28 | 1 |
 | Miss Fire at full throttle | Josh Totall | 14 | 1 |
 | Aux fan kicking in | Scott Wilkes | 3 | 1 |
 | Rear Diff mount bushes part number? | Scott Wilkes | 1 | 1 |
 | Need a Perth, WA Mechanic Urgent!!! | Keenan Edinger | 3 | 1 |
 | "Normal" oil pressure? | Frank Csapo | 15 | 1 |
 | Apexi AVCR boost controller? | Scott Wilkes | 43 | 2 |
 | Looking for ballpark figures | Walter Gillmore | 6 | 1 |
 | Hi Guys can I use E10 safely | Andrew Hargreaves | 15 | 1 |
 | What is this? | Chris Prak | 4 | 1 |
 | 02 Sensor Replacement | Scott Wilkes | 17 | 1 |
 | Broken fan shrouds | Matthew Sharpe | 2 | 1 |
 | Idling Problem | David Tra | 3 | 1 |
 | Sluggish / no boost HELP | Josh Totall | 9 | 1 |
 | V mount | Dave Cazes | 6 | 1 |
 | Need Help Diagnosing A Mechanical Problem | David Grab | 7 | 1 |
 | 1JZ seals | Dave Cazes | 24 | 1 |
 | Blueish smoke on warm up | David Tra | 21 | 1 |
 | Car won't rev past 2000rpm | Jeff Bedsor | 6 | 1 |
 | Water pump gasket partnr.?? 1JZ-GTE | James Johnson | 10 | 1 |
 | Who has a Supra fuel pump? | Daniel Clarke | 9 | 1 |
 | Lock problem | Yang Luo | 7 | 1 |
 | ECU question | James Cahir | 7 | 1 |
 | Exhaust cam gear | Daniel Clarke | 8 | 1 |
 | Idle speed low | Daniel Panickar | 1 | 1 |
 | Slow oil leak | Michael Lucas | 4 | 1 |
 | O2 sensor | David Key | 4 | 1 |
 | Car is Misfiring/Popping when hitting boost | Manual Kalianis | 18 | 1 |
 | What to do now ? | Daniel Clarke | 9 | 1 |
 | Need a part number | Andrew Keddie | 4 | 1 |
 | O2 sensor replacement | David Key | 15 | 1 |
 | Bov placement | Matchy Loi | 3 | 1 |
 | Where to now? | Matthew Tai | 6 | 1 |
 | Airfilter? | James Harris | 22 | 1 |
 | Soarer JZZ30 1JZGTE Part No.'s | Bobby Green | 3 | 1 |
 | Engine mounts | Cameron Laufer | 7 | 1 |
 | 2jz cam gears on a 1jz | James Harris | 30 | 2 |
 | Manifold pressure vs boost via EBC pressure | James Harris | 7 | 1 |
 | Blowing dipstick ... | Adam Barry | 31 | 2 |
 | Would this work | Luke Burt | 4 | 1 |
 | Overheating after shut down. | Andrew Ferres | 37 | 2 |
 | Enigne 'stuttering' or losing power in heavy rain | Geoff McHeyzer | 8 | 1 |
 | Best PLace to get a service in Brisbane? | James Harris | 5 | 1 |
 | Smokin............ | Chris Prak | 9 | 1 |
 | Fan problems | Andrew Keddie | 1 | 1 |
 | 1JZ Crank pulley. My bolts may be stripped. | Matchy Loi | 5 | 1 |
 | Power steering issue | Brett Cutts | 2 | 1 |
 | Water gushing noises? | Brett Cutts | 5 | 1 |
 | Replacing water pump | Danny Dinh | 14 | 1 |
 | So i found this | Michael Lucas | 9 | 1 |
 | Blue Smoke and Sputter | Christopher Clarke | 5 | 1 |
 | Rattling in engine bay | Andrew Keddie | 2 | 1 |
 | Building a 1jz | Michael Keen | 24 | 1 |
 | Soarer wont start | Daniel Clarke | 21 | 1 |
 | Got a rattle | Owen Hayes | 6 | 1 |
 | Vibration through car at idle??? | Scott Wilkes | 12 | 1 |
 | More Problems AGAIN! | Ty Mackay | 12 | 1 |
 | Throttle Position Sensor adjustment???? | Scott Wilkes | 1 | 1 |
 | Whining noise | Mike Dobkin | 12 | 1 |
 | Hks cam gears | Nathan Hlad | 5 | 1 |
 | Where to buy tein ha's | Michael Lucas | 7 | 1 |
 | Are these guys trying to rip me off? | Mark Tierney | 9 | 1 |
 | Timing Belt Changeover | Shane Haverkamp | 11 | 1 |
 | 1jzgte problems, not idling properly, stalling... | Kym Modra | 16 | 1 |
 | TT electric fans | Don Bagnall | 14 | 1 |
 | Replacing valve stem seals | Rob Rojo | 2 | 1 |
 | JZZ30 Powersteering Pump | Max Rockatanski | 7 | 1 |
 | Oil leak | Scott Wilkes | 7 | 1 |
 | New radiator on ebay | Danny Dinh | 7 | 1 |
 | What to do before fitting a replacement 1J? | Shane Sartori | 11 | 1 |
 | 440cc vs. 550cc | Cihan Aday | 10 | 1 |
 | 1995 TT Soarer OEM radiater part number? | Omar Amin | 1 | 1 |
 | Basic Help | Rob Rojo | 11 | 1 |
 | Hks pws fluid cooler | Nathan Hlad | 14 | 1 |
 | Bugger, leaking radiator | Daniel Clarke | 11 | 1 |
 | JZZ30 and JZX90...same factory ECU? | Peter Nitschke | 29 | 1 |
 | Ok Another issue, with boost ... | Rob Rojo | 18 | 1 |
 | Will this be a straight fit? | Daniel Clarke | 2 | 1 |
 | Need help soarer tt 91 | Matthew Werner | 12 | 1 |
 | Yay - Another Joyous Fluid Leak Onto My Driveway..... | Russell Rohde | 27 | 1 |
 | Wont rev past 2500 | Steven Nanevski | 9 | 1 |
 | I'm back with another problem. ... | Patrick Robinson | 4 | 1 |
 | New to 1j's | Lenny Berkefeld | 6 | 1 |
 | Where to buy a cam kit? | Tref Abbott | 7 | 1 |
 | Stalling car | Daniel Clarke | 13 | 1 |
 | Need blinky dash fix - will pay cash | Danny Chatterton | 11 | 1 |
 | How to perform a diagnostic check on tt soarer | Ben Lipman | 2 | 1 |
 | Serpentine belt help?? | Ben Lipman | 3 | 1 |
 | TCS Voltage?? | Scott Wilkes | 2 | 1 |
 | Ecu pin out, for 3 row pins on 1j ecu | Danny Chatterton | 2 | 1 |
 | Radiator problems | Ty Mackay | 18 | 1 |
 | PLEEEASE HELP ! | Patrick Robinson | 23 | 1 |
 | Stainless Steel Radiator.. | Ty Mackay | 6 | 1 |
 | Have My Turbos Gone BOOM BOOM =( | Ty Mackay | 17 | 1 |
 | I need tyres that Grip.... | Mark Pattel | 37 | 2 |
 | Fitted oil filter relocation kit, but now no oil pressure? | Ben Lipman | 4 | 1 |
 | 04111-46033 or 04111-46032 ? .. gasket kit question | Kane Chan | 3 | 1 |
 | Fan Clutch | Mike Dobkin | 2 | 1 |
 | Underdrive Pulleys | Daniel Clarke | 40 | 2 |
 | Coolant/Radiator | Ty Mackay | 16 | 1 |
 | I need a valve cover gasket set for the 1JZ.. shipped to Canada | Dale Holan | 6 | 1 |
 | Boost controller | Nathan Hlad | 9 | 1 |
 | Power upgrades | Nathan Sheehan | 30 | 2 |
 | PASSENGER SIDE FENDER. | Ty Mackay | 7 | 1 |
 | Power steering fluid, nooooooooooooooooooo ! | Michael Keen | 5 | 1 |
 | Big power problem | Leo Khoshaba | 33 | 2 |
 | 1jz pcv gasket part number needed | Aaron Casey | 5 | 1 |
 | Wheel alignment | Chris Prak | 2 | 1 |
 | I think my 1j has been opened? | Steven Anderson | 11 | 1 |
 | Tyres?..? | George Funa | 10 | 1 |
 | Did a bit of polishing | Daniel Clarke | 18 | 1 |
 | AHHH FACCCK.....GAD DAM WATERPUMP CRACKED.......AGAIN!!! | Mike Dobkin | 12 | 1 |
 | Car wont start | Mal Nicholson | 9 | 1 |
 | Idle and acceleration problems after changing Harmonic balancer. | Matchy Loi | 18 | 1 |
 | Quick Help On Blocking Off Stock BOV | Luke Burt | 10 | 1 |
 | How ANNOYING! | Ty Mackay | 23 | 1 |
 | What You Guys Think? | Ty Mackay | 6 | 1 |
 | My 1JZ runs like a muscle car... ? | Kane Chan | 14 | 1 |
 | GT17 turbo...... any good??????? | David Tra | 9 | 1 |
 | Turbo timer? | Andrew Stewart | 29 | 1 |
 | COIL PACKS + EPOXY | Daniel Clarke | 12 | 1 |
 | 1JZ AUTO max power | Benjamin Burgess | 20 | 1 |
 | Coil Packs | Ben Socratous | 5 | 1 |
 | RADIATOR HOSES AND LOCATIONS | Gary Poloskei | 8 | 1 |
 | MORE Problems....Error message... | Peter Nitschke | 24 | 1 |
 | Trust radiator | Nathan Hlad | 9 | 1 |
 | Pipe size | Andrew Magee | 1 | 1 |
 | New Soarer Big Problems.i think | Ty Mackay | 30 | 2 |
 | Car shuting down on start up. | Paul Bernasconi | 4 | 1 |
 | OH LAWD.....Another Waterpump Issue | James Harris | 11 | 1 |
 | WARNING LIGHT :S !! | Rob Rojo | 2 | 1 |
 | O2 sensor reactions, | Nathan Sheehan | 6 | 1 |
 | Scary Moment!! | Adrain Parsons | 6 | 1 |
 | V-spec or r-spec ? | Mark Tierney | 8 | 1 |
 | 1JZGTE spark plugs 91-96 BKR6EIX will fit? | Kane Chan | 4 | 1 |
 | Help With Radiator Hose | Ben Socratous | 4 | 1 |
 | Annoying problem | Luke Wright | 7 | 1 |
 | Quick question | Adrain Parsons | 9 | 1 |
 | PROBLEMS!! | Ty Mackay | 32 | 2 |
 | Coil Packs + Cracks + Araldite | Ty Mackay | 24 | 1 |
 | BOV Questions | Christian Molenda | 3 | 1 |
 | Experiencing abit of lag | Robert Day | 4 | 1 |
 | Boost gauge problem | Shane Haverkamp | 4 | 1 |
 | No power below 3K RPM | David Tra | 11 | 1 |
 | What next? | Dave Cazes | 6 | 1 |
 | Replacing Cam Cover Seal | Brendan McGannon | 4 | 1 |
 | Where to get radiator in Melbourne | Matchy Loi | 4 | 1 |
 | 1GGTE Help!!!!! Plus Hi | Shane Haverkamp | 5 | 1 |
 | Engine noise TT | Tom Richards | 7 | 1 |
 | Replacement water pump | John Alley | 4 | 1 |
 | Odd Coolant Leak | Peter Nitschke | 8 | 1 |
 | Comp test | Scott Wilkes | 19 | 1 |
 | HELP!!!!! Error Code ECT 62 and EFI 14 | Sean Munroe | 3 | 1 |
 | Bov or Pod making noise? | Shane Haverkamp | 14 | 1 |
 | Bottom end knock | James Harris | 14 | 1 |
 | Stock BOV sound | James Linton | 22 | 1 |
 | Stalling, black smoke, backfiring | James Linton | 18 | 1 |
 | What do I need for a good tune-up 1JZ-GTE | James Harris | 11 | 1 |
 | Butterfingers, need some help | Shane Haverkamp | 12 | 1 |
 | Orange Warning light?? | Tristan Maiolo | 6 | 1 |
 | Diagnostic port?? | Scott Wilkes | 8 | 1 |
 | Low Idle problem - found solution! | Cihan Aday | 5 | 1 |
 | SPARK PLUG QUESTION | Matthew Sharpe | 7 | 1 |
 | Fuel Pump stuffed??? EMU | Daniel Clarke | 3 | 1 |
 | Paddle clutch? | David Grab | 6 | 1 |
 | Dyno Results | Matthew Standage | 17 | 1 |
 | The big deal about the 1.5 JZ | Dave Cazes | 23 | 1 |
 | Standard clutch replacement question | Scott Wilkes | 18 | 1 |
 | Extreemly rough on cold start, | Brett Harrison | 2 | 1 |
 | A few problems | Christian Molenda | 16 | 1 |
 | Sandwich plate...what thread size? | Ben Lipman | 4 | 1 |
 | A little help Diagnosing my smokey Soarer | James Harris | 25 | 1 |
 | WA Soarer Mechanics | Nathan Sheehan | 7 | 1 |
 | Axle tramp something shocking! | Mark Pattel | 18 | 1 |
 | HELP!! Pipe Connection? | Andrew Ferres | 22 | 1 |
 | Blow off valve adapter plate??? | Andrew Hargreaves | 1 | 1 |
 | HELP! suspected speed sensor failure | Andrew Alfonso | 2 | 1 |
 | ATTENTION DON BAGNALL.ASSISTANCE NEEDED.MECHANICAL TT ISLE.GENERAL ... | Patrick Robinson | 15 | 1 |
 | TT water line help needed | Michael Keen | 2 | 1 |
 | Intermitent reading temp gauge? | Michael Keen | 3 | 1 |
 | WHAT THE FRIGGIN HELL HAPPENED HERE!!!!!! | Patrick Robinson | 13 | 1 |
 | Sounds bad | James Cahir | 2 | 1 |
 | DAMMIT!!!!! | Scott Wilkes | 4 | 1 |
 | Changing a knock sensor | Garth Williams | 12 | 1 |
 | Big power cooling issues? | James Macarin | 32 | 2 |
 | Leaking radiator, opinions/options | Ben Lipman | 11 | 1 |
 | Engine bearing | Garth Williams | 17 | 1 |
 | Oil burning???? | Brendan McGannon | 21 | 1 |
 | 5 spd manuel TT cars help needed | Dayle Gray | 5 | 1 |
 | NOS Advice | Callum Finch | 18 | 1 |
 | Torque for flywheel and pressure plates | Dayle Gray | 8 | 1 |
 | A few more quick questions for the Soarer Gurus | Michael Keen | 8 | 1 |
 | Shift kit in..Now i cant stop Grinning. | Matt Sartori | 2 | 1 |
 | Dif oil | Daniel Clarke | 21 | 1 |
 | Misfiring when cold | Ben Vandie | 14 | 1 |
 | Soarer not starting right | Danny Dinh | 19 | 1 |
 | Engine oil question again | Yang Luo | 11 | 1 |
 | 92 Twin turbo soarer Manual Fuel economy?? | Antonio Hunt | 15 | 1 |
 | On-road car reset. | Lawrence Ostle | 4 | 1 |
 | Low idle all of a sudden???? | Scott Wilkes | 8 | 1 |
 | 2j with 1j tranny | Blake Gloyn | 7 | 1 |
 | Car Sluggish Too start | Rob Rojo | 8 | 1 |
 | Intercooler after swap | Ben Lipman | 2 | 1 |
 | Oil Cap - Quick question... | Don Bagnall | 5 | 1 |
 | AHHH FRIGGG.........DAM CAR SPUTTERING NOW | Dave Rose | 18 | 1 |
 | Harmonic Balancer | Michael Keen | 5 | 1 |
 | Various vacuum line problems (with pics) | Michael Keen | 10 | 1 |
 | Water temp guage problem? | Scott Wilkes | 4 | 1 |
 | Interference valve engine? | Scott Wilkes | 5 | 1 |
 | TT wont rev past 2500...then wants to die...EFI 41? TPS? | Sokoni Forsythe | 83 | 4 |
 | Fitting Cruise Control? | Brett Harris | 3 | 1 |
 | Water temp, oil pressure and trans temp sensor points?? where are t... | Christian Molenda | 2 | 1 |
 | Low cost last minute horse power.. Need input. | Matthew Sharpe | 25 | 1 |
 | Oil Pressure Warning | Steven Nanevski | 4 | 1 |
 | WATERPUMP ITEM NUMBER | Patrick Robinson | 3 | 1 |
 | Starter Motor | Don Bagnall | 6 | 1 |
 | Questions for the Soarer Gurus of SC | Daniel Clarke | 7 | 1 |
 | WATER PUMP QUICK FIX | Patrick Robinson | 5 | 1 |
 | Need some help | Don Bagnall | 19 | 1 |
 | FIRST TIME THIS HAPPENED TO ME...... | Patrick Robinson | 23 | 1 |
 | Q-U-ESTION | Patrick Robinson | 8 | 1 |
 | Water pump leak | Matt Newman | 6 | 1 |
 | I know you're all jelous, so I'll take your abuse. | Cameron Stanley | 13 | 1 |
 | Car starts idles for 2 seconds then stalls | Danny Dinh | 25 | 1 |
 | Tuned | Chris Prak | 18 | 1 |
 | Oil leak from head gasket? | Chris Prak | 9 | 1 |
 | Cam seals | Gary Rollason | 7 | 1 |
 | Schreeching noise on start up | Brian Timms | 10 | 1 |
 | Fuel Cut? | Nickel Quimada | 7 | 1 |
 | IAT Sensor Signal? | Anthony Weller | 7 | 1 |
 | TT More torque in the lower rev range? | David Wojcik | 17 | 1 |
 | Leaking something from engine ! | James Cahir | 15 | 1 |
 | Cruise control | Cameron Stanley | 1 | 1 |
 | Compression Tests + Methods | Cihan Aday | 24 | 1 |
 | Twin turbo condition question | Braden Murdoch | 18 | 1 |
 | Making it run smoothly..how? (clutch, tranny idle etc) | Tume Penttinen | 8 | 1 |
 | Standard 1994 TT what are part numbers for | Don Bagnall | 9 | 1 |
 | Opinions needed, Just a BHG or not? | Scott Ferguson | 6 | 1 |
 | Overheating issues | Daniel Clarke | 15 | 1 |
 | Belt size after removing AC compressor? | Ben Lipman | 7 | 1 |
 | Radiator Fan Blade | Neil Griffiths | 7 | 1 |
 | Window Prob | Peter Nitschke | 6 | 1 |
 | Leaking power steering fluid! | James Johnson | 14 | 1 |
 | What is this in diagnostic port? | Joshua Rao | 14 | 1 |
 | Help - TT rear brake disc removal | Fran Valdivia | 4 | 1 |
 | Breaking down at 4200rpm | Daniel Clarke | 21 | 1 |
 | OVER HEATING PROBLEM | Alen Sadikovic | 10 | 1 |
 | TT pwr steer bearing | Don Bagnall | 10 | 1 |
 | Low boost and high boost | Daniel Clarke | 8 | 1 |
 | 5000rpm vibration.... and other problems now | Daniel Clarke | 18 | 1 |
 | Low power. puzzled. | Christian Molenda | 3 | 1 |
 | Smoke on startup once in ever 100 starts | Scott Gates | 4 | 1 |
 | Need Help with NSW Blue slip in Tweed Heads | Behruz Jamshidi | 1 | 1 |
 | Oil Temperature too high! | Anuradha Vithanage | 27 | 1 |
 | Starting issues when hot | Brian Rozario | 5 | 1 |
 | Slight Pinging/Mis firing | Louis Angelopoulos | 22 | 1 |
 | Thred pitch of oil filter | Sebastian Grant | 8 | 1 |
 | Quick question | Karl Martin | 3 | 1 |
 | Help with a quote | Cameron Stanley | 19 | 1 |
 | Big issue with my car during the drags | Peter Nitschke | 43 | 2 |
 | Clunk noise from front of car-Engine mounts? | Ben Lipman | 11 | 1 |
 | Torque settings for engine mounts? | Ben Lipman | 1 | 1 |
 | Dyno results | Daniel Clarke | 6 | 1 |
 | Need help | Dave Cazes | 20 | 1 |
 | Power Stearing Seals | Maurice Diggler | 4 | 1 |
 | Wheel Bearing Question | Ken Tran | 15 | 1 |
 | Underdrive pulley - harmonic balancer | Yang Luo | 6 | 1 |
 | New dyno results, also some things you dont know yet... | Cihan Aday | 18 | 1 |
 | Car Overheating STILL! | Christian Zimmer | 11 | 1 |
 | How to tell what type of turbo you have? | Blake Davies | 3 | 1 |
 | Custom piping | Daniel Clarke | 3 | 1 |
 | ECU coolant temp sensor location | James Cahir | 5 | 1 |
 | 100,000km Service, What Parts Are Needed ? | James Harris | 17 | 1 |
 | Does a supra radiator fir in zz30? | James Harris | 6 | 1 |
 | 1JZ crank puuley tension nm | Jayson Nicoll | 4 | 1 |
 | HELP!! Car dying | Ryan McDonough | 11 | 1 |
 | E-manage map sensor installation | Cihan Aday | 6 | 1 |
 | Strange Stalling | Adam Olsen | 7 | 1 |
 | Help please! Oil not draining | Ryan McDonough | 22 | 1 |
 | Replaced timing belt and now this!?? | Alex Aguirre | 16 | 1 |
 | 7MGTE spark plugs in 1JZ | Christian Molenda | 3 | 1 |
 | Cheap oil relocation kit? | Ben Evans | 11 | 1 |
 | Lost boost and a rattle on turbo side of engine. | Paul Kalie | 4 | 1 |
 | Thermostat - what is the factory opening temperature? | Jeff Bedsor | 20 | 1 |
 | Did an oil change and now knocking noise in engine | James Brodie | 11 | 1 |
 | Power problems-solved! | Brendan McGannon | 5 | 1 |
 | Help please urgent | Michael Keen | 17 | 1 |
 | HKS FCD JZX100 install | Jayson Nicoll | 1 | 1 |
 | Dash Message | Anuradha Vithanage | 48 | 2 |
 | Fan/radiator Shroud? Quick Question | Blake Davies | 7 | 1 |
 | Modified soarer TT engine oil leaking? | Trent Osborne | 29 | 1 |
 | Anyone got a capillary oil pressure guage? | Josh Brown | 1 | 1 |
 | Engine revs to 2000rpm then drops to 500rpm | Craig Morris | 20 | 1 |
 | Dirty oil black and white smoke | Davin Kemshead | 6 | 1 |
 | My dyno dynamics dyno run.opinions | Damien Murray | 4 | 1 |
 | Has Timing Belt Slipped ? | Sami Ansari | 13 | 1 |
 | Looking for a mechanic around parramatta | George Funa | 2 | 1 |
 | The best engine oil to use? Yes, I know this gets brought up a lot. | Blake Davies | 42 | 2 |
 | Need Help dont know whats going on!! | Paul Heginbotham | 4 | 1 |
 | How do you remove a Boost Gauge? | Blake Davies | 8 | 1 |
 | Mysterious hose?? | Joshua Rao | 14 | 1 |
 | Almost Getting Hot | Davin Kemshead | 9 | 1 |
 | Error code in Japanese | Christian Molenda | 8 | 1 |
 | A Question out of curiosity | Aaron Grenadier | 6 | 1 |
 | Shift Performance Oil Cooler & Relocater Kit. | Blake Davies | 33 | 2 |
 | Main seal | David Henderson | 5 | 1 |
 | Silly idle problem help | Michael Keen | 31 | 2 |
 | Whats the normal temperature for a 1JZ? | Cihan Aday | 3 | 1 |
 | Spring Tune Up | Grant Franz | 3 | 1 |
 | New turbos on my car, now overheating. | Tim Hutchings | 9 | 1 |
 | Power problems | Daniel Clarke | 11 | 1 |
 | Idle problem | Tume Penttinen | 6 | 1 |
 | Can someone point me to the waterpump/timing belt replacement tutor... | Daniel Clarke | 29 | 1 |
 | Speed Sensor/gear changing | Vineet Naidu | 1 | 1 |
 | Greddy Profec E-01 (anyone using it?) | Jeff Bedsor | 6 | 1 |
 | What is the normal Engine compression for 1JZ? | Shaun Chiew | 5 | 1 |
 | Calling All Electrical Gurus - Urgent Help Needed | Brian Timms | 4 | 1 |
 | Difference between aristo gearbox vs soarer vs supra mkiv | Niclas Backstrom | 1 | 1 |
 | Serpentine belt replacement | Ben Lipman | 11 | 1 |
 | Knocking on Start Up | Brian Timms | 55 | 3 |
 | Looking for some advice on planned gt35r setup | Karl Martin | 19 | 1 |
 | Weird idle problem on my TT | Brian Timms | 27 | 1 |
 | Creaking noise when braking slowly | Brian Timms | 9 | 1 |
 | ID for a part | Brian Timms | 3 | 1 |
 | Help about power steering? | Vinh Bui | 2 | 1 |
 | Change from viscous - hydro fan and standalone gearbox cooler | Damien Murray | 7 | 1 |
 | Where is the ABS unit? | Blake Davies | 4 | 1 |
 | Vibration when standing still | Peter Nitschke | 11 | 1 |
 | Need some help with this ****ing crank pully | Brian Timms | 29 | 1 |
 | Water pump leak | Peter Nitschke | 5 | 1 |
 | How to remove diff? | Daniel Clarke | 8 | 1 |
 | Predator Intercooler and Radiator package going cheap | Jeff Bedsor | 45 | 2 |
 | Idleing to fast | Suphachai Sangasri | 9 | 1 |
 | How do I take off the starter motor? | David Wilson | 3 | 1 |
 | Anyone live near Laurieton / West Haven NSW? | Brett Jones | 2 | 1 |
 | Turbo manifold removal | Tim Hutchings | 32 | 2 |
 | TT Radiator Top Tank | Peter Nitschke | 3 | 1 |
 | Tensioner Pulley Part Number | Brian Timms | 10 | 1 |
 | Aftermarket radiators | Andrew Hargreaves | 6 | 1 |
 | I just ordered new "Number Plates" | Anton Jones | 23 | 1 |
 | Leaky diff | Anton Jones | 3 | 1 |
 | 2jz/1jz conversion | Andrew Keddie | 3 | 1 |
 | Weird O2 Sensor 'observation' | Brian Timms | 4 | 1 |
 | How much to replace power steering and alternator? | Gavin Smith | 20 | 1 |
 | Fuel Cap area hiss | Mike Thomas | 12 | 1 |
 | Changing Sprk Plugs - oil flippin' everywhere!! | Matthew Crawford | 6 | 1 |
 | Rough idle and juddering/stuttering at low RPM | Michael Keen | 11 | 1 |
 | TT Auto - Dinted Pipes | Daniel Clarke | 4 | 1 |
 | Oil Return Lines | Chris Prak | 12 | 1 |
 | Rear grinding noise | Ken Tran | 11 | 1 |
 | Weird problem. | Michael Keen | 4 | |
