Thursday, December 06, 2007 - 02:54 pm, by: Rob Rojo(Rob_tt)
I have just ran the car at WSID got a 13.7@102.24 which is was pretty happy with. Current mods are FMIC, 3" Cat back single exhaust, 13psi, Pod filter. I would like some opinions on what mod to do next and am looking to do it on a budget. Any suggestions would be appreciated
Thursday, December 06, 2007 - 03:18 pm, by: Jason Underwood(Jay666)
Finish off the exhaust, get the dumps done. Also maybe get a piggyback fuel computer to get your air/fuel ratios right, (SAFC maybe) get a good tune. Then go back and try again.
Thursday, December 06, 2007 - 06:35 pm, by: Rob Rojo(Rob_tt)
I was considering holding off on new dumps as a single turbo conversion maybe in the pipe line, Any recommendations on the piggy back ecu, what about bigger injectors?. How much difference would a shift kit would make to times?
Friday, December 07, 2007 - 07:37 pm, by: Daniel Clarke(Dieseltrain)
IM not a fan of SAFC's as they constantly change the timing and fuel. You end up with an slmost irregular signal to the ecu. The FCD clamps it at one point which i find safer.
Myself and Braden ( aka Ribfeast ) and AKA all made good times and good numbers with the FCD only. Much cheaper than the safc, and almost everytime a car fitted with the safc went on the dyno at the dyno day, they all had to be trimmed back as they were on the edge.
Sunday, December 09, 2007 - 11:30 am, by: Rob Rojo(Rob_tt)
When driving the car at high RPM it feels as though it is running to lean, I dont want to up the boost any more until I know for sure that it is not to lean. how is the best way to check this?
Sunday, December 09, 2007 - 06:30 pm, by: Charlie Ters(Ul05st)
Rob Rojo wrote on Sunday, December 09, 2007 - 11:30 am:
look in the back window and look out for smoke=rich seriously, dyno is your friend on this one, save up $60, and get a 3 run pass, use one for normal, one with more boost etc.
Wednesday, February 27, 2008 - 04:51 pm, by: Charlie Ters(Ul05st)
FCD= fuel cut defender (the thing that clamps he voltage to around 3.7v, so the ecu wont cause boost cut when seeing around 13psi+)
get an emanage....dont waste your time with a SAFC, you might as well build a jaycar fuel controller, at least that thing has up to 128 points of tune
if you only plan to run these mods you already have for eternity, then a safc is fine, but if you ever wish to update.... stick to a emanage.... blue at minimum, ultimate if you have an extra $400 to play with (+150 for a boost sensor for 3 bar tuning woot!)
Thursday, February 28, 2008 - 04:09 pm, by: Rob Rojo(Rob_tt)
Thanks Charlie!, I just installed my S-AFC about two weeks ago, I have heard of a few good results using them so I hope it was worth it. It was cheap enough... Whats better pod filter or BFI?
