Not listed in that diagram, but kinda sits on the engine side of the intake manifold, approximately where the 25733A is listed on the diagram above. Somewhat circular black metal arrangement.
Sunday, December 16, 2007 - 05:09 pm, by: Anton Jones(Alj)
When you guys say 'service' this ICV with Carby cleaner. Do you mean remove the black circular piece from the metal housing or just clean it out as a 'whole' once removed?
Thursday, December 27, 2007 - 02:11 pm, by: Braden Murdoch(Ribfeast)
Just be careful as some ISCVs have some plastic bits inside which will be melted/damaged by carby cleaner. Use WD40 as it is a bit more gently. It's a pity the 1JZ ISCV is unable to be pulled apart and cleaned properly
