  Soarer Central * Mechanical - TT * General Mechanical * Ah wierd ticking noise from head area? Previous Previous    Next Next
Michael Askevold
wa
soarer tt
Reg: 12-2007
Thursday, January 10, 2008 - 11:05 pm, by:  Michael Askevold (Mikiesoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah got this strange ticking noise from under the rocker cover,(1jz) it starts around 2500 and disappears after 4500, under power and and the same again off the juice, but ok at idle. the engines done 130,000 and goes well. I've had the car for a year and i do drive it hard, mmm hope i havn't broken any thing. can any one shed some light,,... cheers
Scott Ferguson
Alberta
Soarer GTT-L
Reg: 07-2006
Friday, January 11, 2008 - 01:40 am, by:  Scott Ferguson (Scott_ferguson) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sure it's not just injector noise?
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Friday, January 11, 2008 - 07:08 am, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I hat to say this, but last time I had something like that, it was a big-end bearing.
Take it to a mechy and let them listn to it, trying to diagnost sounds over the internet is bloody hard, and it it's a bigend bearing, you want to get it fixed sooner rather than later, if caught quickly, it's not a major concern, but if it gets to the point where it grinds the crank away, then things become much harder to fix.
B.
Michael Askevold
wa
soarer tt
Reg: 12-2007
Friday, January 11, 2008 - 05:29 pm, by:  Michael Askevold (Mikiesoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cheers but now i've got a major drama. Driving along i noticed that i lost all kick down, gearing up ok but changes at like 3 grand. I thought yeah ok vacuum line or kick down cable.
Got to the shops did what I had to do and came out started ok. Put in reverse and did not want to run. I got it going (missing and surging all over the place)- I've driven many a dodgy car.-
Any how I drove the two kays home and kind of 'farted' and the engine run fine again but still no kick down.. what the oh its 'low kay ' jap import gearbox.... the guy how fitted it didn't know the one he supplied and fitted was a chaser gearbox- idiot.
Yeah nar I know and injector noise but this noise i like a 'group' sound if know what i mean .
thanks guys..... Yeah now I'm rolling in a Saab.
help
Blake Gloyn
manawatu
soarer JZZ30 TT
Friday, January 11, 2008 - 06:04 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
stuffed 02 sensor can make your car behave like that- true! even the gear change thing. true!
Michael Askevold
wa
soarer tt
Reg: 12-2007
Friday, January 11, 2008 - 07:04 pm, by:  Michael Askevold (Mikiesoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do you think, i'll see still if it plugged in.
Michael Askevold
wa
soarer tt
Reg: 12-2007
Friday, January 11, 2008 - 07:15 pm, by:  Michael Askevold (Mikiesoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah still plugged in.
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Friday, January 11, 2008 - 08:28 pm, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
check your gearbox oil level, low or high oil can cause no reverse, if it's near empty though, you might not be hearing this noise from the head, but filtering up from the front of the gearbox....
B.
Michael Askevold
wa
soarer tt
Reg: 12-2007
Friday, January 11, 2008 - 08:43 pm, by:  Michael Askevold (Mikiesoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers B, checked it- levels fine, ok oils a bit of a light brown colour but doesn't smell burn't and has good viscosity.
Its really weird man. I don't like it. Maybe I should of kept my FC least when it broke i could fix it!
www.etuner.com.au
Friday, January 11, 2008 - 10:43 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Blake Gloyn wrote on Friday, January 11, 2008 - 06:04 pm:
Ah, no correlation Blake. :-)
In fact, there is no subsequent feedback loop for oxygen sensors. If its not there - its not used.
I have been running without one for 6 months tuning for lean cruise air fuel ratios of around 16-17.5:1.
Charlie Ters
Reg: 01-2007
Saturday, January 12, 2008 - 06:15 am, by:  Charlie Ters (Ul05st) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
.... i had that noise, it will then dissappear, i then used nulon lifter free, thinking it will cure the noise, it turned out my rear exhaust wheel was 'wobbling' it then siezed and is now emmbeded in my cataliyc converter (hence is why im going single....)
Blake Gloyn
manawatu
soarer JZZ30 TT
Saturday, January 12, 2008 - 07:38 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
all i know cihan is that my car ran really rich, idled badly, stalled, threw up engine electrical system warnings,and changed gear at 4000rpm max under full throttle. all these things were corrected by replacing 02 sensor. the wiring had a fault in it and was sending intermittent incorrect signals to computer. absolutely amazing that it influenced gear shift points.Amazing, but true.
