Friday, April 23, 2010 - 12:01 pm, by: Sebastian Grant(Saabg)
Cheers Christian. As far as penis extensions go that car takes the cake.
What about the head, are the gte and ge 2j head the same or would I better off going with a 2j head. I don't want to go 1.5j. I plan on doing a ground up rebuild before I install which is why I think I might as well save the money and get a ge motor but, a gte head on it's own is quite expensive and might make it worth while just getting a complete gte motor.
Friday, April 23, 2010 - 04:17 pm, by: Sebastian Grant(Saabg)
I'm aware of the reasons for going 1.5j but I'm not going to do that. I'm planning on using a 2jz-ge bottom end but I need to know if it's ok to use the 2jz-ge head.
I don't see how retaining injector setup should be an issue as they are interchangeable but 1/3 are correct.
Saturday, April 24, 2010 - 01:20 pm, by: Michael Larcombe(Lextcy_tas)
I dug up an ancient HPi, where someone coverted his JZZ30 to a 2JZ. 'Apparently' he retained all the 1JZ sensors, loom, and 1JZ ECU, and just had the fuel and ignition mapped on an aftermarket ECU...
Saturday, April 24, 2010 - 04:00 pm, by: Blake Gloyn(Blakenz)
No, he replaced the factory ECU with a jzz30 apexi power FC(using the 1jzgte loom) but then had trouble with the auto not shifting gears, so ended up wiring in an earlier model auto trans ecu(7MG cressidas had a separate ecu for the trans.)
