  Soarer Central * Mechanical - TT * General Mechanical * How many Km's should a serviced 1JZ last? Previous Previous    Next Next
Steven Clements
Wa
Reg: 02-2008
Monday, March 03, 2008 - 01:01 pm, by:  Steven Clements (Steven087) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys
just wondering how long do 1JZ's usually last for before they get tired and start burning oil etc?
mine has done 174 000 kms and im just wondering how much longer it should keep going (with regular servicing etc)
how many other kms do other cars here have?
Mike Thomas
AB
JZZ30 Soarer TT
Monday, March 03, 2008 - 01:04 pm, by:  Mike Thomas (Petcanizzle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my old soarer burned oil at 113,000k but it was bagged.
i think theyre not gona be million mile engines due to the twin turbos and whatnot, but i dont see why they cant go a long time..
ive seen elsewhere on here the average lifespan of the turbos before the first one needs rebuilding is usually 125,000 to 150,000.. more with gentle use and good care.
Steven Clements
Wa
Reg: 02-2008
Monday, March 03, 2008 - 01:27 pm, by:  Steven Clements (Steven087) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sorry i should have been more clear i was referring to the lifespan of the actual motor not the turbos
Mike Thomas
AB
JZZ30 Soarer TT
Monday, March 03, 2008 - 01:36 pm, by:  Mike Thomas (Petcanizzle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the turbos will always go before the motor man... the lifespan of the turbos is the lifespan of the motor, considering the cost of turbos... and because theyre not really serviceable... you just take care of them, and rebuild them when theyre going or gone.
if your turbos are in good shape and your engine is... then well... i dunno.. ive never really heard of a 1JZ dying from natural causes.. usually theyre abused or theyre neglected from lack of necessary repairs and die tragically.
Steven Clements
Wa
Reg: 02-2008
Monday, March 03, 2008 - 01:41 pm, by:  Steven Clements (Steven087) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
apparently my turbos have already been replaced with low km' turbos from a later model. so my only real concern now is the actual motor
it seems ok, a bit noisy on start up (tapping sounds)
Mike Thomas
AB
JZZ30 Soarer TT
Monday, March 03, 2008 - 02:33 pm, by:  Mike Thomas (Petcanizzle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
damn thats a lucky break man new low km turbos...
if the tapping disappears i wouldnt worry, i mean, look into it but dont freak, is it a hard metal on metal sound or like a belt flapping sound or like a clicking or what?
just when the starter is running? or have yu been under the bonnet listening to where its from with someone else starting the car...
if your engine is clean, doesnt leak any fluids... and runs smooth at running temp.. and you use good synthetic oil and keep after your servicing.. theres no reason your engine wont surpass 300,000 or more... before needing more major service...
but i dont see head gaskets lasting much over 250k... isnt the head gasket part of the 200,000 service package or something listed under the soarer specs?
Luke Burt
Reg: 08-2007
Monday, March 03, 2008 - 06:15 pm, by:  Luke Burt (Burt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Steven, I Don't think anyone can put a number of km's to the life of any engine, Unless you've owned it from brand new and know the full history of it, even then, some motors are freakishly reliable, some lemons. Sounds like your big ends are worn a bit
Bit noisy for the first few seconds until oil
pressure builds up? You should be fine for a while bu there isn't really a way to know exactly how long it's got..
If i were you, I'd line up a new engine and just keep driving yours :-) it may last another 10,000, may last another 50,000...
Shane McInnes
JZZ30 GT-TL Manual
Monday, March 03, 2008 - 09:32 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive got 263,000kms on my engine, I assume there original kms imagine if there not lol.
But aslong as you look after and service, you should be fine.
Mine cops a hiding aswell so the 1JZs are quite strong and reliable.
Shane McInnes
JZZ30 GT-TL Manual
Monday, March 03, 2008 - 09:34 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mike its the 1st ive heard of the Head Gasket need replacing at 200k. Mine hasnt been replaced i dont see the need?
Steven Clements
Wa
Reg: 02-2008
Monday, March 03, 2008 - 10:13 pm, by:  Steven Clements (Steven087) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
could the tapping at start up just be sticky lifers? (a had this problem with my old CA and Rb nissan motors)
Mike Thomas
AB
JZZ30 Soarer TT
Tuesday, March 04, 2008 - 02:31 am, by:  Mike Thomas (Petcanizzle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
blow some sea foam through your air lines, should get rid of sticky lifters :-)
god that stuff is mint.
Dylan Kent
Tasmania
Tuesday, March 04, 2008 - 09:41 am, by:  Dylan Kent (Iguana) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what is sea foam??
Mike Thomas
AB
JZZ30 Soarer TT
Tuesday, March 04, 2008 - 11:31 am, by:  Mike Thomas (Petcanizzle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there is a sea foam thread, check canadian corner,... sorry, i get excited about the stuff its not like any of thoe fuel additives.. its not some kind of chemical or solvent agent its just nuts :-) look it up
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Tuesday, March 04, 2008 - 12:19 pm, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is no reason why a properly serviced 1jz wont last you over 500,000+ Kms.
Of course any engine that is thrashed to within inches of it's life wont last long in anyone's books, serviced or not.
drive it nice, service it every 5 - 7,000kms, and it will be happy, mine currently has 157,000kms on it, had 110,000kms this time last year, and definately wasn't oringial km's with the internal wear and tear on the car.
My car has not missed a beat, and runs great, even the turbo's are still in great nick, no smoke, no problems.
B.
Braden Murdoch
Cressida 1JZ TT
Wednesday, March 05, 2008 - 03:25 pm, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My motor has at least 130,000kms on it so far, and other than a brief knock when you first start it cold, it is fine. Mid 170s compression across all cyls.
I change the oil and filter every 3000kms, and never give it a hard time when cold, every bit helps :-)
Luke Nieuwhof
Wednesday, March 05, 2008 - 03:48 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Who has the highest kilometres here I wonder?
Shane McInnes
JZZ30 GT-TL Manual
Wednesday, March 05, 2008 - 07:14 pm, by:  Shane McInnes (Soarin_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dunno? I have to be in the running surely lol. I think Mr Neil has racked up quite a few on his Blue Soarer.
Matthew Crawford
Thursday, March 06, 2008 - 01:43 pm, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
185 on one - 198 on the other
