  Soarer Central * Mechanical - TT * General Mechanical * URGENT PROBLEM: Power Steering/ Overheating Previous Previous    Next Next
Christopher Vos
Reg: 01-2006
Saturday, March 08, 2008 - 03:04 am, by:  Christopher Vos (Vossy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Started car earlier tonight and notice a loud squeel that sounded like a loose fan belt. i drove for about 20 minutes then turned it off momentarily in a carpark waiting for my girlfriend. when she hopped in i turned the car on and it made the squeel again and a loud clunk.
as i took off i noticed that my power steering had suddenly stopped working. after about 30 seconds i got the Alternator not charging Battery message closely followed by the engine overheating message. my engine coolant was leaking/steaming my radiator was bubbling.
it is currently 2.30 in the morning and i have left the car in a carpark about 5min drive from my place. and going to pick up in the morning and need to know what i need to look out for. i just need to get the car home rather than it being towed. is it safe to do so or is it just not worth the risk?
please help!
thankyou
JunkFilterer
Saturday, March 08, 2008 - 03:34 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Your profile doesn't show what sort of car it is, but sounds like you have dropped a belt most likely. There could be more however.
Did you open the bonnet and have a look?
Braden Murdoch
Cressida 1JZ TT
Saturday, March 08, 2008 - 09:00 am, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You have snapped the serpentine belt...I would advise getting an new one before moving the car. It runs the water pump, alternator, power steering, and aircon. Water flowing around an engine is crucial at all times!
Mustafa Akgul
ToyoPartsMan
Saturday, March 08, 2008 - 01:51 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
tow it to your mechanic mate Like Braden said it sounds like the belt is gone I would also check the belt tensioner.
but dont drive it.
Michael Keen
soarer tt
Reg: 10-2007
Saturday, March 08, 2008 - 02:31 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just grab a new belt from repco about $30 bucks, and take a 1/2" drive breaker bar. and your set just put it back on.. easy as, and look under the bonnet near the hinge pin there might be a diagram of how it goes around the pulleys cheers
Graham Dollisson
GTTL , Morris Marina, P76 V8 Super, P76 6cyl Deluxe
Saturday, March 08, 2008 - 03:42 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And also, unless you are 100% sure that the timing belt has been replaced, I would be changing that too!!
Christopher Vos
Reg: 01-2006
Sunday, March 09, 2008 - 05:07 pm, by:  Christopher Vos (Vossy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah i have reciepts for the timing belt. checked it yesterday and it is the main belt. it hasnt snapped.. simply fallen off........
i checked what belt was on it and it is a 6pk1955 which should fit no? went to pick up a new one and was told it should be a 1940... does anyone know what belt it should actually have? it is strange because the belt that was on it is still in tact.. just really loose... unless the belt has stretched?
Christian Molenda
T
Sunday, March 09, 2008 - 07:02 pm, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Christopher Vos wrote on Sunday, March 09, 2008 - 05:07 pm:
probably a stuffed tensioner
Michael Keen
soarer tt
Reg: 10-2007
Sunday, March 09, 2008 - 08:11 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i would say that the wrong size was installed before, and it simply went out of adjustment. grab the tensioner and see of you can move it by hand if so it bugger, but most likely a larger belt was fitted, and it simply out of adjustment now. so get the right size and fit that. i cant remember what size i brought but i found it on the forum somewhere. i think it a 6pk1940 there about anyway. smaller is allways better. longer life hehe
Christopher Vos
Reg: 01-2006
Friday, March 14, 2008 - 04:53 pm, by:  Christopher Vos (Vossy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah i got the 1940 and put it on.. it starts and spins fine just sounds like it is scraping on something... making the typical loose fanbelt noise.. im assuming that if i have the right belt and its still loose it is my tensioner.. the only thing being that the tensioner only has about 20mm to tighten before it will be hitting up against i think the power stearing gear..
mechanic here i come
Matthew Werner
jzz30 TT
Reg: 12-2006
Saturday, March 15, 2008 - 11:12 am, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wouldn hurt to take your serpintine belt off and just spin all your accessories by hand.. it wont tell you wat condition your p/s pump is in.. but you will be able to feel condition of bearings.. they all must spin smooth and free.. except your harmonic balancer.. if that spins easy u got serious issues
