  Soarer Central * Mechanical - TT * General Mechanical * Turbo's Previous Previous    Next Next
Jason Thornton
N.S.W
n/a
Reg: 04-2007
Monday, March 10, 2008 - 07:53 am, by:  Jason Thornton (Jay9959) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi i've got 1jzgte
Question are the turbo's the same
apart from one facing forward and one
backward a friend said that one turbo
is smaller is this true as far as i know
everything is same size,so exhaust wheels
compressor wheels are the same,
What about housing's are the dimension
the to each other.
Matthew Crawford
97 VVT-i JZZ30 + 91 JZZ30 TT
Monday, March 10, 2008 - 09:56 am, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Same same mate - obviously not interchangable though!
Chris Prak
Soarer GTT-L
Reg: 12-2006
Monday, March 10, 2008 - 12:20 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes they are identical besides the wastegate actuators.
Jason Thornton
N.S.W
n/a
Reg: 04-2007
Monday, March 10, 2008 - 02:24 pm, by:  Jason Thornton (Jay9959) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great now i can tell my mate that they
the same
Thanks for the replies
Jeff Smith
GT30/37r Single T
Monday, March 10, 2008 - 04:39 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The supra runs a small and large turbo,Not the soarer.
www.etuner.com.au
Tuesday, March 11, 2008 - 12:48 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff Smith wrote on Monday, March 10, 2008 - 04:39 pm:
Nope they're exactly the same size...
Blake Gloyn
manawatu
soarer JZZ30 TT
Tuesday, March 11, 2008 - 06:43 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff!!! shame on you...
Jeff Smith
GT30/37r Single T
Tuesday, March 11, 2008 - 07:17 am, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I wasn't refuring to the 1jz supra! I was suggesting that maybe his mate is confused with the 2jz that runs the different twin setup.
Matthew Crawford
Tuesday, March 11, 2008 - 09:14 am, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The sequential setup has equally sized turbos on all supras Jeff.
Justin Cook
Tuesday, March 11, 2008 - 01:17 pm, by:  Justin Cook (Justin) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hahaha Jeff I used to think the same thing too :-) They are the same size in the 2J as well, crazy but its true!!!
Jeff Smith
GT30/37r Single T
Tuesday, March 11, 2008 - 05:16 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok! I stand corrected! So doe's the second just have a larger inducer and larger exhaust housing?Were doe's the sequential come into it?
I don't know the supra like I know the soarer.Hahaha
Benjamin Burgess
Toyota Soarer GT-TL, Toyota Corolla Conquest
Tuesday, March 11, 2008 - 05:23 pm, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What it has is this extremely complex wastegate system that is able to divert flow between the turbos at some given rpm, pressure. One of the things 2JZGTE owners do is make the turbos parallel setup, which of course makes the whole setup laggy as all hell.
Jeff Smith
GT30/37r Single T
Tuesday, March 11, 2008 - 05:56 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So this was the way japan tamed the 2j and gave it lag.......Hahahaha
Benjamin Burgess
Tuesday, March 11, 2008 - 06:11 pm, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The stock turbos on a 2jz are pretty good. They'll make 300rwkw.
Tuesday, March 11, 2008 - 07:23 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The US ones will Ben, not the Japanese ones... The USA ones are steel wheeled and flow a bit better:-) Toyota was worried the Yanks would flog the cars too hard and break the ceramics,lol.
Gareth Richards
Bristol UK
GTT-L twin turbo auto / Aristo Mk1 TT / Lexus GS300 SE Mk2
Thursday, March 13, 2008 - 05:28 pm, by:  Gareth Richards (Garethr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Benjamin Burgess wrote on Tuesday, March 11, 2008 - 05:23 pm:
Complex is right!
How it works:
http://www.max-boost.co.uk/max-boost/supra/turbo.htm
Daniel Clarke wrote on Tuesday, March 11, 2008 - 07:23 pm:
...... The USA ones are steel wheeled......
All the export JXA80 Supras are steel (including UK, although most of ours are JDM imports).
