Friday, March 28, 2008 - 10:04 am, by: Anton Jones(Alj)
Mate no need for a seal kit. Pull out the diff, it's a peice of P*ss to do (Planet Soarer guide). Then replace the bearings either side of the centre (for good measure) then replace the gasket seal on the end case. Tighten and new oil..
It's a half day event if you have the bearing already and it's good for your diff. I just put an lsd in (threw away my open centre) and it was a simple process. There is a guide here for the diff centre cahnge from 'grandpa' if you want to do it. EASY.
