Tuesday, April 15, 2008 - 09:48 pm, by: Bobby Green(Nash)
Yea I have it, same issue on auto setting. Wouldn't boost over 10 psi. The setting that got me to hold it stabley at 15 psi was a gain of 5, start boost at 10 psi. Or as Daniel said, get it dyno tuned in manual mode. Make sure you are in a safe place with no cops when setting the auto mode. =P
Wednesday, April 16, 2008 - 11:08 am, by: Aka Abedin(Soarer_91tt)
It will be going on the dyno this month Big fella.
Thanks Bobby, i got it on manual setting now with 15%, 18 gain and 13psi start boost.
When i am taking off hard at a set of lights its hitting around 17psi and stays constant but when i am cruising and on 2nd gear and plant it, then it slowly starts around 14psi and starts rising. Any idea on that?
I wouldve thought it should go straight to 17 psi.
Wednesday, April 16, 2008 - 08:32 pm, by: Charlie Ters(Ul05st)
speaking of which, i need another dyno run for my profec (b spec 2) that i just installed, however, i need 1 piece of help.... heres a pic ..
on the solenoid (for single setup/external w.gate) the middle port is not used, and from factory, had a removable caps on each of the ports... now ,my question is, do i remove the plastic cap so it can breath (thats if it needs it) or do i leave the cap on there to stop dirt etc?? thanks
