  Soarer Central * Mechanical - TT * General Mechanical * Help please urgent Previous Previous    Next Next
Michael Keen
soarer tt
Reg: 10-2007
Monday, May 26, 2008 - 02:08 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi, there i'm trying to find the part number for the cam position sensor's and knock sensor, i have the sensor but what i need is the electrical plug for the loom, now toyota at castle hill said i need to get the part number of the plug, but slight problem i dont have the plug, can some one please provide me with the number on the plug for them to sensor asap. that would be great cheers.
the actualy sensor number does not help them :-(
Monday, May 26, 2008 - 03:50 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try calling NIall at Bond auto tech!
Mercedes Benz SLK230 Kompressor
Monday, May 26, 2008 - 04:14 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Michael, here's a piccy of the wiring loom thingo in the parts programe...........does anything here look like what you need?
Michael Keen
soarer tt
Reg: 10-2007
Monday, May 26, 2008 - 04:19 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah hi don it does, little hard to see what i need in that pic. but attached is another pic with what i need in red, there is only 2 and i can locate the ones for knock sensor. cheers
Monday, May 26, 2008 - 04:35 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can't read your pic. Here's a blown up version.........put ya red circles around de bits ya need.
Michael Keen
soarer tt
Reg: 10-2007
Monday, May 26, 2008 - 05:52 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
here you go, bascialy the number of the plugs that go on the cam position sensor and the knock sensor there is 2 of each
Monday, May 26, 2008 - 09:06 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can't find any reference to the plugs being available as a separate item from the wiring loom on the parts program.
Michael Keen
soarer tt
Reg: 10-2007
Tuesday, May 27, 2008 - 07:36 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah, when you ring toyota, they have a plug book, and all i need to get is the number of the orignial plug, i think there is like 5 digits. i then ring them and they can look in there book, and get the rest of the number. they arnt listed seprate on the parts manual. but yeah. do you understand.
Tuesday, May 27, 2008 - 10:13 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know what ewe mean.........ya might have to have a squiz under the bonnet of someone's TT, and get the number.
I think they're what Toyota refers to as a "Standard Part", which will be used on numerous Toyota vehicles.
Michael Keen
soarer tt
Reg: 10-2007
Tuesday, May 27, 2008 - 12:43 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes you are right. that what i'm trying to find out. ok no worries. thanks don for you help.. anyone wanna pop the bonnet for me and get the number :-)
Jeff Smith
GT30/37r Single T
Tuesday, May 27, 2008 - 12:49 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Will do this arvo for you,That's if someone dosn't help first.
Michael Keen
soarer tt
Reg: 10-2007
Tuesday, May 27, 2008 - 01:51 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks jeff much appreciated
Jeff Smith
GT30/37r Single T
Tuesday, May 27, 2008 - 05:05 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I will do that for you tomorro as I got home late mate and not enough light too see.
Michael Keen
soarer tt
Reg: 10-2007
Tuesday, May 27, 2008 - 06:39 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wel my friend got the number and i typed them into google, and look what i found :-)
http://www.supraforums.com/forum/showthread.php?p=5801110
this link should be made a sticky here everyone http://scionlife.org/Scion_Docs/2005_tC_Wiring_Manual/198-199%20part%20number%20of%20connectors.pdf
Jeff Smith
GT30/37r Single T
Tuesday, May 27, 2008 - 07:45 pm, by:  Jeff Smith (Mozzie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great find mate!
Tuesday, May 27, 2008 - 09:11 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Excellent Michael
I've added them into my stash of useful Soarer info.
Michael Keen
soarer tt
Reg: 10-2007
Wednesday, May 28, 2008 - 04:03 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just have to check with the second link, but the part number is the same for the cam and knock sensors.. so i assuming it a 1jz motor :-)
now i can ring castle hil, and see if they got them in stock with my gaskets if they do i might pick them up this afternoon. when i get my full black interior :-)
