  Soarer Central * Mechanical - TT * General Mechanical * Fuel Cut? Previous Previous    Next Next
Nickel Quimada
GT-T
Thursday, August 14, 2008 - 07:01 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Background info
- GCG steelwheeled and highflowed ct12as
- FMIC , Pod
- Lews dumps , no cat, single 3' exhaust
- running natural boost.
Car has recently had the fuel tank completely drained and brand new ryco z383 fitted. New plugs NGK platinum 1.1 degapped to 0.8 mm. As new plugs were installed coil packs were checked for cracks.(quick inspection) found nothing.
Problem - When putting the foot down this morning in 2 degree weather the cat light appears on the dash and i experience fuel cut. That part i know. But previously to this the car would pop and fart, bog everywhere in the higher rpm ranges as it was still building boost.
Profec B is the next thing to go in , then a tune on the EMU.
Is this part of the fuel cut symptoms or a ignition/fuel problem?
Dave Cazes
sa
tt
Reg: 08-2007
Friday, August 15, 2008 - 08:29 am, by:  Dave Cazes (Cazman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what boost are you running? wheres your gauge?
How you going to "tune" the ecu?
I have never heard of them being part of the fuel cut symptoms, but either way its a bad thing
TR44 HF
Friday, August 15, 2008 - 03:57 pm, by:  Maurice Diggler (Mau_rice) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave Cazes wrote on Friday, August 15, 2008 - 08:29 am:
Nickel Quimada wrote on Thursday, August 14, 2008 - 07:01 pm:
Nickel Quimada
GT-T
Friday, August 15, 2008 - 06:04 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK so it is fuel cut as i have been told by a reputable workshop. Will need to book it in for the EMU to be installed and tuned. Happy days :-)
Brian Rozario
wa
soarer TT
Reg: 06-2007
Friday, August 15, 2008 - 06:28 pm, by:  Brian Rozario (Rozario) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey when you do that let me know who you go to and how much power you get, theres not many people here that do tune the EMU
Nickel Quimada
GT-T
Friday, August 15, 2008 - 06:40 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah i have heard that to brian. will let you know how i go.
Nickel Quimada
GT-T
Wednesday, September 10, 2008 - 09:52 pm, by:  Nickel Quimada (Pinoy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brain check the link out for my results.
http://soarercentral.com/sc-forum/messages/51875/260689.html?1221045626
