  Soarer Central * Mechanical - TT * General Mechanical * IAT Sensor Signal? Previous Previous    Next Next
Anthony Weller
Twin Suckkas
Reg: 08-2008
Sunday, September 07, 2008 - 05:49 pm, by:  Anthony Weller (Mixtick) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey men,
Car has been running very poorly for a while now.. surging, as searched, looks like a common prob..
Foot down 3/4 of the way and have some power loss, as the car feels like its in limp mode etc.
Plugs, Coils are ok.
So. I did a diagnosis and found the error code EFI 24; which I looked up is IAT Sensor Signal..
Now. Where is it located? as id like to see if its ok lol..91 TT
Thanks
Michael Keen
Reg: 10-2007
Sunday, September 07, 2008 - 06:02 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
tell me what iat means and i can proab help ahha
Anthony Weller
Twin Suckkas
Reg: 08-2008
Sunday, September 07, 2008 - 06:13 pm, by:  Anthony Weller (Mixtick) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Intake Air Temp
Michael Keen
Reg: 10-2007
Sunday, September 07, 2008 - 07:14 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It is on the intake manifold, as you're looking at it from the front it is on the left side, it has like a big brass nut on it and it screws into the manifold above the injectors.
Pull it out and it'll be pretty dirty too, as mine was when I did the manifold change.
It has like a long probe on it, I think from memory the size spanner was like 19 mm cheers.. ya can't miss it..
Anthony Weller
Twin Suckkas
Reg: 08-2008
Sunday, September 07, 2008 - 08:29 pm, by:  Anthony Weller (Mixtick) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Mick
I took it out and cleaned it, reset ECU and no more error code so im happy about that!
But the car is still playing up..
One thing done tho so thanks!
Michael Keen
Reg: 10-2007
Tuesday, September 09, 2008 - 03:20 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
glad i could help, what is the car doing excatly ?
Anthony Weller
Twin Suckkas
Reg: 08-2008
Wednesday, September 10, 2008 - 07:09 am, by:  Anthony Weller (Mixtick) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
missfiring under boost from 3500 revs, changing plugs this weekend, but i noticed some oil in 2 of the plugs opposite the injector plugs, and i cannot get em out.. but i dunno :S
