  Soarer Central * Mechanical - TT * General Mechanical * JZZ30 Powersteering Pump Previous Previous    Next Next
John Street
Sunday, September 28, 2008 - 06:46 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
Have used the" search" function, but unable to find a tutorial for reconditioning the TT powersteering pump.
Anyone help?
Kim Hunt
Supercharged SC400\Soarer GT-L UZZ31
Reg: 08-2007
Sunday, September 28, 2008 - 09:38 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there you go buddy
http://www.planetsoarer.com/Power%20steering%20pump.htm
John Street
Monday, September 29, 2008 - 09:27 am, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Kim , does this mean that the V8 and TT pumps are the same?
Kim Hunt
Reg: 08-2007
Monday, September 29, 2008 - 10:29 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i'm not 100% sure.but i think that they might be. or pretty similar
Paul Whitehead
As above
Reg: 05-2009
Wednesday, May 27, 2009 - 08:07 am, by:  Paul Whitehead (Pwhitehead) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
I have a 2.5 lt TT Soarer and the powersteering pump has been recoed but I still have a problem with the pump noise and heavy steering when the engine is cold . The fluid level seems to be ok , What do you think the problem is ?
Regards Paul
Gary Morriss
Wednesday, May 27, 2009 - 02:45 pm, by:  Gary Morriss (Gaza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have you had it at idle , take the pwr steering fluid cap and get someone to see if theres any air bubbles coming up?, might have some left. get someone to look while you turn your steering all the way left then right , but dont leave it turned full on, keep moving it , it will get any air out if there is any.
Max Rockatanski
BadenWuerttemberg
Thursday, May 28, 2009 - 06:59 am, by:  Max Rockatanski (Rockatanski) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This is a pain to deflate the air out of the system! Left right left right turning 1000 times, jack up the car in front and it will be easier to deflate it...
good luck!
