  Soarer Central * Mechanical - TT * General Mechanical * Various vacuum line problems (with pics) Previous Previous    Next Next
Luke Streat
Reg: 09-2008
Saturday, October 18, 2008 - 06:59 pm, by:  Luke Streat (Streatracer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So i finally got around to spending some quality time under the bonnet of the soarer today and discovered several problems.
1. There is no pipe attached to this thingy (tech term)
I dont even know what this is but it looks important with several lines coming off it.
2.There are no lines attached to my bov! so im assuming the sound it makes is actually flutter. not cool. Were do the vacuum lines for the bov usually run from?
3. I found a line with a tee in it up against the firewall it has bolts blocking the 2 pipes coming off it
What is it? possibly the remnants of a boost controler setup?
4. This thing is not attached to anything and is just sitting in the corner of the engine bay bouncing around. were does it belong?
If anyone can help with any of these probs id be very appreciative
Luke
Saturday, October 18, 2008 - 09:49 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1. Heater hose has been removed, may indicate a shot heater matrix - you don't want to know about replacing it. :-(
Luke Streat
Reg: 09-2008
Saturday, October 18, 2008 - 11:00 pm, by:  Luke Streat (Streatracer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well after my Quality time with soarer she now flatly refuses to start!
I ran a diagnostic and it flashed code for normal.
Cant seem to hear fuel pump priming but it may just be more quiet than I am used to.
Also it was running strangely today, jumping around on low revs under load (Quite violently like a bunny hop).
Today was very hot and I had cannon mufflers fitted this morning. dont know if either of these things are related.
HELP!
Saturday, October 18, 2008 - 11:29 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like it is rejecting the cannons :-)
But seriously, try the fuel pump ECU bypass trick.
Luke Streat
Reg: 09-2008
Saturday, October 18, 2008 - 11:42 pm, by:  Luke Streat (Streatracer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Iv done a search for it but my feeble mind needs pictures to show were to put the paper clip <:-(
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Sunday, October 19, 2008 - 08:05 am, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There should be a little sticker on the inside cover of the diagnostic port mate. It has a picture of the terminals and relates them back to what they are (insert fuel jumper letters here)
Mercedes Benz SLK230 Kompressor
Sunday, October 19, 2008 - 10:09 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fp & B+
Michael Keen
Reg: 10-2007
Sunday, October 19, 2008 - 10:55 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Saturday, October 18, 2008 - 09:49 pm:
yeah you do they are a really easy to change about 4 hours work.
Luke Streat
Reg: 09-2008
Sunday, October 19, 2008 - 04:04 pm, by:  Luke Streat (Streatracer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
4 hours?! haha I dont think ill need a heater in this country anyways
Michael Keen
Reg: 10-2007
Sunday, October 19, 2008 - 05:57 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yerp did it not long ago, yeah you prob wont need it in wa, but we need it here. in bathurst ehhe
