  Soarer Central * Mechanical - TT * General Mechanical * AHHH FRIGGG.........DAM CAR SPUTTERING NOW Previous Previous    Next Next
Patrick Robinson
New Providence
Monday, October 20, 2008 - 11:18 am, by:  Patrick Robinson (Islandsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
(LONG SIGH) Okay, here's my dilemma. After 3 weeks of waiting for my water pump to arrive I finally installed it and got everything back together. Now this is my first time ever in life dealing with changing a timing belt on any car that i have ever owned. Good thing is the car turned over and idled fine on the very first try. I left it running for a few minutes, and then I revved her up and everything was fine. Now, when I jumped in the car and was about to take her for a spin; I pulled out the driveway and when i put my foot on gas, she had absolutely no power. She would not go past 12 km/h and whenever I try to push the gas harder to give her power she sputters, but the thing is, she doesn't shut off. This is puzzling the hell out of me. What can possibly be the problem.
Dave Rose
wa
uzz31 v8
Monday, October 20, 2008 - 01:55 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like the timings out (valve) did you turn the engine over(clockwise)after fitting belt to check the timing ?
Monday, October 20, 2008 - 06:06 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im with Dave on this one, Cam timing out by the sounds of it.
Danny Dinh
GT T
Monday, October 20, 2008 - 09:45 pm, by:  Danny Dinh (Xtc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
me 3
Patrick Robinson
New Providence
Monday, October 20, 2008 - 10:19 pm, by:  Patrick Robinson (Islandsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no i didn't turn the engine over clockwise after fitting the belt. But why is it that the car would start so easily on the first go. I pray to God I didn't damage anything.
Cameron Laufer
T
Reg: 12-2007
Monday, October 20, 2008 - 10:39 pm, by:  Cameron Laufer (Ivboost) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nothing will be damaged, It's a Non-interference head design
Dave Rose
wa
uzz31 v8
Monday, October 20, 2008 - 10:41 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry Patrick but it looks that way , yes they still run with a tooth out ...in fact if it out the right way they run smoother at tick over.
See if the marks line up...but only turn it clockwise if you pass the mark keep going till it comes round again,this makes sure there is no backlash between the crank and cams.
I am sure you have not damaged anythink,good luck
Patrick Robinson
New Providence
Tuesday, October 21, 2008 - 03:59 am, by:  Patrick Robinson (Islandsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
But see that's the thing about it. The cams line up at TDC. Could it be possible that the cams are lined up and the crank is off a tad?
Thanks alot for your help guys.
Tuesday, October 21, 2008 - 06:26 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check all the simple things too - I missed reconnecting a plug lead when I did my timing belt last time and almost shat myself - couldn't tell anything was wrong at idle either.
Patrick Robinson
New Providence
Tuesday, October 21, 2008 - 09:42 am, by:  Patrick Robinson (Islandsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
my brother was saying that too, so, i'm not as fortunate as you guys with your luxurious garages so I have to wait until the sun comes up. I'll check that tomorrow and see what goes from there. But my question still remains: Could it be possible that the cams are lined up and the crank is off a tad?
Dave Rose
wa
uzz31 v8
Tuesday, October 21, 2008 - 11:17 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Patrick if they line up at TDC (TURNING CLOCKWISE) then look elsewere as Matthew says plug leads etc.....fuel starvation springs to mind ?...pump.
Tuesday, October 21, 2008 - 11:18 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If the crank is showing TDC 0 degrees on the harmonic balancer, and both cams line up, then no, its not possible for the crank to be off (unless its a full 180 degrees out, in which case the car wouldn't start)
Thats from a mechanical POV at least (the angle sensor could be faulty though?) - the harmonic balancer is keyed so it will only go on one way.
Shane Haverkamp
soarer TT
Reg: 10-2007
Tuesday, October 21, 2008 - 02:00 pm, by:  Shane Haverkamp (Havabeer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
excuse the roughness of the drawing. but the cams need to be lined up with the marks on the backing cover thing
and the harmonic balancer/crank pulley need to be lined up at 0 degree's TDC
you may have to dummy fit the plastic cover with the markings on it to line up the crank pulley
Tuesday, October 21, 2008 - 05:36 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
TPS
Patrick Robinson
New Providence
Tuesday, October 21, 2008 - 09:30 pm, by:  Patrick Robinson (Islandsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Shane thanks. That's the problem right there I think. Because I noticed the cams were at 12:00 and the crank, I don't think was on zero. I think it was basically on the 12:00 position also. But that's puzzling the shat out of me because why would the dam car start and run?
Dave Rose
wa
uzz31 v8
Tuesday, October 21, 2008 - 10:03 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well that was a full circle .....
Patrick Robinson
New Providence
Wednesday, October 22, 2008 - 12:28 am, by:  Patrick Robinson (Islandsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So Dave are you saying that could be the problem
You SC guys are so farking helpful it almost brings tears to my eyes.
Dave Rose
wa
uzz31 v8
Wednesday, October 22, 2008 - 01:59 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well if the cranks not at TDC O DEG then yes this is the problem.
