Friday, October 24, 2008 - 11:02 pm, by: Sami Ansari(Thesaint)
Hey
I have started to notice this for the last few weeks now ...
I go to start the car ... turn the key .. find i have to hold it longer than normal and once I release then the engine slowly splutters on ... sometimes it hasn't turned on first go (almost but not quite) and I have had to try again
Tends to be fine on cold start ... more of an issue when I return to the car after having driven it somewhere
What I have tried: - Battery - Cleaned terminals - Fuel ECU Bypass
Any Suggestions/tests I can do to diagnose what may be causing this
Saturday, October 25, 2008 - 08:31 am, by: Rob Rojo(Rob_tt)
Do you have an immobiliser? When you go to start your car do you just go straight from off to start straight away or do you go to the on position for a few seconds first. To allow fuel pressure to build?
Saturday, October 25, 2008 - 10:13 am, by: Rob Rojo(Rob_tt)
Did not see your running power fc, but I would guess that it would have to have a reset setting in there somehow, try just disconnecting the battery for a couple of minutes with headlights on. With the coilpacks just check for any cracks but this would be more likely if the car was missing at higher revs as for the ignitor I think you would need to just swap it over to see if that the cause. Probably be worth talking to Cihan about it.
