  Soarer Central * Mechanical - TT * General Mechanical * Dif oil Previous Previous    Next Next
Michael Keen
Reg: 10-2007
Sunday, October 26, 2008 - 09:55 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi, thought i should change my diff oil, any idea what to use cheers. just standard open wheeler.. no fancy lsd here..
Michael Keen
Reg: 10-2007
Sunday, October 26, 2008 - 01:44 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey, well i went and got some nulon 75w-90 smooth shift transaxle oil. it a semi synthetic oil, only got 2 ltr hope it enough.. hope it works..
Sunday, October 26, 2008 - 07:48 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Awsome, Next time, post it in the section for Diffs and Wheels,lol.... :-)
Kyle Wathen
JZZ30 Manual GT-T
Reg: 02-2007
Sunday, October 26, 2008 - 08:00 pm, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
While we are on the topic...
Which oil is best for factory LSD and how many litres?
Sunday, October 26, 2008 - 10:25 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its a Mechanical LSD so normal Diff oil will work. Go for some Synthetic though, 75-90 80-90 will work a treat.. takes about 1.8-2L iirc.
George Funa
Reg: 05-2006
Tuesday, October 28, 2008 - 09:54 pm, by:  George Funa (Fun001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How often should you change diff oil?
Charlie Ters
'Single' biggest mistake :-)
Reg: 01-2007
Tuesday, October 28, 2008 - 10:58 pm, by:  Charlie Ters (Ul05st) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LSX90..... cheap, nasty and if you were to service at toyota today, you will get it (in large castrol contracted drums that is) :-)
i heard its never overkill to have lsd oil ($$$$ stuff) in an open wheeler, but dangerous when cheap non-lsd stuff is poured in an lsd diff?
Wednesday, October 29, 2008 - 04:11 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ONly if tis a clutch pack type LSD... Otherwise any diff oil is fine if it is a mechanical oil.
Change the diff oil every 50,000km's... If thats the case, Put some good stuff in ! You dont put No frills in your engine do you? Even if changed frequently? :-)
George Funa
Reg: 05-2006
Wednesday, October 29, 2008 - 10:50 pm, by:  George Funa (Fun001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel Clarke wrote on Wednesday, October 29, 2008 - 04:11 pm:
Thanks Daniel. So Banana peels won't work
Thursday, October 30, 2008 - 05:55 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I did mine a couple of months ago - just used the Castrol product - can't remember the exact weighting. Took just over 1.5 litres. Old stuff was pretty stinky and nasty, and the magnetic plug was a pretty well coated. Most difficult bit was getting the two plugs undone as they use an allen key and I didn't have any allen key attachments for my socket set, so I had to use an ordinary allen key and wack it with a hammer.
Blake Gloyn
manawatu
soarer JZZ30 TT
Thursday, October 30, 2008 - 07:58 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i recommend changing your diff oil as soon as you get the car, then every 20000km if you are racing it. it's important to keep the torsen in really good nick.
years ago, the local toyota dealer put LSD oil in my torsen. they didn't have a clue that it needed normal gear oil. I changed it immediately. 1.6litre volume, i reckon.
Danny Dinh
GT T
Thursday, October 30, 2008 - 08:36 pm, by:  Danny Dinh (Xtc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the right tools always make the jobs easier. Invest in the quality tools and you won't round any bolts and nuts and save your skin too.
Thursday, October 30, 2008 - 10:53 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
George Funa wrote on Wednesday, October 29, 2008 - 10:50 pm:
Hahahahaha George you funny bastard !!!
They work a Treat, when your selling the car with noisy rear end,lol...
And yeah, Get yourself some Hex Sockets, I got some in 1/2inch drive ! 10mm,12mm,14mm( havent used this one ).
The Driveshaft bolts are 10mm Hex and i think the rear diff cradle ones are 12mm... Having the right tool, much easier :-)
Friday, October 31, 2008 - 06:26 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Indeed, I have a kick arse socket set now that my wonderful mum-and-dad inlaws got me last birthday, but unfortunately the one thing it was missing was hex sockets. I'll get some before I have to do the job again.
Christian Molenda
T
Friday, October 31, 2008 - 09:25 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Blake, What oil do you recommend and what damage will be done if LSD oil in a torsen?
asking as i have castrol LSD oil in mine and since its been in there its alot clunkier... (although i thought a burnout did that) seems worse when hot then cold.
Friday, October 31, 2008 - 10:33 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That could be that the LSD oil is thinner Christian. Which when its hot would get even thinner and wouldnt quite fill the tolerances as well as a thicker grade oil . I would advise dropping it out and going with some 80-90 Synth mate! Worth a go, should make the diff " less clunky ".
Dave Rose
wa
uzz31 v8
Friday, October 31, 2008 - 11:35 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Christian dont think it was the oil as Soarers were not really built to do burnouts they even fitted traction control to stop the problem
Christian Molenda
T
Friday, October 31, 2008 - 02:14 pm, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave, no traction control on mine.. Also it was after a burnout a while ago at willowbank when i first noticed it, but was around the same time i changed the oil. Also my powerlevel and the shiftkit doesnt help too much
Dave Rose
wa
uzz31 v8
Friday, October 31, 2008 - 02:27 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
AH AH only pulling ya leg,but Chris if you stop doing burn outs ,it will not get any worse!!!!.
The clunk could be in the prop?,i think CASTROL LXS 90 H/DUTY is o.k,i always use it .
Cameron Laufer
T
Reg: 12-2007
Friday, October 31, 2008 - 02:31 pm, by:  Cameron Laufer (Ivboost) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave Rose wrote on Friday, October 31, 2008 - 11:35 am:
Soarer weren't made to produce 300+RWKW's either
Christian, change the oil and sell it on Supra forums before it go bang, i herd people are willing to pay upto a grand for one did I just write that
Friday, October 31, 2008 - 03:10 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very true Cameron, But they can handle quite alot of launches and burnouts :-)
