  Soarer Central * Mechanical - TT * General Mechanical * 5 spd manuel TT cars help needed Previous Previous    Next Next
Dayle Gray
Arizona
Soarer JZZ30 TT
Reg: 07-2008
Sunday, November 02, 2008 - 03:47 am, by:  Dayle Gray (Soarer007) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can someone email me pics of how and
where the clutch master is mounted
on their TT 5spd car ? Im doing a conversion
from auto to stick on mine, the pics would
help clear up some questions about mounting
and what Im missing.
So far I have the R154 trans, clutch, flywheel, starter, driveshaft, crossmember, shifter, boot and pedals. thanks
in advance.
Scott Wilkes
Tasmania
92 TT Factory Manual
Reg: 10-2008
Sunday, November 02, 2008 - 08:14 am, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dunno if these help, but its all i have at the moment
master cylinder is the metal shrouded object at the right (drivers side) of the car above the rear turbo. Il try and get a better pic today, if someone else dosnt get in before me
Michael Keen
Reg: 10-2007
Sunday, November 02, 2008 - 10:43 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi, i just converted mine to manual last weekend, still doing the inside, now, the auto starter is the same, so you dont need that, you will need a manual ecu , i have one for sale, pm if you like cheers you will also need a manual brake pedal as the auto one is wider, there is all ready a hole in the firewall, for the master cylinder you just need to drill out the bolt holes, but if you look through from the inside you will see it, pretty easy job, take your dash out so you can get to the top bolt..
well worth it cheers
Dayle Gray
Arizona
Soarer JZZ30 TT
Reg: 07-2008
Sunday, November 02, 2008 - 01:21 pm, by:  Dayle Gray (Soarer007) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sweet !
I got an R134 5 spd, flywheel, clutch crossmember, driveshaft, shifter, boot,
slave cylinder and lines, and starter out of a Chaser (or Mark III turbo, not sure)
Got the pedals out of a Soarer RHD here
in the USA of all places too.
I may need your ECU, thanks.
What I need more is the clutch master/ w rod.
Have a good used one or can you get me a new one
from the dealer ?
Thanks for the pics, not sure I could see exactly where the clutch master was mounted.
I have a single turbo conversion too, hope I
have the room for it.
Dayle Gray
Arizona
Soarer JZZ30 TT
Reg: 07-2008
Sunday, November 02, 2008 - 01:23 pm, by:  Dayle Gray (Soarer007) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
one more thing, I dont get a chance to check the sites as much as Id like, so if you post and also can email me, that would be great.
and lmk what you want for the Ecu.
my cars a 92.
thanks
Dayle
motorsport_svx@yahoo.com
