Friday, November 28, 2008 - 08:26 pm, by: Ben Lipman(Ben12a)
I am looking to fit electric oil pressure and temp gauges to my track car. I want to buy a sandwich plate, but need to know which of the following is the Soarer TT thread size for the filter.
M18-P1.5
M20-P1.5
3/4UNF-16
I would have thought, being Japanese, it would be one of the metric sizes, but the "guide" states Toyota is the 3/4UNF size. This is on ebay though, so I wouldn't put money on their accuracy.
Saturday, November 29, 2008 - 12:44 am, by: Matt Newman(Soarersrock)
if you have a filter kicking around measure the inside diameter and as a guide add the pitch measurement and that should get you close enough to tell what size it is but thats the only solution i can offer you but maybe someone will know
Saturday, November 29, 2008 - 06:17 am, by: Cameron Laufer(Ivboost)
Ben, 1jz use a Ryco z418 oil Filter, here are the Specs, Thread size is at the bottom Part: Z418 Type Oil Filter End Material Height Overall 89mm Inside Diameter Top Inside Diameter Bottom Outside Diameter Top Outside Diameter Bottom Seam Diameter 77.5mm Seal Diameter 71.2mm Thread 3/4-16-UNF-2B
