  Soarer Central * Mechanical - TT * General Mechanical * Fuel Pump stuffed??? EMU Previous Previous    Next Next
Rob Rojo
Reg: 12-2007
Sunday, December 21, 2008 - 09:42 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have recently noticed a surging problem when under 80-100% throttle from around 5000rpm. There is no backfiring or miss as such but the car feels to surge as it goes up the through the revs.
I have an Emanage Ultimate have had a look at the the data logging and it seems strange as the factory ECU is running the injectors at 100% duty cycle momentarily even while decelerating and then cutting the injectors briefly only to run back at 100% with TPS at 60%.
I have tried the Fuel ECU bypass and swapped the spark plugs but neither made a difference.
The only reason I am leaning towards the fuel pump is that the Fuel pressure may be dropping as a result of the Pump to preventing enough fuel and the ecu compensating by maxing the injectors to fuel it up again.
Michael Keen
Reg: 10-2007
Monday, December 22, 2008 - 06:21 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
fuel filter?
Monday, December 22, 2008 - 05:48 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was my suggestion to Rob on MSN last night MIchael :-)
