  Soarer Central * Mechanical - TT * General Mechanical * Big power problem Previous Previous    Next Next
Open in new windowArchive through February 12, 2009Leo Khoshaba25
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Thursday, February 12, 2009 - 06:36 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wow, that sux dude.
Only thing i can think of is that the previous owner ran it low on oil, screwed the bearings and then maybe filled it back up and offloaded it.
Rob Rojo
Reg: 12-2007
Thursday, February 12, 2009 - 06:55 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think you found your big power problem! That's
very unlucky, on the bright side you should be able to get a motor for less than $500.00 (no turbos) or just pick up a 2j bottom end.
David Tra
qld
Reg: 11-2007
Thursday, February 12, 2009 - 07:25 pm, by:  David Tra (Bookie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Steven Anderson wrote on Thursday, February 12, 2009 - 06:36 pm:
I agreed. Neglect is the killer :-(
Sorry to hear about your engine loss.
Daniel Savage has alot of 1js for sale.
Where abouts in bonnyrigg do you live Leo?
I grew up around there :-)
Leo Khoshaba
Soarer GT-TL
Reg: 09-2008
Thursday, February 12, 2009 - 07:26 pm, by:  Leo Khoshaba (Evlgsr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I agree the title of this thread was correct and ended up in a big bang
rob what is involved in getting a 2j bottom end and putting it in on a 1j head is it just plug and play per say or is there parts that will have to be modified, i think i will go with the engine swap option and just finish it at that but now its looking for a motor that will be my problem finding one from sydney.
Leo Khoshaba
Soarer GT-TL
Reg: 09-2008
Thursday, February 12, 2009 - 07:28 pm, by:  Leo Khoshaba (Evlgsr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David - I think maybe he did but come on its a stock soarer if i was pumping massive power fair enough for this to happen
Daniel is not in sydney but i will defentely ask him as he has been a great person to deal with to get parts.
Edensor park actually but went to bonnyrigg high school was a great school loool
Cameron Laufer
T
Reg: 12-2007
Thursday, February 12, 2009 - 07:42 pm, by:  Cameron Laufer (Ivboost) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mate I don't believe that the conrod was the point of failure, sounds more like you had a melted/seized piston that let go, in turn braking the con rod, I've seen some big power 1jz with over 500hp at the crank and never have a conrod issue, you can push a 2jz to over 800hp on STD rods and 1jz rods are stronger....
As for getting a 2jz bottom end as Rob said, I think you will find you will need more then a bottom end, your head will be FUBAR.... cracked, bashed, bent valves just a start. How many of you have seen the insides of a motor that has let go. not much is reusable, bolton are normally fine, although the rear turbo may be shot as metal may have made itself through the exhaust track. When you brake a rod you normally bend or crack the crank and smash the top end.
If you reuse you intake manifold get you injectors checked, I would not be surprise if your no.6 injector is clogged or not flowing the same as the rest of them. Causing the problem.
David Tra
qld
Reg: 11-2007
Thursday, February 12, 2009 - 08:41 pm, by:  David Tra (Bookie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I went to bonnyrigg high in 2000. Needless to say, i wasnt there for long!
Daniel is not in syd but he does travel to syd.
Im sure you can work something out with him.
Leo Khoshaba
Soarer GT-TL
Reg: 09-2008
Thursday, February 26, 2009 - 09:04 am, by:  Leo Khoshaba (Evlgsr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought it was time for an update so here goes
after the car being out of action for a week or so it is now back on the road, the engine has been replaced (thanks to Daniel savage for organising a spare engine on a short notice, he is the man for parts) and so has the gearbox and ecu, let me just say this new package seems to be healthy and alot smoother then my old motor. It was comps tested and was 150 to 145 across all cylinders and has been dynoed at 145rwkw at vinces dyno on 9.5 psi with a very nice curve on 3rd gear (o/d off). The car runs alot smoother now and feels like it wants to keep going power wise.
Regarding the other engine it will be stripped for parts gearbox will be sold as it was not the problem, turbos where in good condition they will be sold but the block has a large hold on the side of it where the pistons came out of, basically the rod had snapped in half after the piston had exploded.
