  Soarer Central * Mechanical - TT * General Mechanical * I think my 1j has been opened? Previous Previous    Next Next
Michael Keen
Reg: 10-2007
Sunday, February 22, 2009 - 08:27 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
do you guys have gasket glue coming out around the sump to block? it like a clear metallic goldish any thoughts?
Sunday, February 22, 2009 - 08:42 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought 1J's didnt use gaskets, Just goo from the factory ?
Michael Keen
Reg: 10-2007
Sunday, February 22, 2009 - 08:47 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yer, i know that, but there would not be a heap spewing out the side on a factory engine would there?
Ben Socratous
as i drive though the valley of the 1/4 mile, i shall fear no falcodore, for the angel of boost is with me
Sunday, February 22, 2009 - 08:51 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm fairly sure that toyota used black goo for all oem joints. Could simply be a blown motor swapped out for a chaser motor and needed the mid sump swapped for a rear?
Michael Keen
Reg: 10-2007
Sunday, February 22, 2009 - 09:10 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes, it could but the engine number match the chassis.
yet it like a clearish gold colour with metallic in it. if ya get my drift
Cameron Laufer
T
Reg: 12-2007
Sunday, February 22, 2009 - 09:14 pm, by:  Cameron Laufer (Ivboost) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Toyota used grey goo on sump, upper pan, oil pump on 1jz's and red on Tranny Pans
Michael Keen
Reg: 10-2007
Sunday, February 22, 2009 - 09:18 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
so that confirms it then, my engine has been open......mmm i wonder what has been done to it? forgies would be great ahhaha
even the head gasket looks like a 3layer metal one is that standard?
Danny Dinh
GT T
Sunday, February 22, 2009 - 10:18 pm, by:  Danny Dinh (Xtc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have 4 1j engines sitting in my back yard and can confirm that they all have grey goo on the sump
Cameron Laufer
T
Reg: 12-2007
Sunday, February 22, 2009 - 10:44 pm, by:  Cameron Laufer (Ivboost) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yea 3 layer HG is about right, around 1.2-1.3mm compressed. If the sump has been off, the motor has been out of the car as it is not possible to pull the sump with it in there.
Michael Keen
Reg: 10-2007
Monday, February 23, 2009 - 06:35 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
makes you wonder hey
Steven Anderson
UZZ31 Manual
Reg: 05-2006
Monday, February 23, 2009 - 12:08 pm, by:  Steven Anderson (Cusscuss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
taking the sump off isnt really considered 'opening' an engine, taking the head off is, its not a big deal to drop the sump and put it back on.
