  Soarer Central * Mechanical - TT * General Mechanical * Ecu pin out, for 3 row pins on 1j ecu Previous Previous    Next Next
Danny Chatterton
Reg: 03-2009
Thursday, March 26, 2009 - 03:02 pm, by:  Danny Chatterton (Dannyec) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi guys, new on here.
i have a problem, with my soarer, when i try to do a ecu test using TE1 and E1 or TE2,E1, I don,t get any thing on the dash flashing. i want to try doing it from the ecu pins, to see if i have a dash fault, or wiring problem, between the two.
as it am having all the common soarer problems,eg spark, f/p ecu,ect ect.
when i did the check test,it came up with some strange message on the dash,in jap, which is not in the listed translation page.and when i hit the scroll button, it said ecu,ok and (i think) bcm,ng.does thing mean any thing too any one.any help would be great.please danny.
Chris Prak
JZZ30 Soarer - Twin Snails
Reg: 12-2006
Friday, March 27, 2009 - 04:34 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If it has NG after the efi, ect whatever, this is the problem. Leave it on the NG one, wait about 20 seconds and a number will come up. If there are multiple codes, they will come up in 20 second intervals. Search on here for the code and work from there.
