  Soarer Central * Mechanical - TT * General Mechanical * Timing Belt Changeover Previous Previous    Next Next
Ty Mackay
Soarer TT 1jz-gte
Reg: 01-2009
Saturday, May 30, 2009 - 03:00 pm, by:  Ty Mackay (Duo89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Guys my timing belt has started to crack etc etc
i heard this affects performance..
where can i get like a performance belt and how much to have someone replace it for me?
im also getting my car painted black again!
how many litres of black and how many litres of black would be required to paint the car?
Saturday, May 30, 2009 - 04:30 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Timing belt has no effect on performance (unless it jumps a cog or breaks of course), and there is no point in spending extra money on an "performance" belt, just get an OEM one or thru supercheap etc - they are all much the same.
If its cracked, then get it replaced ASAP, you don't want it to break.
Saturday, May 30, 2009 - 05:32 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I reckon 4 litres of high gloss sheen should do the whole car ... Maybe grab a sample pot to touch up the engine bay with ???
Ty Mackay
Soarer TT 1jz-gte
Reg: 01-2009
Saturday, May 30, 2009 - 07:31 pm, by:  Ty Mackay (Duo89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
price wise to get it replaced? labour etc?
is it a DIY?
im getting the car sanded back first,
im was thinking black and couple of coats of clear how many litres of each do u reakon?
Chris Prak
JZZ30 Soarer - Twin Snails
Reg: 12-2006
Saturday, May 30, 2009 - 08:24 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ty, if you need to ask, I recommend taking it to a mechanic. Any general mechanic should be able to do it. Replace the serpentine belt while your at it too as this comes off to get to the timing belt.
Are you DIY spraying painting?
Chris Prak
Reg: 12-2006
Saturday, May 30, 2009 - 08:25 pm, by:  Chris Prak (Carizma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Price maybe no more than $100 for labour. Depending how much workshop charge labour per hour. Shouldn't take more than hour to change if nothing goes wrong.
Sunday, May 31, 2009 - 07:04 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Chris, if he is talkin about the Timing Belt .... That means removing the harmonic balancer , serpentine belt , changing water pump , tensioner may as well be changed as well.
Your looking at between $550 and $750 including coolant and parts and labour depending on where you go. And those crank bolts are Nasty to undo sometimes.
Mark Tierney
Soarer GTT & Celsior
Sunday, May 31, 2009 - 08:33 am, by:  Mark Tierney (Mark_t) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
FYI, Greddy performance timing belt is about $200 delivered from Greenline in Japan.
While you are there, you may as well install the exhaust camgear...will net you another couple of neddies with a few degrees retard. Greddy one is about $200 delivered as well.
http://www.greenline.jp -(toyota, soarer, then engine parts catalog)
If you have plans to develop more power, get this stuff done now while the belt is being replaced.
It wont be good if the belt breaks, so this should be a priority. Sounds like the 100k's service hasn't been done?
Ty Mackay
Soarer TT 1jz-gte
Reg: 01-2009
Sunday, May 31, 2009 - 02:09 pm, by:  Ty Mackay (Duo89) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah probably not hey? i dont know the history, but sounds like its gonna cost a bit ouch!!
i wasnt gonna DIY but was seeing if it could b done :-)
spray painting diy no.. i gotta mate who will snadback and paint it professionally for about a grand including sanding back i just gotta provide the paint :-)
Scott Wilkes
Tasmania
92 TT Factory Manual
Reg: 10-2008
Sunday, May 31, 2009 - 02:55 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dont bother with the greddy, can get a gates racing belt with the blue backing for 99AUD from capa performance :-)
Shane Haverkamp
soarer TT
Reg: 10-2007
Sunday, May 31, 2009 - 05:29 pm, by:  Shane Haverkamp (Havabeer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i believe there's already a write up on this site about how to do a timing belt stop.
http://www.toymods.net//forums/showthread.php?t=14262&highlight=replacing+timing+belt+water+pump
has pretty much all the information you need on how to do it. you dont HAVE to replace things like tensioner or water pump. but its recommended. shouldn't cost cost more then a couple of hundred all up. maybe try calling a few work shops and asking for a rough quote.
