  Soarer Central * Mechanical - TT * General Mechanical * Soarer wont start Previous Previous    Next Next
Kym Modra
Soarer 2.5TT
Sunday, May 31, 2009 - 09:08 am, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Guys,
I have done a search to no avail. I was driving through a roundabout on Friday and my Soarer Just stopped. It would turn over but would not fire.
I had it towed home and tried to start it the next day - it fired up chugged a little bit then conked out again. I suspect the fuel filter, which I will be changing today, but I am not confident. I tried the B+ Fp trick to no avail thinking it may be the fuel pump ecu playing up.
You guys got any more ideas?
I was running a little low on fuel (about 10 litres) After it would not start I added another 10-15 litres I had in a jerry can to no avail either. I also noticed I can not get anything up on the display by pressing the fuel button either. Or does this only work when the car is running?
JZZ30 2JZ + Manual
Sunday, May 31, 2009 - 09:20 am, by:  James Johnson (Jamesy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
do a diagnostics check on it see what i brings up
Grant Rowan
jzz30 GT3582r
Sunday, May 31, 2009 - 09:29 am, by:  Grant Rowan (Booster13psi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It could be your igniter.
Check if you have spark.
Kym Modra
Soarer 2.5TT
Sunday, May 31, 2009 - 09:35 am, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I will do a diagnostics and let you know how I go.
Kym Modra
Soarer 2.5TT
Sunday, May 31, 2009 - 06:13 pm, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well I ran diagnostics - no fault, changed the fuel filter - still got a red arm from the fuel!
It still wont start.'
I have to do a search now on how to see if I have spark...............
Where is the igniter by the way?
Michael Keen
Reg: 10-2007
Sunday, May 31, 2009 - 07:43 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
igniter it is on the left strut tower.
so it cranks but not start. and happend all of a sudden, check your fuses, like all of them, in the engine bay, and in the drivers foot well.. also check to make sure the is power at the postive terminal at the alternator. if not your alt fuse has blown, i have seen this twice in these cars.
then get back to us.
Justin Camilleri
Had a 85 MZ10, 92 TT, Now 91 TT
Sunday, May 31, 2009 - 08:18 pm, by:  Justin Camilleri (Just) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm guessing your fuel pump has had it.
Sunday, May 31, 2009 - 08:43 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kym if its the fuel pump, ive got a stock one , was working fine, i just upgraded to a walbro pump... PM me and we can work something out :-)
Michael Keen
Reg: 10-2007
Sunday, May 31, 2009 - 08:47 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just check to make sure your getting power to the pump, the disconnect a fuel line near engine, you will need a second person for this. get them to watch it, best place it into a bucket or something, and turn car on, it fuel comes out pump is all good. well the best way of checking it with out a proper gauge to fit in the line, which i dont think you would have... and yeah
Kym Modra
Soarer 2.5TT
Monday, June 01, 2009 - 07:20 am, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for the tips - Im off work today to check this out. Yeah it just stopped when I was driving, It hasnt started since.... It did splutter once for a few seconds but I couldn't keep it going.
By the way I searched for hours last night - I could not find anything on how to check if you have spark, anyone point me in the right direction?
I do have Jeffs Soarer Bible, but I can only find one page as to where the plugs are located ( In Japanese), not how to remove them or check spark
I have removed the top cover plate. Do I just remove the 2 screws around the connection on each, and the plugs are underneath? Sorry for the dumb questions - Its not like my old HQ V8 thats for sure.
Thanks in Advance
PM Daniel Clarke
Kym Modra
Soarer 2.5TT
Wednesday, June 03, 2009 - 06:43 am, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have checked the fuses, timing belt is still intact,alternator is not seized. Still unsure how to test igniter. Any pointers would be great.
Going through Bible for tips as we speak.
PM Daniel Clarke
Christian Molenda
T
Wednesday, June 03, 2009 - 07:52 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
it does sound like fuel pump ecu.. however the fp b+ trick would have fixed this
Rob Rojo
Reg: 12-2007
Wednesday, June 03, 2009 - 09:32 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can you hear the pump when the ignition is turned on?
Kym Modra
Soarer 2.5TT
Wednesday, June 03, 2009 - 03:59 pm, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can't hear the pump going while in the on position - Doesn't the engine have to be started though to hear the pump?
Wednesday, June 03, 2009 - 04:31 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
IM Sending Kym a Pump tomorrow. See if that fixes it :-)
Michael Keen
Reg: 10-2007
Wednesday, June 03, 2009 - 08:27 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you dont normaly hear the pump if it a stock one, only when you upgrade it.
Kym Modra
Soarer 2.5TT
Thursday, June 04, 2009 - 07:03 am, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks all for your input. Great to know theres support out there :-)
PM Daniel
Kym Modra
Soarer 2.5TT
Monday, June 08, 2009 - 01:24 pm, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well I have spark, I have 12V at the pump in the boot, I removed fuel line close to the injectors on the battery side, turned it over and nothing came out! I sure hope the fuel pump Daniel's sending me fixes it.
Monday, June 08, 2009 - 08:46 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sent it thrusday, hopefully you recieve it tomorrow and fit it and get it all up and running :-)
Kym Modra
Soarer 2.5TT
Tuesday, June 09, 2009 - 06:03 pm, by:  Kym Modra (Avkdm) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi All,
It was the fuel pump after all! Thanks to everybody for their input, especially Daniel who sent me up a replacement pump. Now I am confident I can fix my passenger electric window next after trawling through the forums!
Thanks again.
PM Daniel Clarke
Tuesday, June 09, 2009 - 08:29 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No problems, glad i could help out.
