Saturday, June 27, 2009 - 01:13 pm, by: Cameron Laufer(Ivboost)
I thought I would start a thread with common parts for our 1jz powered soarers. Please feel free to add to the list.
1JZ-GTE Oil Filter OEM Part No.'s 90915-03002, 90915-20001, 90915-20003 or Ryco Z418
Toyota recommend 10w-30 grade engine oil for 1JZ-GTE Yet HKS Recommend Their HKS Hyper Ester JZ-G Engine Oil which is a 10w-50.
JZZ30 Air Cleaner OEM Part No. 17801-46060
1JZ-GTE Ignition Coil's OEM Part No. 90919-02205
1JZ-GTE Spark plugs OEM Part No. or NGK 90919-01180 or PK20R8 90919-01181 or BKR6EP-8 90919-01194 or PK20TR11 90919-01195 or BKR6EKPB11 For High Boost Applications NGK BKR7e
1JZ-GTE Overhaul Gasket Set 04111-46031
1JZ-GTE Valve Regrind Set 04112-46030
1JZ-GTE Engine Mount 12360-46020
1JZ-GTE Head Gasket 11115-88400
1JZ-GTE Cam Position Sensor 90919-05007
1JZ-GTE Crank Position Sensor 90919-05006
1JZ-GTE Front Main Oil Seal 90311-46001
1JZ-GTE Rear Main Oil Seal 90311-90006
1JZ-GTE Cam Cover Gaskets 11213-88400
1JZ-GTE Cam Shaft Seals 90311-38041
1JZ-GTE Oil Pump 15100-46030
1JZ-GTE Harmonic Balancer 13407-46010
1JZ-GTE Thermostat 90916-03092, 90916-03093
1JZ-GTE Multi V Grove Belt 90916-02309 or a 6PK1940
1JZ-GTE Timing Belt 13568-46010, 13568-49025, 13568-49065
1JZ-GTE Timing Belt Tensioner 13540-46010, 13540-46011
